NicoVanDerDussen
Sending attachements by e-mail
Mon Sep 08, 2014 11:19 am
I'm trying to send a JPG by e-mail.
Googling for Python Email Attachment gives quite a few results, but I don't get it to work properly.
Using
http://code4reference.com/2013/07/simpl ... -an-email/
gives a attachment ATT00001 which does not open.
Others also fail to give me the proper solution.
What is the "best" way for a novice to send e-mail by Python?
Nico
Setting up your Raspberry Pi to work with a 3G dongle http://nvdd.info/11gKrsZ
Re: Sending attachements by e-mail
Mon Sep 08, 2014 12:22 pm
import time
from datetime import datetime
import picamera
import smtplib
from email.mime.image import MIMEImage
from email.mime.multipart import MIMEMultipart
with picamera.PiCamera() as camera:
   camera.resolution = (1024, 768)
   camera.start_preview()
   # Camera warm-up time
   time.sleep(2)
   camera.capture('photo.jpg')
f_time = datetime.now().strftime('%a %d %b @ %H:%M')
toaddr = 'someone@example.com'    # redacted
me = 'picamera@mydomainname.co.uk' # redacted
subject = 'Photo ' + f_time
msg = MIMEMultipart()
msg['Subject'] = subject
msg['From'] = me
msg['To'] = toaddr
msg.preamble = "Photo @ " + f_time
fp = open('photo.jpg', 'rb')
img = MIMEImage(fp.read())
fp.close()
msg.attach(img)
try:
   s = smtplib.SMTP('localhost')
   s.send_message(msg)
   s.quit()
except:
   print ("Error: unable to send email")
This is a doctor free zone.
NicoVanDerDussen
Mon Sep 08, 2014 1:13 pm
thanks for the example code - I hacked it to work with GMail and added a few items from others.
I left the redundant coded as comments deliberately.
#http://www.raspberrypi.org/forums/viewtopic.php?f=32&t=86441
import time
#import picamera
from smtplib import SMTP
from smtplib import SMTPException
import smtplib
   time.sleep(2)
toaddr = 'to@outlook.com'    # redacted
me = 'me@gmail.com' # redacted
msg['From'] = me
msg['To'] = toaddr
fp.close()
msg.attach(img)
try:
   s = smtplib.SMTP('smtp.gmail.com',587)
   s.ehlo()
   s.starttls()
   s.ehlo()
   s.login(user = 'me@gmail.com',password = 'super_password')
   #s.send_message(msg)
   s.sendmail(me, toaddr, msg.as_string())
   s.quit()
#except:
#   print ("Error: unable to send email")
except SMTPException as error:
      print "Error: unable to send email :  {err}".format(err=error)
It still send the attachment without the file name .
ATT00001 instead of photo.jpg.
I appreciate being able to learn from those who walked the way long before me :)
NicoVanDerDussen
Mon Sep 08, 2014 2:02 pm
seems as if I found a solution :D
#!/usr/bin/python
# You are entering crocodile infested water!
# A noob at work!
# Retrieved from http://solvingmytechworld.blogspot.com/2013/01/send-email-through-gmail-running-script.html
# Kept all the main code, but hacked a bit
# Import smtplib for the actual sending function
import smtplib
# For guessing MIME type
import mimetypes
# Import the email modules we'll need
import email
import email.mime.application
#Import sys to deal with command line arguments
import sys
# Create a text/plain message
msg = email.mime.Multipart.MIMEMultipart()
msg['Subject'] = 'subject_you_prefer'
msg['From'] = 'from@gmail.com'
msg['To'] = 'receivers_mail@gmail.com'
# The main body is just another attachment
body = email.mime.Text.MIMEText("""Here you can write as many things as you want!""")
msg.attach(body)
# PDF attachment block code
# Nico: Ok, use a fixed image...and a jpg not pdf
#directory=sys.argv[1]
directory = 'photo.jpg'
# Split de directory into fields separated by / to substract filename
spl_dir=directory.split('/')
# We attach the name of the file to filename by taking the last
# position of the fragmented string, which is, indeed, the name
# of the file we've selected
filename=spl_dir[len(spl_dir)-1]
# We'll do the same but this time to extract the file format (pdf, epub, docx...)
spl_type=directory.split('.')
type=spl_type[len(spl_type)-1]
fp=open(directory,'rb')
att = email.mime.application.MIMEApplication(fp.read(),_subtype=type)
fp.close()
att.add_header('Content-Disposition','attachment',filename=filename)
msg.attach(att)
# send via Gmail server
# NOTE: my ISP, Centurylink, seems to be automatically rewriting
# port 25 packets to be port 587 and it is trashing port 587 packets.
# So, I use the default port 25, but I authenticate.
s = smtplib.SMTP('smtp.gmail.com:587')
s.starttls()
s.login('from@gmail.com','super_password')
s.sendmail('from@gmail.com','receiver@outlook.com', msg.as_string())
s.quit()
Mizzy50
Sat Apr 11, 2015 4:49 pm
From where do I get these library files
import datetime
import smtplib
import MIMEImage
Sat Apr 11, 2015 7:26 pm
I think all of those python modules are part of the base install.
Return to “Python”
