vector
Perl 5.8.3 or later and perl modules?
Mon Jan 28, 2013 4:17 am
does anybody know how I can get on my pi perl 5.8.3 or later and perl modules? :?
Re: Perl 5.8.3 or later and perl modules?
Mon Jan 28, 2013 4:48 am
You haven't said which Operating System version you are using.
If you have installed the Raspbian version, you should have perl and perl-modules 5.14 already installed.
You can check this in a terminal with "dpkg -l perl perl-modules" (That's a lower-case "L", not a capital "i" or number "1")
My system reports
pi@raspi:~$ dpkg -l perl perl-modules
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name               Version        Architecture   Description
ii  perl               5.14.2-16+rpi1 armhf          Larry Wall's Practical Extraction and Rep
ii  perl-modules       5.14.2-16+rpi1 all            Core Perl modules
pi@raspi:~$
vector
Tue Jan 29, 2013 1:15 am
What about Perl 5.8.3 higher?
jojopi
Tue Jan 29, 2013 3:19 am
In case it is not obvious, five.fourteen.two is higher than five.eight.three. In fact, 5.8.3 is a rather old version, released in January 2004.
Perhaps it would be better to explain what you are trying to do, and how it is not working.
technion
Sun Feb 10, 2013 4:26 am
vector wrote:What about Perl 5.8.3 higher?
The CentOS 5 (with their reputation of being behind versions on everything) server I built roughly two years ago is running a more recent version than that. You would struggle to find something lower.
