vale
Pi 4 not booting if hdmi cable plugged
Sun Jan 19, 2020 7:53 pm
Hello!
I used Raspberries pi 3 since few years without particular issue. I recently bougth à 4 version and i've a problem with hdmi.
When i start the pi, red ligth is on, the green ligth blink and after 1 or 2 seconds, only the red ligth is on. If i unplug my hdmi tv screen, the boot sequence seems to restart and after few seconds i'm able ton connect with vnc or i can re-plug the hdmi and it's working.
if i boot whitout hdmi cable, the pi is booting normaly and i can connect via vnc or plug the hdmi cable.
That"s weird!! I read many things and tried various things without success:
hdmi_safe=1 => seems to boot but few second later got a black screen with a static _ in the top left corner
hdmi_force_hotplug=1 => same issue
hdmi_group=1 + hdmi_mode=31 => not working at all
config_hdmi_boost=9 => same issue
I also tried without success with a config.txt from my pi 3 that was working on the tv...
I'am using the last raspbian image and everithing is up to date.
Not sure if it's related, but i also can't use my tv remote with kodi although that the cec plugin is activated...
Could someone help me?!
Thanks!!
vale
Re: Pi 4 not booting if hdmi cable plugged
Mon Jan 27, 2020 7:35 pm
A few days after my first post, I could not start, even by disconnecting the HDMI.
Finally, I bought a new pi card from Amazon and it worked out of the box. So the first one bought on Aliexpress is just shit ... :( Waiting for a refund .....
