elatllat
Re: Headless?
Thu Oct 09, 2014 12:15 am
yes
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Re: Headless?
Thu Oct 09, 2014 3:36 pm
Boot the Pi to a command prompt.
sudo nano /boot/cmdline.txt
add
ip=169.254.3.14
to the end of the one line in that file, DO NOT split the line.
Wire the eth0 with a cat 5 to you laptop (no x-over needed).
Reboot your Pi and use PuTTY to connect to 169.254.3.14
This is a doctor free zone.
pluggy
Re: Headless?
Thu Oct 09, 2014 3:44 pm
If you set up internet sharing on the windows machine and leave the Pi with default settings it should connect to the internet through the windows machine as well, but you'll need to interrogate the windows machine to find the IP address its doled out to the Pi to ssh into it. Far easier to connect the Pi to the router.
How many ways of skinning a cat do you need ?
