Brandon92
Re: Relay Module KY-019 5V
Sun Sep 16, 2018 8:30 am
tlfong01 wrote:
Sat Sep 15, 2018 5:23 am
Brandon92 wrote:
Fri Sep 14, 2018 3:27 pm
Yup, you are correct. That's why I advised you to use a sensor with a I2C data bus interface. Or
does this sensor something that you really need?
DHT22 directly interrupting Rpi, bypassing stupid and slow MCP23017
Well, I actually have bought three other types of sensors to mess around (the most recent one is DHT12 which is similar to DHT22, but also I2C compatible).
But I really need this time wasting, trouble making, DHT22 for two reasons:
  • 1. I need to have 64 sensors for my small, 64 bed room castle (well, in the air) automation project.
  • 2. I need to show off that I can interrupt Rpi with 64 devices. :lol:
Now I am thinking of overcoming the slow and stupid MCP23017 interrupt thing by forgetting it altogether. Instead of using MCP23017 INTA, INTB, I will let DHT22 open drain output (already at the same time, connected to MCPO23017 GPIO pin) to itself directly interrupting RPi.
Appendix - DHT12
DHT12 Datasheet
http://www.robototehnika.ru/file/DHT12.pdf
Castle in the air - Don McLean - 2,295,059 views
https://www.youtube.com/watch?v=TTqi7iEZEWA
Okay, I think it is still cheaper to buy a dedicated sensor.
However, this will not work. Because when you sent a start plus. All the sensor are going to response to you. If you make a dedicated line for the sensors to your Rpi. I think it's a better idea to multiplex them on that single line. So, that you can talk directly to the sensor. You can buy dedicated multiplex chips. Remember that it's need to be bidirectional, or use a trick. An other options is to use a analog switch to enable one sensor on your data bus.
tlfong01
Wed Sep 19, 2018 2:46 am
Wiring OR 64 DHT22 outputs together
Ah, the last schematic has some wires wrongly connected and should have misled you. My apologies. I attach a debugged one now.
BTW, I think the 64 DHT22's wired or interrupt signal is one way ticket to the blue, never coming back. In other words it is a waste of money to get a return ticket. Of course (not in our case) Rpi can always read MCP23017 IntCAP A to find out which naughty DHT22 baby disturbs her sleep, ...
Wired logic connection - Wikipedia
https://en.wikipedia.org/wiki/Wired_logic_connection
PCA9616 - Bus Buffer, 3 Channel, SMBus/I2C TSSOP16 - element4
https://hk.element14.com/nxp/pca9616pw- ... g%2Fsearch
Neil Sedaka - One way ticket 1959 - 1,339,250 views
https://www.youtube.com/watch?v=xGGU-15Tt6M
https://www.youtube.com/watch?v=oQtmU8ZbDq0
Eruption - One Way Ticket 1979 - 5,782,318 views
https://www.youtube.com/watch?v=RC8ApqqKuAg
I am an electronics and smart home hobbyist.
tlfong01
Wed Sep 19, 2018 6:37 am
BTW, I think the 64 DHT22's wired or interrupt signal is one way ticket to the blues, never coming back. In other words there is no need to use a bidirectional channel. Of course (not in our case) Rpi can always read MCP23017 IntCAP A to find out which naughty DHT22 disturbs its sleep, ...
Expanding Rpi Project Work Bench
The Rpi work bench is getting too small for more to come prototyping boards, so I am assembling a bigger bench to show off as many of my master pieces as possible, ...
StevenP
Wed Sep 19, 2018 8:10 am
Very impressive use of space on your workbench! I wish my own wiring was as neat! ;)
"The time has come," the Walrus said,
"To talk of many things..."
tlfong01
Thu Sep 20, 2018 9:03 am
Marie Kondo: "The Life Changing Magic of Tidying Up"
Well, perhaps this pretty young lady can make your wish come true! :)
I couldn't concentrate much when watching the pretty lady speaking softly :) , though I still remember a couple of words that surprise me, such as spark joy, touching the thing, get rid of unwanted things, do it right now, but the key word that inspires me most is 'category'.
This "category" idea is perhaps simple or just common sense, but I think indeed it is very important and useful in my everyday organizing things and ideas, but also in computer hardware and software projects.
Marie Kondo: "The Life Changing Magic of Tidying Up" | Talks at Google - 1,756,171 views
https://www.youtube.com/watch?v=w1-HMMX_NR8
tlfong01
Thu Sep 20, 2018 1:17 pm
Marie Kondo: "The Life Changing Magic of Tidying Up" - Google Talk - 1,756,171 views
  • get rid of unwanted things
  • categorize
My Japanese 5S and KaiZen Style Rpi Work Bench
- all benches have wheels to facilitate moving.
/to continue, ...
