CharlyDelta
Contact: Facebook
Re: RPi Cam Web Interface
Thu Jan 16, 2020 12:17 pm
I based it on your code. That's the fun part. Thank you for the push that got me here!
Found it with
annotate.write ('Obj = {}'.format (sensor.get_obj_temp()))
Have a good day, ras07 !
awezm
Sun Jan 19, 2020 12:23 pm
How can I redirect the video output and the entire web interface to my custom website url instead of it being on http://ipAddress:port/subfolder?
ras07
Sun Jan 19, 2020 11:13 pm
That's a DNS and routing issue, and it's quite a bit beyond the scope of this forum/topic. But if you're trying to make it accessible to the outside world you should know that RPi-CWI isn't intended to be secure, and exposing it to the world is a really bad idea without a thorough understainging of the security considerations. In addition it can use some major bandwidth; unless you have a commercial internet feed, your upstream bandwidth likely isn't sufficient.
Unless you really know what you're doing, you shouldn't try to do this.
ras
Bagmulgwan
Mon Jan 20, 2020 4:19 pm
I just got a surveillance camera working with the motion package. It's neat, but continuous surveillance is not really what I want to do with the camera. It's just that everything about this – to my mind, rather complex – project was easy to find and set up, because there are tons of examples on the web.
What I really want is simply a remote camera that I can use to check the state (open/closed) of a garage door somewhere close – but not visible from a window, say. There is no need for motion detection. I just want a button in a browser window that I can click and see whether the door is open or closed. Simple, right? Would anyone here know of such a project – that would help me get started, at least? Thank you in advance!
ras07
Tue Jan 21, 2020 4:15 am
RPi Cam Web Interface would work fine for this and is easier to set up than Motion. Note that it doesn't work with USB cameras, however, in case that's what you already have.
Bagmulgwan
Tue Jan 21, 2020 7:20 am
Thank you, but Motion was, in fact, so easy to set up in maybe half an hour that it really was no problem at all. The problem was its complexity, and RPi Cam Web Interface seems just about as complex. I don't want a package that can do 15-20 things; I just want a simple application that lets me check the garage door's state (open/closed) remotely when I want. (In my experience, the more complex an application, the more liable it is to break.)
The "simple application" would be something like this: A button on a web page. When clicked, it runs raspistill, say, and takes one photo. And then shows the photo on the remote screen.
That's all. I can do it now by ssh'ing to the remote RPi, running raspistill once, scp'ing the jpg to my PC and then viewing the image locally. But clicking the button on the web page would be faster.
Bagmulgwan
Tue Jan 21, 2020 5:06 pm
Finally thought of a faster way: ssh to the remote camera with the -X argument. Run raspistill. Then run links2 on the jpg file. The image appears on my local screen. Done.
Maybe this is fast enough for my modest purpose. No need for a web server on the Raspi, say.
RidleyNelson17
Contact: Twitter
Thu Feb 13, 2020 1:34 am
Is there any way someone could possibly post a bithub link or any link to that matter to an .img file containing the latest build?
precaash
Fri Feb 14, 2020 12:17 pm
Hey guys,
I wrote a python script that sends an 'im' command to FIFO when a certain GPIO pin receives a signal and it works.
However I want that the pictures that are taken that way have a different file name: e.g. from "im_0030_20200214_105335.jpg" to "trig_0030_20200214_105335.jpg".
As a first step I want to permanently change the saved file name. I read that I would need to configure the raspimjpeg file (there are two: /etc/raspimjpeg and /var/www/html/raspimjpeg) so I change it with the following command:
 sudo sed -i 's,image_path /var/www/html/media/im_%i_%Y%M%D_%h%m%s.jpg,image_path /var/www/html/media/trig_%i_%Y%M%D_%h%m%s.jpg,g' raspimjpeg
(Yes, I changed both)
It changes the file content, but once I take a picture the filename still remains as ""im_0030_20200214_105335.jpg"
It feels to me like the changes are not applied. How should I proceed?
Thank you in advance! This forum has already proven helpful to me numerous times! :D
ras07
Fri Feb 14, 2020 7:39 pm
I'm not positive, but I'd imagine you'd have to restart the camera to reread the configuration file. This will probably cause timing and other issues, and is generally heavy-handed in a way that may not suit your needs.
I'd recommend a different approach: leave the raspimjpeg file alone, and instead set some kind of flag (could be a temporary file somewhere) in your python script. Then edit (or create) the end_img.sh script in the macros directory to rename the file after it's captured (the script gets the file name on the command line, so you'll need to parse that to figure out what to change). Then clear the flag (erase the temp file or whatever).
Incidentally, two things to note regarding your first solution - the first is that /var/www/html/raspimjpeg is just a symlink to /etc/raspimjpeg, so you wouldn't need to edit both; they are the same file. The second is that settings in uconfig will override settings in raspimjpeg, so could just make the setting changes there rather than mess with raspimjpeg (and that would generally be better). My guess is you would still have to restart the camera though - I think my suggestion would be preferable.
Amarand
Contact: Website Yahoo Messenger Facebook YouTube
Mon Feb 17, 2020 4:38 pm
I did a search in this topic for the word "focus" and didn't find anyone asking this question....
I've been successfully using the ArduCAM drop-in programmable focus camera with RPi Cam Control for a few weeks now. Works great.
The focus control all goes through the same ribbon cable, which is nice. I guess other versions have you connect the focus control to the GPIO?
Because only one program can be talking to the camera at once (apparently), I need to "Stop Camera" and then run the Python tools to adjust focus, then "Start Camera" again once the focus is right.
What I'd love to see is a focus control built into the RPi Cam Web Interface, so I can do the focus and preview right in the same app.
Is that something that could eventually happen?
Return to “Camera board”
