klricks
Re: STICKY: Howto: Disable Screen Saver In Raspbian
Tue Feb 26, 2019 6:16 pm
jamesh wrote:
Tue Feb 26, 2019 3:26 pm
There is some official documentation here.
https://www.raspberrypi.org/documentati ... ensaver.md
If anyone finds that doesn't work, please indicate the problem by posting in this thread.
xscreensaver works but it is a 40MB install and adds a background process.
Simpler to do these commands (For GUI Desktop only):
xset s off
xset -dpms
To make permanent add those 2 commands to autostart
/etc/xdg/lxsession/LXDE-pi/autostart
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
jwilson115
Fri Mar 15, 2019 6:21 am
On the Console
If you are using the Raspberry Pi solely on the console (no desktop GUI), you need to set the console blanking. The current setting, in seconds, can be displayed using
cat /sys/module/kernel/parameters/consoleblank
Here, consoleblank is a kernel parameter. In order to be permanently set, it needs to be defined on the kernel command line.
sudo nano /boot/cmdline.txt
Add consoleblank=0 to turn screen blanking off completely, or edit it to set the number of seconds of inactivity before the console will blank. Note the kernel command line must be a single line of text.
regroers
Sat Mar 16, 2019 7:55 am
Thank you. This is very useful.
It is more fun to drive a slow car fast than to drive a fast car slow.
regroers
Thu Mar 21, 2019 5:51 am
Thanks man! This worked on me. :D
Moore253
Thu Jun 20, 2019 5:08 am
Edit the autostart file
For the standard Pi user:
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
For the root Pi user (if running the GUI with "sudo startx" for instance when running apps that access the IO pins):
sudo nano /root/.config/lxsession/LXDE-pi/autostart
If the above doesn't work, then there is not a per user file so edit the global one Tellthebell.com:
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
klricks
Thu Jun 20, 2019 12:35 pm
If the above doesn't work, then there is not a per user file so edit the global one:
There is no reason to sudo startx not even for GPIO access. Doing so could result in a broken desktop.
Return to “Beginners”
