mcgyver83
unrar spanned archive
Tue Sep 24, 2013 6:05 am
Hi!
I have a spanned archive set (part1.rar, part2.rar .... etc) and I need to unrar it via command line.
I tried
unrar e a.part1.rar
unrar e a.part1.rar a.part2.rar
but I still have the same error:
unrar 0.0.1  Copyright (C) 2004  Ben Asselstine, Jeroen Dekkers
Extracting from /media/ScreenPlayHD/a.part1.rar
Extracting  a.txt                                              Failed
1 Failed
Everything is fine with single rar file or if I try to unrar the same spanned archive from windows.
Same error if I use Xarchive from LXDE.
mcgyver83
Re: unrar spanned archive
Wed Sep 25, 2013 11:53 am
No one? :roll:
RaTTuS
Contact: Twitter YouTube
Wed Sep 25, 2013 12:32 pm
umm at a guess they are named wrong
should they not be something like
file.rar
file.part2
file.part3
then you
unrar e file
it will find the other parts then
Covfefe
mcgyver83
Wed Sep 25, 2013 1:07 pm
On windows I can unrar them as they are now, a.rar, a.part1.rar, a.part2.rar ..
You are suggesting to rename them in a.part1, a.part2 removing rar suffix?
RaTTuS
Wed Sep 25, 2013 1:43 pm
yeah try it and see
I never use rar these days myself
Covfefe
mcgyver83
Wed Sep 25, 2013 4:27 pm
I had
a.part1.rar,
a.part2.rar,
a.part3.rar.
Unrar e a.part1.rar
failed.
Unrar e a.part1.rar a.part2.rar a.part3.rar
failed.
Renamed to
a.part1,
a.part2,
a.part3
Unrar e a.part1
failed.
Unrar e a.part1 a.part2 a.part3
failed.
Error:
Extracting p.iso Failed
1 Failed
mcgyver83
Thu Oct 10, 2013 6:36 am
I still have the same problem.
Can someone suggest me another utility to unrar spanned archive?
mcgyver83
Mon Nov 04, 2013 10:30 pm
none can help me?
suchenwi
Mon Nov 04, 2013 10:52 pm
As RaTTuS wrote on Sep.23, the files should be named
x.rar
x.part2
x.part3
Have you tried that?
jojopi
Mon Nov 04, 2013 11:42 pm
suchenwi wrote:As RaTTuS wrote on Sep.23, the files should be named
x.rar
x.part2
x.part3
No, they are named correctly. They can be either .partN.rar, or old-style: .rar .r00 .r01…
The problem is that the unrar implementation in package unrar-free does not support multipart archives. http://gna.org/bugs/?723
The "proper" versions of rar/unrar are not free software and presumably are not available for ARMv6 with hard float ABI. It may be possible to compile unrar (but not rar) yourself from source. http://www.rarlab.com/rar_add.htm
A better option is to stop using rar. It is very slow and does not have particularly good compression.
mcgyver83
Tue Nov 05, 2013 7:36 am
Is the compile an hard job?
I'm e rookie on linux compilation stuff.
In the link you provided I found 2 interesting archive:
UnRAR for ARM Linux Command line freeware ARMEL v4 Linux UnRAR.
UnRAR for ARM Linux Command line freeware ARM Linux UnRAR.
Which one I have to download and compile?
There is any way to join the partN.rar files to have big rar file and use unrar-free with it?
RaTTuS
Tue Nov 05, 2013 9:40 am
personally,
I'd unrar them on a PC then re zip them with anything else [or not and just move them whole]
rar is slow , proprietary , not very good and a lot of other things that I will not mention on a family friendly forum [FFF]
http://www.rarlab.com/rar/unrarsrc-5.0.12.tar.gz <- is probably the place you want to start
Covfefe
mcgyver83
Tue Nov 05, 2013 1:03 pm
Thanks.
I'll check you link.
Regards
Joe Schmoe
Tue Nov 05, 2013 1:23 pm
I know the goal is to "solve the problem" and not get waylaid into "side meta", but, just out of curiosity (seriously!), I think many of would like to know why it is that you need to use RAR.
Is this a one-time deal, or is it part of an on-going process?
Is there any reason why you couldn't just unrar it on a PC (and be done with this task) ?
(I assume that size is an issue - given that the thing is a multi-part archive - but still, the question remains...)
Joe Schmoe
Tue Nov 05, 2013 1:25 pm
I should add to the previous that (given what little I know about RAR, having never used it, just read about it), the primary attraction of RAR is the ability to run scripts and stuff as part of the unpacking process (i.e., it is more of an installer than just a mere archiver), but the funny thing about this, of course, is that that functionality be turned off (disabled) in a non-Windows version [*].
[*] For "security reasons" ...
mcgyver83
Thu Nov 07, 2013 11:53 am
I usually receive rar files so I have to deal with them and I cannot choose the packing algorithm.
I'm not moving file to the pc because it will take a while copying them via samba (raspberry is connect via wifi dongle to the network).
Joe Schmoe
Thu Nov 07, 2013 2:16 pm
mcgyver83 wrote:I usually receive rar files so I have to deal with them and I cannot choose the packing algorithm.
OK - that all makes sense. The key being that it is *not* a "one-time deal".
mcgyver83
Fri Nov 08, 2013 8:55 am
unfortunately no :?
Ok, I'll try compiling winrar sources.
mcgyver83
Mon Nov 11, 2013 9:42 pm
x.rar
x.part2
x.part3
I'm trying to compile from the sources suggested by Rattus, http://www.rarlab.com/rar/unrarsrc-5.0.12.tar.gz
I extracted the sources, run "make".... after how can I install compiled software and delete sources?
Sorry but it's the first compile I made
