NickT
OK LED off most of the time following rpi-update
Thu Jun 07, 2012 7:32 am
I've used the rpi-update utility to get the latest kernel and firmware to see if it addresses some USB errors. Following the upgrade the 'OK' LED is off most of the time and occasionally flashes on. The Pi appears to operate normally. I've done this with two SD cards, each behaves the same. If I flash them back to the state I had before the update, the LED stays on.. My installation is fairly standard, just the April Debian and a VNC server. The version details after update are :
Linux version 3.1.9+ (dc4@dc4-arm-01) (gcc version 4.5.1 (Broadcom-2708) ) #101 PREEMPT Mon Jun 4 17:19:44 BST 2012
Has anyone else observed this behaviour? Should I be concerned?
itimpi
Re: OK LED off most of the time following rpi-update
Thu Jun 07, 2012 7:55 am
Mine is the same. I think that light is meant to flash for SD card access so that makes sense.
If I have no wired ethernet then I have the Red Power LED on solid and occasional flashes on the OK LED. All other LED's being off.
If I have a wired Ethernet connected then I get the three LED's associated with that coming on as well (2 green and one yellow) - ending up with quite a light show :)
dom
Thu Jun 07, 2012 8:46 am
That is correct. I had always intended the LED to be lit when SDCARD was being accessed, but the initial kernel had that inverted.
Occasional flashed on (typical from sdcard) are much more visible than occasional flashed off.
NickT
Thu Jun 07, 2012 9:06 am
dom wrote:That is correct. I had always intended the LED to be lit when SDCARD was being accessed, but the initial kernel had that inverted.
Thank you for the information, I'll trust this update then. Perhaps 'OK' isn't the best legend to have on the silk screen. I'm sure other users will also interpret the absence of light as signifying 'NOT OK'
rurwin
Thu Jun 07, 2012 9:58 am
It's not as bad as "10M" ;-)
grumpyoldgit
Thu Jun 07, 2012 10:03 am
You get the same if the file system is copied to a memory stick. On boot-up OK flashes once, briefly. But after that the SD card is not being accessed so OK does not light up again.
dpawson
Thu Jun 07, 2012 10:36 am
Someone tell what rpi-update is please?
Dave
NickT
Thu Jun 07, 2012 10:46 am
dpawson wrote:Someone tell what rpi-update is please?
Dave
It's way of keeping your Pi up to date with the very latest firmware/kernel patches. Best explained here
https://github.com/Hexxeh/rpi-update
dpawson
Thu Jun 07, 2012 11:03 am
Dave
Needs ca-certificates and git-core too!
Thanks.
dpawson
Thu Jun 07, 2012 11:09 am
Having run it I get
Using SoftFP libraries
/opt/vc/sbin/vcfiled: error while loading shared libraries: libvchiq_arm.so: cannot open shared object file: No such file or directory?
Suggestions please?
NickT
Thu Jun 07, 2012 11:15 am
dpawson wrote:Having run it I get
Suggestions please?
It does that for everybody apparently. It can be safely ignored
dpawson
Thu Jun 07, 2012 11:18 am
OK, thanks Nick
texy
Thu Jun 07, 2012 12:42 pm
dpawson wrote:
Dave
Thanks.
Last night the ca-certificate failed to download (or be found, one or t'other). Is this resolved now?
Texy
rurwin
Thu Jun 07, 2012 12:48 pm
@texy, Have you done a "sudo apt-get update" recently? I understand things are moving quickly in the Debian world at the moment.
texy
Thu Jun 07, 2012 1:20 pm
No, not since last night ;-)
Texy
dpawson
Thu Jun 07, 2012 1:23 pm
Texy
No problem today.
Dave
texy
Thu Jun 07, 2012 1:25 pm
Thanks - I will give it a go again later.
Texy
rurwin
Thu Jun 07, 2012 1:47 pm
http://www.raspberrypi.org/phpBB3/viewt ... =26&t=6857
Summary: Don't do an RPiUpdate at the moment; it seems to be broken.
dpawson
Thu Jun 07, 2012 1:55 pm
rurwin wrote:http://www.raspberrypi.org/phpBB3/viewt ... =26&t=6857
Worked an hour ago?
Dave
texy
Thu Jun 07, 2012 2:45 pm
Thanks for the heads up.
T.
