giovangiuseppe
SSH not work with Wi-Fi
Thu Jan 16, 2020 1:44 pm
Hi I'm Italian and sorry for my bad English, I have a problem with raspbian.
I connected my raspberry to Wi-Fi, but I can no longer connect, via SSH to the raspberry, if I am connected via Lan everything works.
I tried to set a static IP, but nothing has changed, I searched in various forums including this one and found this "article": [url] https://www.raspberrypi.org/forums/viewtopic.php?f = 28 & t = 138631 [/ url]
Advice? Do I send you my configurations?
Maze_fr
Re: SSH not work with Wi-Fi
Thu Jan 16, 2020 2:50 pm
Wifi 5G o wifi 2.4G ? RPi 0 / 2 / 3 / 4 ?
Col RPi 4 :
C'è un problema con il 2.4G quando c'è un USB3 HDD/SDD collegato.
Per utilizzare il 5G, devi scegliere il paese con raspi-config.
Edit : in english...
Wifi 5G or wifi 2.4G ? RPi 0 / 2 / 3 / 4 ?
With RPi 4 :
There's a problem the 2.4G when there's a plugged USB3 HDD/SDD.
In order to use the 5G, you must choose the country with raspi-config.
"Don't believe in forum signature quotations, they may be fakes" - Victor Hugo
DirkS
Thu Jan 16, 2020 3:09 pm
Col RPi 4 :
This is the English section of the forum, so please respond in English
giovangiuseppe
Thu Jan 16, 2020 5:48 pm
Col RPi 4 :
With RPi 4 :
I use a raspberry pi 3B+, wi-fi 2.4G and i choose the country with raspi-config
giovangiuseppe
Thu Jan 16, 2020 5:52 pm
This is my configuration
DHCPCD file
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# Most distributions have NTP support.
#option ntp_servers
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
# OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
# Example static IP configuration:
# interface eth0
# static ip_address=192.168.1.23/134
# static ip6_address=fd51:42f8:caae:d92e::ff/64
# static routers=192.168.1.1
# static domain_name_servers=192.168.1.1 8.8.8.8 fd51:42f8:caae:d92e::1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
# profile static_eth0
# fallback to static profile on eth0
# interface eth0
# fallback static_eth0
# 15 / 01 / 2020 raspberry.org/forums/viewtopic.php?t=157250
	 interface wlan0
	 inform 192.168.1.134
	 static domain_name_servers=8.8.8.8 8.8.4.4
wpa supplicant
ctrl_interface=/var/run/wpa_supplicant
# ctrl_interface_group=0
update_config=1
country=IT
network={
        ssid="Casa Di Iorio_EXT"
        psk="@(QwErTy)"
        proto=WPA2
interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
DirkS
Thu Jan 16, 2020 6:01 pm
Remove
and the 'proto' line from wpa_supplicant.conf and reboot
pi-anazazi
Thu Jan 16, 2020 6:07 pm
Casa di Iirio? Sounds nice!
https://www.booking.com/hotel/it/casa-d ... schia.html
Would you mind changing the password for your wifi after posting it here?
Kind regards
anazazi
giovangiuseppe
Thu Jan 16, 2020 6:33 pm
I know Ischia i love there but is not my house XD
giovangiuseppe
Thu Jan 16, 2020 7:08 pm
Remove
nothing has changed: c
