Botspot
Why does shutdown dialog take so long to load?
Tue Jan 14, 2020 5:26 pm
Latest Raspbian Buster.
When running from a HDD, it takes nearly a minute for the shutdown dialog to load after clicking the button in the menu.
When running on a Sandisk Extreme Pro, it takes nearly 10 seconds. Chromium opens faster than the shutdown dialog in both cases.
Why?
I would think the shutdown dialog would be very lightweight, maybe 1 MB to load the GUI. But obviously not, and I'm curious as to why.
Ever wanted to run an .img file before flashing it to an SD card?
Or wished you could run Stretch on a Pi 4?
Or wanted to run two versions of Raspbian on a single Pi simultaneously?
You can do all of that, and more, with my Vdesktop script - http://bit.ly/VDESKTOP
FTrevorGowen
Re: Why does shutdown dialog take so long to load?
Tue Jan 14, 2020 10:35 pm
Why?
Something's not quite right - I'm using fairly basic 32Gb uSDHC cards** in my P4B's and the Shutdown Options pop up does so in < 1sec. (NB. Since I normally don't boot direct to desktop I prefer to "Exit to command line" and then "sudo shutdown -h now" - gives me bit more time to ensure I can watch for the final PWR/ACT led sequence before, physically, removing power - those leds are not so easy to see through a suitable slot in two of the cases.)
Trev.
** AH - AK shown here: https://www.cpmspectrepi.uk/raspberry_p ... cards.html
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Botspot
Thu Jan 16, 2020 1:22 pm
It's a genuine Sandisk, I ordered it directly from their website.
My Shutdown Options takes approximately as long to load as Chromium.
Chromium takes 6-10 seconds. Shutdown Options takes 6-10 seconds.
FTrevorGowen
Thu Jan 16, 2020 1:29 pm
Exactly which type of Sandisk (IIRC there's an early P4 thread where it was noted that one "high-performance" Sandisk type actually worked slower in a P4 than its (one model type) lower "brother". A3 vs. A2 or something like that)
Trev.
Botspot
Thu Jan 16, 2020 1:47 pm
Trev.
I don't think the SD card is an issue. After all, Chromium loads in 8 seconds average!
It is a 64GB SanDisk Extreme Pro A1.
Thu Jan 16, 2020 3:33 pm
Does it take that long every time? I wonder if it's waiting for a disk sync or similar - they can take a while if you have a lot of cache to save.
What does htop say whilst its happening?
edit: Just tried this with most recent stuff, up in less than 0.5s.
W. H. Heydt
Thu Jan 16, 2020 4:17 pm
Trev.
A2 (slower) vs. A1 (faster). A2 requires specific--proprietary--hardware support that Pis lack.
Botspot
Thu Jan 16, 2020 5:20 pm
Yes it takes about as long every time. On this SD card on 4B4 latest Buster, it ranges from 7 secs to 5 secs. (My 3B usually took 10 secs)
I agree, likely to be disk related. Back when my 3B ran on a hard drive, I could hear the HDD's reading head rattling all over the place while Shutdown Options was loading.
Sure, I will try htop in a few minutes, once the data is cleared from the cache.
Thu Jan 16, 2020 5:23 pm
Well I'm running from a basic 8GB card, and its very quick on that. It is odd.
Botspot
Thu Jan 16, 2020 5:41 pm
I have always had this issue, thought everyone had it. Even Stretch (and Jessie IIRC). In general it takes as long to load the shutdown dialog as it takes chromium to load.
How long does chromium-browser take to cold-start for you?
GlowInTheDark
Thu Jan 16, 2020 5:44 pm
Why bother?
I just do:
sudo poweroff
from a terminal window.
Works every time - and quickly.
GitD's list of things that are not quite ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
Thu Jan 16, 2020 9:26 pm
Why bother?
I just do:
sudo poweroff
Because there is clearly something wrong if its taking that long to start up. And that's probably not the only symptom.
Botspot
Sat Jan 18, 2020 6:37 pm
Strangely
jamesh wrote: What does htop say whilst its happening?
As long as htop is running, Shutdown dialog appears almost instantly. But if I exit htop and wait for a few minuted, it takes a while to open as it did before.
jamesh wrote: And that's probably not the only symptom.
Everything else opens fast, pcmanfm in 0.3 seconds, lxerminal in 0.5 seconds, gpicview in 1 second. I'm going to try a fresh Raspbian install.
