plugwash
STICKY: status of java on raspbian.
Tue Jan 01, 2013 1:36 am
There are now quite a few Java options for Raspbian so I thought I'd summarise them to help the confused newcomers decide which VM is for them.
Oracle JDK7
Pros: fast, full-featured
Cons: non-FOSS, free to use for "desktop"/"server" use but requires separate licensing for embedded use.
Notes: included by default in recent versions of the Raspberry Pi Foundation Raspbian image.
Package name: oracle-java7-jdk (note: package is in Raspberry Pi Foundation repo, not the Raspbian repo)
Zero
Pros: full-featured, FOSS
Cons: slow
Notes: default VM in Raspbian OpenJDK packages.
Package name for OpenJDK7: openjdk-7-jre
Package name for OpenJDK6: openjdk-6-jre
JamVM
Pros: faster than Zero, free, seems mature, FOSS
Cons: slower in my test than Avian and Oracle. Lacks support for agents
Package name for OpenJDK7: icedtea-7-jre-jamvm
Package name for OpenJDK6: icedtea-7-jre-jamvm
Avian
Pros: faster than JamVM in my test, FOSS.
Cons: seems very new, not available for openjdk-6, didn't seem to be as fast as Oracle VM in my test.
Package name for OpenJDK7: jvm-7-avian-jre
JDK 8 (with JavaFX) for ARM Early Access
Pros: seems to be the fastest option, supplied class libraries include accelerated JavaFX implementation.
Cons: proprietary, doesn't appear to be re-distributable, still pre-release, supplied class libraries are JDK8-based and don't include AWT/Swing (though apparently the Oracle embedded VM can be used with the class libraries from Raspbian OpenJDK to get AWT/Swing support).
Forum thread: http://www.raspberrypi.org/phpBB3/viewt ... 81&t=26110
The default VM for OpenJDK7 on Raspbian can be changed by editing /etc/java-7-openjdk/jvm-armhf.cfg. Presumably a similar config file exists for OpenJDK6 but I haven't checked myself.
edit: incorporated some of hendrik's fixes
edit2: add package name for avian, pointed out as missing by xranby
edit3: add mention of oracle java 7 packages.
henrik
Re: status of java on raspbian.
Tue Jan 01, 2013 6:24 am
oracle embedded JRE preview
pros: seems to be the fastest option, supplied class libraries include accelerated javafx implementation.
cons: propietary, doesn't appear to be redistributable, still prerelease, supplied class libraries are jdk8 based and don't include AWT/swing (though apparently the oracle embedded vm can be used with the class libraries from raspbian openjdk to get AWT/swing support).
forum thread: viewtopic.php?f=81&t=26110
That should be "Oracle JDK 8 preview for Linux/ARM". Our Java SE Embedded products (that you call the embedded JRE) is a commercial variant optimized for low memory footprint.
A few clarifications:
- All implementations use the OpenJDK class libraries, but with different VMs
- OpenJDK is developed by Oracle and other members of the OpenJDK community
- The Oracle JDK is based on OpenJDK, adding a few features that we either don't have the right to open source or that we keep closed for commercial reasons. For now that includes our ARM port of Hotspot, which is highly optimized.
- Oracle JDK binaries undergo extensive testing and are likely the highest quality.
- Oracle JDK is free (as in beer) for most purposes including redistribution with applications, see the license agreement you click through to download JDK 7
- The Oracle JDK 8 preview is under an early access license with more reatrictions
- Using the Swing/AWT libraries from OpenJDK 7 or Oracle JDK 7 with the JDK 8 preview is unlikely to work moving forward, but you can always compile OpenJDK 8 (our binaries and the OpenJDK source are kept in sync)
- JavaFX is partially available open source in the OpenJFX project on java.net, and will be fully open sourced over the next few months (including the ARM port)
Henrik Ståhl
Sr. Director, Product Managament
Java Platform Group, Oracle
xranby
Wed Feb 06, 2013 12:40 pm
The new hardfloat fixed CACAO JVM found in the new IcedTea 6 1.12 release work well under Raspbian. We should focus on packaging it.
http://blog.fuseyism.com/index.php/2013 ... -released/
While i know that compilation can be tricky i have prepared a RaspberryPi armhf CACAO libjvm.so that you can use as an drop in replacement into any OpenJDK 6 installation (/usr/lib/jvm/java-6-openjdk-armhf/jre/lib/arm/server/libjvm.so) This libjvm.so was built using the icedtea6 1.12 release from inside a Raspbian chroot.
