MrsKSayers
Raspberry Pi Certified Educator
Problem Installing Scratch GPIO
Sun Dec 07, 2014 4:51 pm
This is driving me nuts. I have 2 sets of SD cards and have successfully installed Scratch GPIO on my 8Gb cards but when I try to install it on my 4Gb cards I get errors.
I download the files OK then when running the install script I get:-
line 1: --2014-12-07: command not found
line 2: syntax error near unexpected token `('
line 2: `Resolving goo.gl (goo.gl)... 74.125.230.65, 74.125.230.64, 74.125.230.68, ...'
I'm typing this post from my Pi so do have an Internet connection.
I've used the instructions from Cymplecy to do this.
Help much appreciated before I go totally insane
Kim
simplesi
Re: Problem Installing Scratch GPIO
Sun Dec 07, 2014 4:58 pm
Hi - is this ScratchGPIO5 or 6beta?
Is there space enough on the card I wonder?
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
FTrevorGowen
Sun Dec 07, 2014 4:59 pm
MrsKSayers wrote:This is driving me nuts. I have 2 sets of SD cards and have successfully installed Scratch GPIO on my 8Gb cards but when I try to install it on my 4Gb cards I get errors.
Kim
It may be simply that you're running out of space on your 4Gb cards, especially if Raspbian was installed with NOOBS. You can check this via the df command (compare the result for both card sizes).
Trev.
Edit: I see that Simon has cross-posted with a similar suggestion.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
MrsKSayers
Sun Dec 07, 2014 5:00 pm
simplesi wrote:Hi - is this ScratchGPIO5 or 6beta?
Simon
I've tried 4 and 5 same error
MrsKSayers
Sun Dec 07, 2014 5:02 pm
Kim
Trev.
I have 214Mb free apparently! is this enough? I'll scream if that's all it is!
simplesi
Sun Dec 07, 2014 5:24 pm
For some reason - your download could be being corrupted
try this (corrected) link instead
sudo wget https://www.dropbox.com/s/56ohstul6g0nsem/install_scratchgpio5.sh?dl=0 -O isgh5.sh
and then
sudo bash isgh5.sh
Simon
simplesi
Sun Dec 07, 2014 5:27 pm
Hold - on - wrong link!!
simplesi
Sun Dec 07, 2014 5:30 pm
I've corrected the link in the post 2 above
simplesi
Sun Dec 07, 2014 5:34 pm
Well - the file is 200Kb so there is enough room for it but that's might not be a lot working headroom for your Pi - try the new link and see how it goes
MrsKSayers
Sun Dec 07, 2014 5:44 pm
Thanks will give it a go
