gkreidl
Howto: Flash support for most browsers (RPi 2/3)
Sun Feb 08, 2015 1:45 pm
Edit April, 7th, 2017: New thread title and support for other browsers.
Edit Otobert, 13th, 2017: Added Stretch support
Flash support is now realized in chromium-browser using the pepperflash plugin. It is installed by default on new images and can be installed on older systems with rpi-chromium-mods.
By adding a wrapper it can also be used in a lot of other browsers (Firefox, kweb, Midory, Qupzilla ...). It will not work in browsers built with gtk+3: epiphany, kweb3 and (currently) kweb on Stretch.
Flash support for other browsers (based on an original post by paulwratt):
For installation we need gdebi-core (or the full GUI version of gdebi):
sudo apt-get install gdebi-core
or
Now download the following file and install it with gdebi:
1) For Jessie:
wget http://ftp.debian.org/debian/pool/contrib/f/freshplayerplugin/browser-plugin-freshplayer-pepperflash_0.3.5-1~bpo8+1_armhf.deb
sudo gdebi browser-plugin-freshplayer-pepperflash_0.3.5-1~bpo8+1_armhf.deb
2) For Stretch:
wget http://ftp.debian.org/debian/pool/contrib/f/freshplayerplugin/browser-plugin-freshplayer-pepperflash_0.3.5-1+b1_armhf.deb
sudo gdebi browser-plugin-freshplayer-pepperflash_0.3.5-1+b1_armhf.deb
Then create the ~/.config/freshwrapper.conf
leafpad ~/.config/freshwrapper.conf
and add the following content:
audio_buffer_min_ms = 20
audio_buffer_max_ms = 500
audio_use_jack = 0
jack_autoconnect_ports = 1
jack_autostart_server = 1
pepperflash_path = "/usr/lib/chromium-browser/libpepflashplayer.so"
flash_command_line = "enable_stagevideo_auto=1"
enable_3d = 0
enable_hwdec = 0
quiet = 0
fullscreen_width = 0
fullscreen_height = 0
randomize_dns_case = 0
device_scale = 1
quirk_plasma5_screensaver = 0
enable_windowed_mode = 1
enable_xembed = 1
tie_fullscreen_window_to_browser = 1
enable_vaapi = 0
enable_vdpau = 0
vsync_afterwait_us = 0
fs_delay_ms = 300
enable_vsync = 1
double_click_delay_ms = 400
show_version_info = 0
probe_video_capture_devices = 0
# setting the following to '0' also seems to work
enable_xrender = 1
After saving the file Flash support should be available in most browsers. You may have to enable the plugin in your browser.
Flash animations work well, flash video to a certain degree on a RPi 3, depending on the video resolution (no hardware acceleration).
Minimal Kiosk Browser (kweb)
expandables
Re: Howto: Flash Player for Chromium on Raspbian with RPi2
Sun Feb 08, 2015 3:04 pm
How fast it it on the raspberry pi 2? Can you play 720p youtube video with this flash plugin for chromium?
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
Sun Feb 08, 2015 3:07 pm
expandables wrote:How fast it it on the raspberry pi 2? Can you play 720p youtube video with this flash plugin for chromium?
Why would you ever need Flash for YouTube? Visit http://youtube.com/html5 and join the 21st Century.
This is a doctor free zone.
expandables
Sun Feb 08, 2015 3:11 pm
I know html5 is the future i just was curious on the speed of flash on the raspberry pi.
DirkS
Sun Feb 08, 2015 3:17 pm
Hint: gkreidl already mentioned that it does not use HW acceleration.
gkreidl
Sun Feb 08, 2015 3:22 pm
No, but the embedded videos in the Raspberrypi.org forum play nicely.
Joe Schmoe
Sun Feb 08, 2015 3:23 pm
Heh heh. As is the case with lots of things like this, it will probably get to the point of actually working at the same time as when people really, totally, stop using Flash. I.e., when Flash is really, as many already claim it already is, "dead".
P.S. Side note: I've often said the same thing about "i18n" - that by the time they actually get it working, everybody will be speaking English (which is clearly the worldwide trend)...
mahjongg
Sat Feb 14, 2015 12:47 am
speed of flash has nothing to do with the speed video's are played. Flash is just used to launch a codex to play the video. If flash was really used to "play video" (that is to decode a video stream and put it on the screen), if it would work at all it would be excruciatingly slow, something like one frame every ten minutes. Flash code runs slow! is buggy and memory hungry!
The independently (cloned) player from google is not very much better than gnash, and Adobe keeps changing Flash run code (and its player) so its a moving target for people who want to write competing players.
gkreidl
Sat Feb 14, 2015 8:25 am
mahjongg wrote:[
I'm not a great friend of Flash, either, and I hope it will vanish soon. But people have been asking for it and sometimes it's the only way to get things to work (pages with Flash animation, for example).
