oranda
Re: Mac VMWare Fusion & Rapberry Pi
Fri Mar 09, 2012 11:33 pm
Is it possible to run a emulated Raspberry Pi within VMWare Fusion on a iMac?
If so, how?
If not, how else could it be done?
oninoshiko
Fri Mar 09, 2012 11:39 pm
VMWare does not (AFAIK) emulate an ARM. You will have to do one of two things:
run a linux distro with qemu-arm on vmware (I think someone has a setup already configured for vmware, does fusion use VMWare workstation images?)
get a copy of qemu-arm for MacOS
nick.mccloud
Sat Mar 10, 2012 7:23 am
Yes it is, I've done it.
See http://www.raspberrypi.org/forum/projec ... oremulator
AlArenal
Sat Mar 10, 2012 8:27 am
It's easier, though, todirectly run qemu on the Mac.
1. Download / install Apple's Xcode. It's freely available in the Mac App Store. If your system is too old and not supported by App Store, download the appropriate Xcode version for your Mac OS X on http://connect.apple.com/ . Registration there is free, you only need your Apple ID.
2. Install the appropriate version of Mac Ports from http://www.macports.org/install.php on your Mac.
3. Open a terminal and type
sudo port install qemu +target_arm
It's gonna install qemu with the arm emulator.
4. You can now use the qemu based packages floating around here in the forums
emceeMC
Mon Sep 23, 2019 7:54 pm
That link is dead :(
Tue Sep 24, 2019 9:21 am
Not surprising, it's 7 years old!! I think you might win the oldest necro award with this one. I'd suggest Google for more information on this one.