The cacao armhf libjvm.so is found here:
http://labb.zafena.se/cacao/armhf-armv6/libjvm.so
if you want to use it in combination with a icedtea 6 openjdk 6 install run:
sudo apt-get update
sudo apt-get install openjdk-6-jre
wget http://labb.zafena.se/cacao/armhf-armv6/libjvm.so
sudo cp libjvm.so /usr/lib/jvm/java-6-openjdk-armhf/jre/lib/arm/server/libjvm.so
sudo cp libjvm.so /usr/lib/jvm/java-6-openjdk-armhf/jre/lib/arm/cacao/libjvm.so
java -version
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
plugwash
Wed Feb 06, 2013 1:57 pm
xranby wrote:The new hardfloat fixed CACAO JVM found in the new IcedTea 6 1.12 release work well under Raspbian. We should focus on packaging it.
Looks like debian already did http://packages.qa.debian.org/o/openjdk ... 4840Z.html
I'll take a closer look when I get some time.
Does this version also contain the fixed jamvm?
xranby
Wed Feb 06, 2013 2:19 pm
Yes both the armhf JamVM and the armhf CACAO are included in this new major 6 release.
Its mentioned in the release log: http://blog.fuseyism.com/index.php/2013 ... -released/
twitter.com/xranby
plugwash
Wed Feb 06, 2013 6:30 pm
I have split the posts about removing java and java security into their own thread. Please direct all discussion of that issue there not here.
plugwash
Wed Feb 06, 2013 8:30 pm
xranby wrote: Yes both the armhf JamVM and the armhf CACAO are included in this new major 6 release.
Unfortunately it seems the new version failed to build on both armel and armhf in debian with different failures. Any thoughts? (i'm trying a build on raspbian anyway but I wouldn't be surprised if it fails too
armel:
libtool: compile: arm-linux-gnueabi-gcc -DHAVE_CONFIG_H -I. -I../../../.. -I../../../../src -I../../../.. -I../../../../src -I/build/buildd-openjdk-6_6b27-1.12-1-armel-d7BDV2/openjdk-6-6b27-1.12/build/openjdk/jdk/src/solaris/javavm/export -I/build/buildd-openjdk-6_6b27-1.12-1-armel-d7BDV2/openjdk-6-6b27-1.12/build/openjdk/jdk/src/share/javavm/export -I/build/buildd-openjdk-6_6b27-1.12-1-armel-d7BDV2/openjdk-6-6b27-1.12/build/openjdk/jdk/src/solaris/javavm/export -I/build/buildd-openjdk-6_6b27-1.12-1-armel-d7BDV2/openjdk-6-6b27-1.12/build/openjdk/jdk/src/solaris/hpi/export -I/build/buildd-openjdk-6_6b27-1.12-1-armel-d7BDV2/openjdk-6-6b27-1.12/build/openjdk/jdk/src/share/hpi/export -I../../../../src -I../../../.. -I../../../../src -g -O2 -fno-strict-aliasing -D__ARM__ -D__LINUX__ -D_POSIX_C_SOURCE=200112L -D_XOPEN_SOURCE=600 -D_XOPEN_SOURCE_EXTENDED -D_BSD_SOURCE -std=c99 -pedantic -Wall -Wno-long-long -MT asmpart.lo -MD -MP -MF .deps/asmpart.Tpo -c asmpart.S -fPIC -DPIC -o .libs/asmpart.o
asmpart.S: Assembler messages:
asmpart.S:242: Error: selected processor does not support ARM mode `blx exceptions_asm_new_abstractmethoderror'
make[7]: *** [asmpart.lo] Error 1
armhf:
make[1]: Entering directory `/build/buildd-openjdk-6_6b27-1.12-1-armhf-y7c3I9/openjdk-6-6b27-1.12/build'
if [ -e /build/buildd-openjdk-6_6b27-1.12-1-armhf-y7c3I9/openjdk-6-6b27-1.12/build/openjdk.build-ecj/j2sdk-image/bin/java ] ; then \
/build/buildd-openjdk-6_6b27-1.12-1-armhf-y7c3I9/openjdk-6-6b27-1.12/build/openjdk.build-ecj/j2sdk-image/bin/java -Xshare:dump ; \
fi
Loading classes to share ... #