Appendix - Japanese 5S and Kaizen Videos
TOYOTA 5S - 200,772 views
https://www.youtube.com/watch?v=nHutkkfUpDs
Kaizen The Secret behind Japanese Productivity - 90,531 views
https://www.youtube.com/watch?v=fcBXtwGexNc
Lean 5S in MSICU - 74,598 views
https://www.youtube.com/watch?time_cont ... MkXICM1-98
Japan 5S Methodology - Wikipedia
https://en.wikipedia.org/wiki/5S_(methodology)
tlfong01
Sat Sep 22, 2018 9:03 am
Rpi Controlled Aquaponics Tank
https://www.youtube.com/watch?v=SLMq0EI-EOA
https://www.youtube.com/watch?v=3AcsSn9ABK8
tlfong01
Tue Sep 25, 2018 1:13 pm
tlfong01 wrote:
Sat Jul 07, 2018 8:00 am
tlfong01 wrote:
Fri Jul 06, 2018 8:34 am
tlfong01 wrote:
Thu Jul 05, 2018 9:17 am
Next step is to see if 5V signals can control the 4 relays.
Quad KY019 Relay Module Assignment
Relay 1 = 220VAC
Relay 2 = 12VAC
Relay 3 = 24VAC
Realy 4 = 12VDC
Now I am testing the relay box off power, with following setup.
1. 220AV power off
2. 12VDC power off
3. 5V power on
4. IN1, 2, 3, 4 manual connect to 5V power.
4. Ears to listen to relay on/off clicks
5. Multimeter to check if relay COM/NO open/short
Everything went well. Next step is to test the relay box with 220VAC power on.
Quad KY019 Relay Module Rack Mount Notes
tlfong01
Wed Sep 26, 2018 7:57 am
ky019x4v1 wiring notes
tlfong01
Thu Sep 27, 2018 5:03 am
Portable RCBO Schneider Easy9 2P Wiring Notes
RE: RELAY MODULE KY-019 5V Postby tlfong01 » 2018-Jul-07 Sat 11:13 pm
https://www.raspberrypi.org/forums/view ... 5#p1338021
Leak Electricity Protection Plug CAA-19
RE: RELAY MODULE KY-019 5V Postby tlfong01 » 2018-Jul-12 Thu 2:31 pm
https://www.raspberrypi.org/forums/view ... 0#p1339896
Schneider Easy9 Air Breakder Home Main Breaker 2P10A~2P63A With Electricity Leakage Protection 2P 10A - ¥138
https://detail.tmall.com/item.htm?id=53 ... 36:3681680
tlfong01
Thu Sep 27, 2018 7:57 am
Rpi3B+ KY014 x 4 (220VAC, 12VAC, 24VAC, 12VDC) UPS Panasonic 6VDC x 4
tlfong01
Sat Sep 29, 2018 9:32 am
Quad KY019 Relay Station
tlfong01
Sat Sep 29, 2018 1:25 pm
Mains meter wiring notes
tlfong01
Sun Sep 30, 2018 1:19 am
Aquaponic Domestic Garden
Aquaponic Domestic Garden MagPi Issue 74 October 2018
https://www.raspberrypi.org/magpi/wp-co ... Window.png
https://www.raspberrypi.org/magpi-issues/MagPi74.pdf
08 Aquaponic Domestic Garden
46 Laundry-saving rain detector
tlfong01
Thu Oct 04, 2018 12:41 pm
Mains meter wiring notes 2
tlfong01
Fri Oct 05, 2018 7:49 am
Mains meter wiring notes 3
tlfong01
Fri Oct 05, 2018 8:51 am
Mains meter wiring notes 4
tlfong01
Tue Oct 09, 2018 3:48 am
Aquaponic Dometic Garden - MagPi 2018oct
https://www.raspberrypi.org/magpi/aquap ... ic-garden/
https://twitter.com/braghettos
Growing veggies indoors when you’re not always there is easy when you have a Raspberry Pi and a guard fish. Rob Zwetsloot
“Living in a big city has pros and cons,” Diego Braga tells us. “One of the cons I suffered most is not having a small organic garden.”
Diego lives in Milan, in a small apartment with a smaller balcony that he spends a lot of time away from. That didn’t stop him wanting to grow some fresh veg for himself, though, and he looked at hydroponic gardens to see if that was a solution.
A prototype setup for the system using IKEA parts
Building an aquaponic garden with live fish
“One of the cons of this approach is that you need to feed fertiliser in the water, and that’s something that, even if it can be automated, is not self-sufficient,” Diego explains.
“In 2015, EXPO Italy took place and in a pavilion there was an aquaponics system in which plants and fishes were living close and feeding each other. I started to study the aquaponics system and it blew my mind: two different ecosystems (the aquarium with fishes and plants in the solid earth) can feed each other.
The waste of one is the nourishment of the other. That was what I wanted.”
Diego figured all he’d then have to automate is the cleanliness of the aquarium, and decided to do it and collect sensor data via IBM Watson’s IoT platform. It took him a while to figure out how.
“First of all, I had to study a solution to keep the aquarium clean. The fish waste is the perfect nourishment for the plants and this waste lies on the bottom of the aquarium. One night I had an inspiration: use an X-Y plotter and, instead of writing on a surface, use a submersible pump to collect all the waste and deliver it to the plants.”
