Petrouil
Object Recognition using Raspberry
Fri Jan 10, 2020 3:43 pm
I am here because I need to build a project with raspberry pi 4 with opencv that recognises objects in real time, and I have some questions.
1) Is this possible in real-time using such an slow computer?
2) What algorithm/library should I use for this purpose?
3) Can I use my USB Microsoft LifeCam instead of buying the raspberry camera?
Thanks in advance for any kind of answers!!
luckydog
Re: Object Recognition using Raspberry
Tue Jan 14, 2020 3:53 pm
Hi, I found this articl https://elinux.org/RPi_USB_Webcams that says that camera is compatible, looks like it hasnt been updated recently but I would give your camera a go before you buy a new one.
pmbdk
Tue Jan 14, 2020 4:38 pm
1) It depends on your definition of "realtime". No image sensor works in true realtime anyway ;-)
2) Depends on your application
3) The webcams I have tried works fine. But you can just plug it in and test. You don't really want high-resolution anyway.
ElEscalador
Tue Jan 14, 2020 4:48 pm
Check out https://github.com/AlexeyAB/darknet for a version of pjreddie/darknet that allegedly runs on a pi4. I have not been able to get it to run on a pi3, but the way I use it in ROS/robotics makes it easy for a little pi3 robot to send images to a laptop for processing. Without even using my GPU I get the same 1fps that I do when I run directly on my laptop. I understand that running on the pi4 is much, much slower.
Giving away some sensors and robot parts in advance of my book release! The first review and giveaway below!
https://youtu.be/fCX0HaeQiyw
g4bch
Wed Jan 15, 2020 12:53 pm
You might find something here
https://www.pyimagesearch.com/category/raspberry-pi/
It seems to be quite a bit ther on image processing and AI, mainly python based.