# A fatal error has been detected by the Java Runtime Environment:
# Internal Error (os_linux_zero.cpp:270), pid=2433, tid=1090061424
# fatal error: caught unhandled signal 11
# JRE version: 6.0_27-b27
# Java VM: OpenJDK Zero VM (20.0-b12 interpreted mode linux-arm )
# Derivative: IcedTea6 1.12.0
# Distribution: Debian GNU/Linux unstable (sid), package 6b27-1.12-1
# An error report file with more information is saved as:
# /build/buildd-openjdk-6_6b27-1.12-1-armhf-y7c3I9/openjdk-6-6b27-1.12/build/hs_err_pid2433.log
# If you would like to submit a bug report, please include
# instructions how to reproduce the bug and visit:
# http://icedtea.classpath.org/bugzilla
/bin/bash: line 2: 2433 Aborted /build/buildd-openjdk-6_6b27-1.12-1-armhf-y7c3I9/openjdk-6-6b27-1.12/build/openjdk.build-ecj/j2sdk-image/bin/java -Xshare:dump
make[1]: *** [stamps/add-archive-ecj.stamp] Error 134
xranby
Wed Feb 06, 2013 8:56 pm
armel:
Was this reported from the official armel Debian builders?
having access to the /build/buildd-openjdk-6_6b27-1.12-1-armhf-y7c3I9/openjdk-6-6b27-1.12/build/hs_err_pid2433.log do help if possible.
So this looks like an internal crash inside the ARM32 assembler interpreter port that is an extension on top of zero for ARM OR the generic OpenJDK zero vm (they both use unfortunately the same version number string when run on hardware without Thumb2). These bugs are hard to track down, usually happens inside the 10K line handwritten ARM assembler interpreter addon for Zero.
If the bug is persistent then A) try switch the default JVM powering OpenJDK6 used by the buildd to JamVM.
(edit /etc/java-6-openjdk/jvm-armhf.cfg on the builder and make sure
-jamvm KNOWN
is on the top)
or B) disable zero for the build edit the debian rules for armel and armhf and make jamvm the default jvm. it might be a problem with Zero for the 6 1.12 release because Oracle do not test Zero at all, for what I know, in OpenJDK upstream and the IcedTea release team only got limited testing of zero on different platforms. So the safest bet is to disable Zero.
All in all I will try reproduce and if I can reproduce it then file a bugreport with the IcedTea team.
twitter.com/xranby
plugwash
Thu Feb 07, 2013 4:08 am
The "# A fatal error has been detected by the Java Runtime Environment:" was from debian armhf, build log at https://buildd.debian.org/status/fetch. ... 1359686380
I've just confirmed that raspbian fails in the same way as debian armhf. The error log file is at http://plugwash.raspbian.org/hs_err_pid ... spbian.log
I'll be fililng a bug report with debian once i've reproduced the bug on it and got the errror log file.
plugwash
Thu Feb 07, 2013 4:34 am
Looks like 1.12.1 just hit sid, waiting to see if that fails too.
xranby
Thu Feb 07, 2013 12:31 pm
plugwash wrote:Looks like 1.12.1 just hit sid, waiting to see if that fails too.
looks promising:
https://buildd.debian.org/status/packag ... =openjdk-6 Debian armhf build sucess using IcedTea6 1.12.1
armel still fail to build because Debian soft-float armel target armv4t while the CACAO assembler part of the code used a BLX armv5+ instruction. This is easily fixed the key is to replace the
BLX ...
with a
mov PC, LR
BX ...
instruction pair, BLX is only a compact assembler instruction found in armv5 and later to do a backup of the PC register into the LR and branch using the same instruction. This needs to be fixed with cacao upstream. And nothing for Raspbian to worry about since we target armv6 that include BLX!
