saxoalex
i2cdetect shows all addresses
Tue Jan 14, 2020 11:41 pm
Hi there,
I have some troubles with my raspberry pi 2 B+.
In fact, when I enter the command line 'i2cdetect -y 1' in the console, it shows all addresses, even if nothing is plug to I2C SDA and SCL.
I already followed this post : https://www.raspberrypi.org/forums/view ... hp?t=93222. I tried to put a brand new Raspbian without any new softwares. I have the same problem.
I looked for a short circuit between SDA and GND or SCL and GND with a multimeter, but there is no short circuit. All seems correct...
I don't know what to do. I think the problem is hardware.
Can you helm^p me please ?
Thank you.
joan
Re: i2cdetect shows all addresses
Wed Jan 15, 2020 2:58 am
SDA is probably shorted to ground.
Run gpiotest.
6by9
Wed Jan 15, 2020 8:52 pm
Or you've managed to set the pinmuxing so that two pins are configured to the same SDA function. Check GPIOs 44&45 via "raspi-gpio get".
saxoalex
Wed Jan 15, 2020 10:04 pm
I tested gpiotest :
And raspi-gpio get :
BANK0 (GPIO 0 to 27):
GPIO 0: level=1 fsel=0 func=INPUT
GPIO 1: level=1 fsel=0 func=INPUT
GPIO 2: level=0 fsel=4 alt=0 func=SDA1
GPIO 3: level=1 fsel=4 alt=0 func=SCL1
GPIO 4: level=0 fsel=0 func=INPUT
GPIO 5: level=0 fsel=0 func=INPUT
GPIO 6: level=0 fsel=0 func=INPUT
GPIO 7: level=0 fsel=0 func=INPUT
GPIO 8: level=0 fsel=0 func=INPUT
GPIO 9: level=0 fsel=0 func=INPUT
GPIO 10: level=0 fsel=0 func=INPUT
GPIO 11: level=0 fsel=0 func=INPUT
GPIO 12: level=0 fsel=0 func=INPUT
GPIO 13: level=0 fsel=0 func=INPUT
GPIO 14: level=1 fsel=4 alt=0 func=TXD0
GPIO 15: level=0 fsel=4 alt=0 func=RXD0
GPIO 16: level=0 fsel=0 func=INPUT
GPIO 17: level=0 fsel=0 func=INPUT
GPIO 18: level=0 fsel=0 func=INPUT
GPIO 19: level=0 fsel=0 func=INPUT
GPIO 20: level=0 fsel=0 func=INPUT
GPIO 21: level=0 fsel=0 func=INPUT
GPIO 22: level=0 fsel=0 func=INPUT
GPIO 23: level=0 fsel=0 func=INPUT
GPIO 24: level=0 fsel=0 func=INPUT
GPIO 25: level=0 fsel=0 func=INPUT
GPIO 26: level=0 fsel=0 func=INPUT
GPIO 27: level=0 fsel=0 func=INPUT
BANK1 (GPIO 28 to 45):
GPIO 28: level=1 fsel=0 func=INPUT
GPIO 29: level=1 fsel=0 func=INPUT
GPIO 30: level=0 fsel=0 func=INPUT
GPIO 31: level=1 fsel=1 func=OUTPUT
GPIO 32: level=0 fsel=1 func=OUTPUT
GPIO 33: level=0 fsel=0 func=INPUT
GPIO 34: level=1 fsel=0 func=INPUT
GPIO 35: level=1 fsel=0 func=INPUT
GPIO 36: level=1 fsel=0 func=INPUT
GPIO 37: level=0 fsel=0 func=INPUT
GPIO 38: level=1 fsel=1 func=OUTPUT
GPIO 39: level=0 fsel=0 func=INPUT
GPIO 40: level=0 fsel=4 alt=0 func=PWM0
GPIO 41: level=0 fsel=1 func=OUTPUT
GPIO 42: level=1 fsel=1 func=OUTPUT
GPIO 43: level=1 fsel=0 func=INPUT
GPIO 44: level=1 fsel=4 alt=0 func=GPCLK1
GPIO 45: level=0 fsel=4 alt=0 func=PWM1
BANK2 (GPIO 46 to 53):
GPIO 46: level=0 fsel=0 func=INPUT
GPIO 47: level=0 fsel=1 func=OUTPUT
GPIO 48: level=0 fsel=4 alt=0 func=SD0_CLK
GPIO 49: level=1 fsel=4 alt=0 func=SD0_CMD
GPIO 50: level=1 fsel=4 alt=0 func=SD0_DAT0
GPIO 51: level=1 fsel=4 alt=0 func=SD0_DAT1
GPIO 52: level=1 fsel=4 alt=0 func=SD0_DAT2
GPIO 53: level=1 fsel=4 alt=0 func=SD0_DAT3
joan
Wed Jan 15, 2020 10:14 pm
That indicates GPIO 2, 3, 17, and 18 have failed (assuming nothing was connected to those GPIO during the test).
saxoalex
Thu Jan 16, 2020 12:41 am
Nothing was connected.
Have I to connect something to these GPIOs ?
joan
Thu Jan 16, 2020 6:20 am
The GPIO are bust. If something was connected that would have invalidated the test.
saxoalex
Thu Jan 16, 2020 11:58 am
Did you meant busy ?
Nothing was connected. What can I conclude ?
trejan
Thu Jan 16, 2020 12:07 pm
No. They mean bust the verb for when something is broken.
Something has damaged those 4 GPIOs on your Pi. If nothing is connected then the fault is inside the SoC and you need to replace the Pi.
saxoalex
Thu Jan 16, 2020 3:16 pm
Oh.. Ok.. :(
Thank you for your advice.
This post can be close now.
