ame
Re: Keypad on Rpi using Pi4J
Wed Dec 02, 2015 5:13 am
mythbuster wrote:
raspdroid wrote:I take other way. Based on the logic of library for Python by Chris Crumpacker.
https://pypi.python.org/pypi/matrix_keypad
This is the code, works fine :D
http://pastebin.com/21edWhGS
Thank very much for the help.
King regards
I tried the code, but got an error on this line:
        theRows[rowVal].setMode(PinMode.DIGITAL_OUTPUT);
Wonder what the problem is? Thanks.
I also tried all the code in this thread, but no luck on any of them. Can anyone provide some further information regarding this? Maybe some project source that shows the classes in action? I am not sure how to integrate the code into my project.
Thanks for any help!
Jim
Usually the error message contains enough information to figure out the problem. Please post the error message.
mythbuster
Wed Dec 02, 2015 3:30 pm
It is an ArrayIndexOutOfBoundException.
When I try the other codes in this thread it simply exits or does not get any response.
Jim[/quote]
Usually the error message contains enough information to figure out the problem. Please post the error message.[/quote]
ame
Wed Dec 02, 2015 10:47 pm
So, what is rowVal? It's probably larger than the size of theRows, or you have an off-by-one error.
mailboarder
Fri Jan 11, 2019 11:09 pm
Hi Guys,
For my project I would like also to use the 4x4 Matrix Numpad in Java. Unfortunately I can not continue in some places. Maybe one of you can help me. My first question would be how can I insert a test program in my main class to watch in the output which button I'm currently pressing? And secondly, I get the following error message while running and unfortunately can not interpret it. For info: I use IntelliJ IDEA. I can also give more information. Hope you can help me and sorry for my poor English.
Here my main code:
package de.numpad;
public class Main {
    public static void main(String[] args){
while (true){
KeypadTest num = new KeypadTest();
    System.out.println(num.toString());
and the Keypad code:
package de.numpad;
import com.pi4j.io.gpio.GpioController;
import com.pi4j.io.gpio.GpioFactory;
import com.pi4j.io.gpio.GpioPinDigitalInput;
import com.pi4j.io.gpio.GpioPinDigitalOutput;
import com.pi4j.io.gpio.Pin;
import com.pi4j.io.gpio.PinPullResistance;
import com.pi4j.io.gpio.PinState;
import com.pi4j.io.gpio.RaspiPin;
import com.pi4j.io.gpio.event.GpioPinDigitalStateChangeEvent;
import com.pi4j.io.gpio.event.GpioPinListenerDigital;
import java.beans.PropertyChangeEvent;
import java.beans.PropertyChangeListener;
import java.util.ArrayList;
import java.util.List;
public class KeypadTest {
    private List<PropertyChangeListener> listener = new ArrayList<PropertyChangeListener>();
    public static final String KEY = "key";
    private char keyPressed;
    /** The Constant KEYPAD. */
    private static final char keypad[][] = { { '1', '2', '3', 'A' },
            { '4', '5', '6', 'B' }, { '7', '8', '9', 'C' },
            { '*', '0', '#', 'D' } };
    /** The gpio. */
    private final GpioController theGpio = GpioFactory.getInstance();
    /** The Constant PIN_1_IN. */
    private static final Pin PIN_1_IN = RaspiPin.GPIO_07;
    /** The Constant PIN_2_IN. */
    private static final Pin PIN_2_IN = RaspiPin.GPIO_00;
    /** The Constant PIN_3_IN. */
    private static final Pin PIN_3_IN = RaspiPin.GPIO_02;
    /** The Constant PIN_4_IN. */
    private static final Pin PIN_4_IN = RaspiPin.GPIO_03;
    /** The Constant PIN_5_OUT. */
    private static final Pin PIN_5_OUT = RaspiPin.GPIO_01;
    /** The Constant PIN_6_OUT. */
    private static final Pin PIN_6_OUT = RaspiPin.GPIO_04;
    /** The Constant PIN_7_OUT. */
    private static final Pin PIN_7_OUT = RaspiPin.GPIO_05;
    /** The Constant PIN_8_OUT. */
    private static final Pin PIN_8_OUT = RaspiPin.GPIO_06;
    /** The pin1. */
    private final GpioPinDigitalInput thePin1 = theGpio
            .provisionDigitalInputPin(PIN_1_IN, PinPullResistance.PULL_UP);