make[7]: Entering directory `/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/cacao/cacao-68fe50ac34ec/src/vm/jit/arm'
/bin/bash ../../../../libtool   --mode=compile arm-linux-gnueabi-gcc -DHAVE_CONFIG_H -I. -I../../../..  -I../../../../src -I../../../.. -I../../../../src -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/solaris/javavm/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/share/javavm/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/solaris/javavm/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/solaris/hpi/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/share/hpi/export -I../../../../src -I../../../.. -I../../../../src -g -O2 -fno-strict-aliasing -D__ARM__ -D__LINUX__ -D_POSIX_C_SOURCE=200112L -D_XOPEN_SOURCE=600 -D_XOPEN_SOURCE_EXTENDED -D_BSD_SOURCE -std=c99 -pedantic -Wall -Wno-long-long  -MT asmpart.lo -MD -MP -MF .deps/asmpart.Tpo -c -o asmpart.lo asmpart.S
/bin/bash ../../../../libtool --tag=CC   --mode=compile arm-linux-gnueabi-gcc -DHAVE_CONFIG_H -I. -I../../../..  -I../../../../src -I../../../.. -I../../../../src -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/solaris/javavm/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/share/javavm/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/solaris/javavm/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/solaris/hpi/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/share/hpi/export -std=c99 -pedantic -Wall -Wno-long-long  -D__ARM__ -D__LINUX__ -D_POSIX_C_SOURCE=200112L -D_XOPEN_SOURCE=600 -D_XOPEN_SOURCE_EXTENDED -D_BSD_SOURCE -D_REENTRANT -g -O2 -fno-strict-aliasing -MT emit.lo -MD -MP -MF .deps/emit.Tpo -c -o emit.lo emit.c
libtool: compile:  arm-linux-gnueabi-gcc -DHAVE_CONFIG_H -I. -I../../../.. -I../../../../src -I../../../.. -I../../../../src -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/solaris/javavm/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/share/javavm/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/solaris/javavm/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/solaris/hpi/export -I/build/buildd-openjdk-6_6b27-1.12.1-1-armel-MmogaA/openjdk-6-6b27-1.12.1/build/openjdk/jdk/src/share/hpi/export -I../../../../src -I../../../.. -I../../../../src -g -O2 -fno-strict-aliasing -D__ARM__ -D__LINUX__ -D_POSIX_C_SOURCE=200112L -D_XOPEN_SOURCE=600 -D_XOPEN_SOURCE_EXTENDED -D_BSD_SOURCE -std=c99 -pedantic -Wall -Wno-long-long -MT asmpart.lo -MD -MP -MF .deps/asmpart.Tpo -c asmpart.S  -fPIC -DPIC -o .libs/asmpart.o
twitter.com/xranby
plugwash
Thu Feb 07, 2013 10:41 pm
xranby wrote:This needs to be fixed with cacao upstream. And nothing for Raspbian to worry about
While it's not directly relavent to raspbian having the package stay in good shape on debian armel is probablly a good thing for us.
I may try and whip up a patch, is there a preferred way of selecting arm version specific code within the cacao codebase?
Getting back onto the subject of raspbian i've just built the new openjdk-6 successfully for raspbian. I will then run some basic tests.
Do you have any information on pros/cons of cacao vs zero, jamvm and avian?
Note: since this discussion is getting a bit long I may split it off into it's own thread later, please don't take offense if I do.
plugwash
Fri Feb 08, 2013 12:11 pm
Ok the new version of openjdk-6 including a working cacao is now in raspbian.
xranby
Wed May 29, 2013 11:19 am
JDK 7 Update 40 Early Access Release Build b26 May 23, 2013 with ARM hard-float support is now available under the Pre-Release Software Evaluation Agreement license.
https://jdk7.java.net/download.html
This EA build is based on the OpenJDK 7 jdk7u project source + Oracle's closed source ARM JIT that will become the next general avail, GA, release at the end of August 2013:
http://openjdk.java.net/projects/jdk7u/ ... /7u40.html
twitter.com/xranby
xranby
Mon Jun 17, 2013 5:07 pm
In-order to use the alternative JVMs such as JamVM, CACAO and Avian in combination with OpenJDK pass the jvm name as the first argument on the command line to java; example:
java -jamvm -version
java -cacao -version
java -avian -version
You can set the default to use for OpenJDK 6 by editing the
/etc/java-6-openjdk-armhf/jvm-armhf.cfg
You can set the default to use for OpenJDK 7 by editing the
/etc/java-7-openjdk-armhf/jvm-armhf.cfg
The alternative OpenJDK JVM are installed under /usr/lib/jvm/java-7-openjdk-armhf/jre/lib/arm under a folder named after the respective alternative JVM. The jre/lib/jvm.cfg tells the OpenJDK installation which folders are valid JVM names.
