nick13131
Where's my memory?
Mon Feb 09, 2015 5:46 pm
I recently got a 32GB microSD card for Christmas, and I have formatted it with NOOBS and Raspbian, but when I look at the contents in the LXDE file manager, I notice it says 24GB free of 27.8GB
First off, I know that it doesn't take 8GB of data to store Raspbian - I've done it on ~3GB before on a 4GB sd card. If NOOBS is allocating the other 5GB to it, how can I reduce this? I have not installed any other programs or connected to any WiFi, but I have added a third user (besides root and pi)
I am familiar with the disclaimer that 'actual memory size may be smaller' on a memory card, but it appears that a good ~5GB is unaccounted for. Why is this?
It's Pi o'clock somewhere!
elatllat
Re: Where's my memory?
Mon Feb 09, 2015 6:16 pm
1) use parted or gparted to look at how your card is partitioned.
2) be aware of bits vs bytes, and base 2 vs base 10 units
3) be aware of file system overhead (optionally remove reserved space with "tune2fs -m 0 /dev/root")
4) use "df -h /" and "du -schx /*" ("df -H" and "du --si" are base 10 units)
All space is accounted for if you know where to look.
Using Raspbian without NOOBS will give you more free space.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
DirkS
Mon Feb 09, 2015 8:12 pm
'lsblk' will show all the partitions on the SD card (including the size)
You will find that the NOOBS partitions (including recovery) take most of the 5GB.
elatllat
Tue Feb 10, 2015 4:34 pm
lsblk is one of those convenience tools like mtr and tree that you can get buy without but become favored once you find them.
