reflow
Output to VGA
Sun Mar 16, 2014 12:38 pm
Is it possible to output in VGA through the usage of an adapter?
stevepdp
Re: Output to VGA
Sun Mar 16, 2014 12:43 pm
Yes, VGA adapters are known to work with Raspberry Pi.
See this doc at the elinux wiki for a list of known working adapters and other important info. They can be pretty tricky to set up depending on the adapter used.
You'll likely also want to research VGA specific settings for your /boot/config.txt
FTrevorGowen
Re: Output to VGA
Sun Mar 16, 2014 2:44 pm
stevepdp wrote: ...
FWIW, this page of mine may be of interest:
http://www.cpmspectrepi.webspace.virgin ... GA_Monitor
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