twitter.com/xranby
henrik
Wed Sep 11, 2013 12:36 am
Oracle JDK 7 with hardfloat support (for Raspbian) is now GA, available here:
http://www.oracle.com/technetwork/java/ ... index.html
Henrik (Oracle Java team)
plugwash
Wed Sep 11, 2013 10:09 am
hmm, in the list of downloads I see an "armv7" hard float abi and an "armv6/armv7" soft float abi but no armv6 hard float abi version.
henrik
Wed Sep 11, 2013 2:48 pm
Docs error, will fix. Should be ARMv6/7.
mcgyver83
Fri Oct 11, 2013 2:30 pm
I installed oracle jdk 8 to use hardfloat.
Now I red on the rpi site that jdk 7 is now ready for arm with hardfloat.
I follwed the instructions on the site, sudo apt-get install oracle-java7-jdk but the jdk8 is still
alive.
How can I un'install it?
freedomotic
Fri Nov 15, 2013 11:11 am
Hi all,
a quick question: is the jdk version in raspbian (last available image) hardfloat?
Freedomotic Open IoT Framework
http://freedomotic.com
xranby
Fri Nov 15, 2013 11:17 am
freedomotic wrote:Hi all,
Yes
(all raspbian images are using the hardfloat ABI, and the JVM is using the hardfloat ABI)
twitter.com/xranby
mcgyver83
Fri Nov 15, 2013 12:55 pm
So which JVM is suggested as faster on the rasp?
xranby
Fri Nov 15, 2013 1:58 pm
mcgyver83 wrote:So which JVM is suggested as faster on the rasp?
If you design a graphical application then the most important choice on the Raspberry Pi is to pick an API that can take advantage of the Broadcom VideoCore GPU graphics processor.
The PI CPU runs at 175MFlops while the GPU runs at: 2600MFlops thus picking the right API makes up to 15 times performance difference! Also the JVM running on the CPU will handle events such as input better if all graphics rendering is offloaded to the GPU.
http://elinux.org/Raspberry_Pi_VideoCore_APIs
The fastest closed source JVM is Oracles JDK7 & JDK 8 Hotspot JVM.
The fastest Open Source JVM are:
JamVM for OpenJDK 8.
Cacao / Avian for OpenJDK 7.
The most stable Open Source JVM is all around JamVM.
Zero JVM is also stable although it is known to be quite slow on the Pi.
twitter.com/xranby
plugwash
Fri Nov 15, 2013 3:50 pm
Afaict the oracle VM is the fastest if you are prepared to accept it's license.
henrik
Fri Nov 15, 2013 4:51 pm
That sounds a bit scary scary, so let's be clear. It's the same "free-as-in-beer" license (for usage and redistribution for most use cases you can think of) that we use for desktop and normal server-side Java. No developer or hobbyist should be remotely concerned about accepting it.
Full text (long because it allows you a lot of freedoms):
Previous discussion in this forum:
http://www.raspberrypi.org/phpBB3/viewt ... p?p=401112
http://www.raspberrypi.org/phpBB3/viewt ... p?p=236983
FAQ on the original (soft float) Oracle JDK for ARM:
https://blogs.oracle.com/henrik/entry/o ... _for_linux
Relevant text from FAQ:
Is the ARM JDK free (gratis) or does it require a commercial license?
"Like all general-purpose JDK and JRE binaries, the ARM JDK is free for development and production use on general-purpose hardware, and can be redistributed for free with applications targeting a general-purpose computer. See the end-user license for the exact license grants & restrictions. To take a couple of examples, an ARM server deployed in your datacenter running Tomcat or Glassfish is general-purpose, as is a Raspberry Pi board when you use it like a PC. An industrial controller or a kiosk appliance is not general purpose, and both would require a commercial license."
Henrik Stahl, VP Product Management, Java, Oracle
Return to “Java”