    /** The pin2. */
    private final GpioPinDigitalInput thePin2 = theGpio
            .provisionDigitalInputPin(PIN_2_IN, PinPullResistance.PULL_UP);
    /** The pin3. */
    private final GpioPinDigitalInput thePin3 = theGpio
            .provisionDigitalInputPin(PIN_3_IN, PinPullResistance.PULL_UP);
    /** The pin4. */
    private final GpioPinDigitalInput thePin4 = theGpio
            .provisionDigitalInputPin(PIN_4_IN, PinPullResistance.PULL_UP);
    /** The pin5. */
    private final GpioPinDigitalOutput thePin5 = theGpio
            .provisionDigitalOutputPin(PIN_5_OUT);
    /** The pin6. */
    private final GpioPinDigitalOutput thePin6 = theGpio
            .provisionDigitalOutputPin(PIN_6_OUT);
    /** The pin7. */
    private final GpioPinDigitalOutput thePin7 = theGpio
            .provisionDigitalOutputPin(PIN_7_OUT);
    /** The pin8. */
    private final GpioPinDigitalOutput thePin8 = theGpio
            .provisionDigitalOutputPin(PIN_8_OUT);
    /** The outputs. */
    private final GpioPinDigitalOutput theOutputs[] = { thePin5, thePin6,
            thePin7, thePin8 };
    /** The input. */
    private GpioPinDigitalInput theInput;
    /** The in id. */
    private int theLin;
    /** The in id. */
    private int theCol;
     * Instantiates a new piezo keypad.
    public KeypadTest() {
        initListeners();
     * Find output.
     * Sets output lines to high and then to low one by one. Then the input line
     * is tested. If its state is low, we have the right output line and
     * therefore a mapping to a key on the keypad.
    private void findOutput() {
        // now test the inuts by setting the outputs from high to low
        // one by one
        for (int myO = 0; myO < theOutputs.length; myO++) {
            for (final GpioPinDigitalOutput myTheOutput : theOutputs) {
                myTheOutput.high();
            theOutputs[myO].low();
            // input found?
            if (theInput.isLow()) {
                theCol = myO;
                checkPins();
                try {
                    Thread.sleep(200);
                } catch (InterruptedException e) {
                break;
            myTheOutput.low();
     * Check pins.
     * Determins the pressed key based on the activated GPIO pins.
    private synchronized void checkPins() {
        notifyListeners(this, KEY, this.keyPressed,
                this.keyPressed = keypad[theLin - 1][theCol]);
        // System.out.println(keypad[theLin - 1][theCol]);
     * Inits the listeners.
    private void initListeners() {
        thePin1.addListener(new GpioPinListenerDigital() {
            @Override
            public void handleGpioPinDigitalStateChangeEvent(
                    final GpioPinDigitalStateChangeEvent aEvent) {
                if (aEvent.getState() == PinState.LOW) {
                    theInput = thePin1;
                    theLin = 1;
                    findOutput();
        thePin2.addListener(new GpioPinListenerDigital() {
            @Override
                    theInput = thePin2;
                    theLin = 2;
                    findOutput();
        thePin3.addListener(new GpioPinListenerDigital() {
            @Override
                    theInput = thePin3;
                    theLin = 3;
                    findOutput();
        thePin4.addListener(new GpioPinListenerDigital() {
            @Override
                    theInput = thePin4;
                    theLin = 4;
                    findOutput();
    private void notifyListeners(Object object, String property, char oldValue,
                                 char newValue) {
        for (PropertyChangeListener name : listener) {
            name.propertyChange(new PropertyChangeEvent(this, property,
                    oldValue, newValue));
    public void addChangeListener(PropertyChangeListener newListener) {
        listener.add(newListener);
King regards
Return to “Java”