There are a lot of sensors required to keep the system working well
Aquaponic domestic garden pump and waste
Using an IKEA shelf with the aquarium at the bottom and pot on the shelf above, the waste water is pumped up to the plant, which then uses it and pH-balances the water, while gravity allows nutrients to drop down to the fish.
To get data from the sensors so he could keep an eye on it, Diego used a Raspberry Pi:
“I already worked with Raspberry Pi devices in previous projects, but in this case the availability of the Node-RED orchestration that can interact with the GPIO pins and the availability of a Watson IoT node library was perfect to connect my aquaponics system to the cloud.
The Raspberry Pi was the perfect piece to complete the puzzle.”
After so long, what does Diego think of his creation? “It works really well. It’s wonderful and reassuring to see plants growing in the living room next to the sofa. Up to now, I’ve planted basil and tomatoes and they’ve been really tasty. When I’m sitting in the living room, I can also smell the vegetables.”
tlfong01
Fri Oct 12, 2018 7:07 am
[/i][/color]
220VAC Pump with no ground wire
I found that my AC220V pump has not ground wire. I wonder if the electricity leaking out would kill my fish. Perhaps I should find a mains ground wire and immerse into the fish tank, ...
Fri Oct 12, 2018 7:25 am
If it doesn't have a ground wire, then it shouldn't need one. Putting a ground wire in your tank would be more likely to kill the fish if there was a leak as the electricity would flow through the water from the pump to the ground.
tlfong01
Mon Oct 15, 2018 3:34 am
1. If it doesn't have a ground wire, then it shouldn't need one.
2. Putting a ground wire in your tank would be more likely to kill the fish if there was a leak as the electricity would flow through the water from the pump to the ground.
Well, I very much agree with you on point 1.
But for point 2. I am not very sure.
I am using the amazing Amazon's waterproof electric shaver that works under a shower. But I always worry one day the shaver leaks AC 220V electricity and the shock shaves all the hair on my head in a split second! :mrgreen:
Amazon WaterProof Electric Shaver
https://www.amazon.com/WATERPROOF-Elect ... B01LY3XZPY
About the product
... Get a shave that’s fast and close , ... in just a few strokes
... 5-Direction Flex Heads - heads independently move in 5 directions for a faster and closer shave
... With the Wet and Dry seal, you can shave even under the shower ...
Mon Oct 15, 2018 5:22 am
I don't know about where you are, but here in the UK there are very strict rules about electrical sockets in bathrooms.
1. No standard (3-pin) sockets allowed at all.
2. Only two-pin transformer isolated sockets may be fitted.
3. Any sockets must be a certain distance from a bath or shower (I can't remember the distance without looking it up).
Because the sockets are completely isolated from the normal mains circuit by a transformer, if electricity did try to "leak" out, it would have nowhere to go. There is no path from the power to ground because it is isolated from ground, unlike the standard fittings where the Neutral wire is normally grounded at some point. The only way you should be able to get a shock from a faulty device in this scenario is if you came into contact with both wires from the socket.
Also, I can see on that shaver that it has a power supply on the plug end that probably supplies something like 12V DC to the shaver and will be fully isolated from the mains supply.
Brandon92
Mon Oct 15, 2018 5:42 am
I have also a electric shaver from Philips that I can use in the shower. However when I charge that device, I can not use it. (It will not turn on when connected to the charger).
So, Is there something written in the manual about this. And also your picture is different than the provided link.
tlfong01
Mon Oct 15, 2018 8:27 am
4. Because the sockets are completely isolated from the normal mains circuit by a transformer, if electricity did try to "leak" out, it would have nowhere to go. There is no path from the power to ground because it is isolated from ground, unlike the standard fittings where the Neutral wire is normally grounded at some point. The only way you should be able to get a shock from a faulty device in this scenario is if you came into contact with both wires from the socket.
5. Also, I can see on that shaver that it has a power supply on the plug end that probably supplies something like 12V DC to the shaver and will be fully isolated from the mains supply.
Just a short comment on point 5
Sorry, I carelessly forgot that my shaver is not like the 220VAC input fish tank water pump. It has a 220VAC input 15VDC output adapter to charge the battery inside the shaver.
Philips Series 3000 Wet & Dry Men’s Electric Shaver - S3580/06 £54
https://www.amazon.co.uk/Philips-Electr ... B01N2TJ7O8
UK 2-Pin Bathroom Plug, 4.4 out of 5 stars, 764 customer reviews, 59 answered questions
* 4 directional flex head to adjust to every curve of your face and neck.
* 50 minutes of cordless shaving time from a one hour charge.
* shave wet or dry: 100% waterproof shaver for use in the shower.
* Input : 100~240VAC 9W
* Output: 15V DC 5.4W
tlfong01
Mon Oct 15, 2018 9:58 am
Philips Series 3000 Wet and Dry Electric Shaver Instruction Manual
https://www.argos-support.co.uk/instruc ... t89906.pdf
Note - The shaver cannot be used directly from the mains.
Charging
2. When you charge the shaver for the first time or after a long period of disuse, let it charge until the charging light lights up continuously. See the table below for the charging time of your shaver.
Charging time 1 hour/8 hours
Shaving minutes 60 min/50 min/45 min/40 min.