You should not comment things you haven't tested. Video does work on many websites, a bit sluggish, sometimes, but it works. Not "one frame every ten minutes". Most embedded videos on the RPi website work quite nicely, for example.
mahjongg
Sun Feb 15, 2015 11:45 am
my "one frame per ten minutes" remark was in the purely theoretical (and nonsensical) case that flash code itself would be used for the video decoding. People seem to think that flash is used to decode the video, but that is laughable. It has nothing to do with "testing it myself" either, you just misunderstood the point I was making.
Flash is used as a video-player-launcher, NOT as a video decoder/player. There are better ways these days than Flash to launch a video stream player from inside a website these days.
There are also better ways to write games that play inside a browser than Flash.
iPad users also thought they wanted Flash, but they didn't get what they thought they wanted....
peter105
Tue Feb 17, 2015 6:01 am
I install the flash into raspbian,however if I surf
some flash Vedio web ,chromium will be exit without operate,but if I use vnc to connect with my pi2,the flash and the chromium will work very well, I don't know what happen...
mahjongg
Wed Feb 18, 2015 11:39 pm
chromium (for RM based systems) doesn't use Adobes flash player, but its own "clone", which is only a bit better than "gnash", also googles effort is no longer developed further nor updated for new versions of flash.
newsflash :D
For youtube you don't need flash anymore, Youtube has decided to natively support HTML5 from now on.
http://youtube-eng.blogspot.nl/2015/01/ ... l5_27.html
LienRag
Thu Feb 19, 2015 12:41 am
Thanks for the howto...
Is there a way to install Adobe AIR on Pi? Raspbian preferably?
On Linux it is sort of a PITA (only old version availables, and on 64 bits there are additional steps) but I did it and it works.
ghans
Sat Feb 28, 2015 8:40 am
I doubt that Adobe AIR was ever availble for Debian or
Ubuntu armel or armhf , so you're out of luck.
ghans
Sat Feb 28, 2015 11:30 am
LienRag wrote: Is there a way to install Adobe AIR on Pi? Raspbian preferably?
Adobe AIR is even more dead than Flash, it was an Adobe experiment to try to get rid of Flash, it's been abandonware for a while now.
expandables
Sat Feb 28, 2015 3:06 pm
For anyone who wants to install "armv7" raspberry pi 2 chromium go here http://blog.valitov.me/2014/06/installi ... m.html?m=1 :mrgreen:
Stephen nonetheless
Sun Mar 01, 2015 3:56 pm
Thanks!
This was the one thing lacking on pi that meant i needed to keep a laptop hooked up to the telly for the footy, great work Sir! :D
expandables
Sun Mar 01, 2015 9:00 pm
Stephen nonetheless wrote:Thanks!
You might need to keep that laptop flash is slow. :mrgreen:
Stephen nonetheless
Sun Mar 01, 2015 10:34 pm
Watched the footy on it today, ok it's a bit choppy but tbh that may be my feeble connection (~2Mbps) and it at least played consistently throughout whereas it often stutters and stops on the laptop. Only problem was not being able to install adblock (chrome version incompatible with webstore, 'pparently) but yeah quite pleased frankly :)
Kudos to the OP!
expandables
Mon Mar 02, 2015 12:39 am
Stephen nonetheless wrote:Watched the footy on it today, ok it's a bit choppy but tbh that may be my feeble connection (~2Mbps) and it at least played consistently throughout whereas it often stutters and stops on the laptop. Only problem was not being able to install adblock (chrome version incompatible with webstore, 'pparently) but yeah quite pleased frankly :)
Kudos to the OP!
New version of chromium here so you can be able to install extensions http://blog.valitov.me/2014/06/installi ... m.html?m=1 :mrgreen:
Stephen nonetheless
Mon Mar 02, 2015 11:26 am
Oh you good fellow! That's my bit of messing for this evening sorted anyway :D
skarebrian
Wed Mar 04, 2015 10:08 am
Well, having read how to put a Pi on the back of a TV - to get a simple permanent computer in place for youtube and tv replays - I got myself a Pi 2 - and what happened - first site I loaded up " you need Flash Player " Then an hour or so in the forum it seems it can work if you are somehat advanced in programming - with a special version of Chromium.
Anyone interested in putting up a tutorial on this ?
I think this is a good beginners project - to solve the PC-TV connection problem.
( the actual installation of software and hardware and connecting to a TV - went like a dream - great )
Todays newbie - Brian
ktb
Wed Mar 04, 2015 7:39 pm
Kudos to the OP!
Thank you for this
Rovaals
Sun Mar 29, 2015 12:25 am
Looking at http://odroidxu.leeharris.me.uk/ I can see Pepper Flash 15 for ARMv7h and a Pepper Flash 16 that doesn't specify if it is for ARMv7h or not.
Has this method (which says to use the Pepper Flash 12 file) been attempted with those newer ones? I don't have an RPi2, only a B+, so I can't check myself.
Has anyone posted videos to youtube of the performance of Pepper Flash on RPi2? When I look all I find are tutorials for Gnash on the other RPi models.
expandables
Sun Mar 29, 2015 1:24 am
Youtube performance is slow as a snail :mrgreen:
Return to “Raspbian”
