rin67630
Could it be explained in a simpler way?
Thu Dec 05, 2019 2:15 am
Upon updating Raspbian Buster with
sudo apt-get update
I get this error:
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'testing' to 'stable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
The man pages are at least as confusing as the main error containins absolutley no examples of the expected syntax to accept the stable release.
Could it be possible to get a simple example of how to accept above mentioned InRelease?
Thank you for helping
trejan
Re: Could it be explained in a simpler way?
Thu Dec 05, 2019 2:20 am
Run "sudo apt update" instead and it'll prompt you. apt-get is intended for non-interactive usage in scripts so works differently to apt.
It is very unlikely apt-get or the man pages will be modified. It has been like this in upstream Debian for a long time now and the Raspbian maintainers try to avoid modifying packages as it is a maintenance headache.
Thu Dec 05, 2019 2:22 am
sudo apt-get update
I get this error:
Use APT as recommended:
sudo apt update
sudo apt full-upgrade
sudo reboot
https://www.raspberrypi.org/documentati ... pdating.md
Retired disgracefully.....
rin67630
Thu Dec 05, 2019 2:43 am
Thank you (and Trejan). So easy, once you do it right! :P
andrum99
Thu Dec 05, 2019 10:45 am
Background: 'apt-get' used to be the recommended way to do these things, then 'apt' was developed as a successor.
Thu Dec 05, 2019 10:50 am
Sort of.
apt was developed as a more "user friendly" way to do things. apt-get is best for automated scripts and other things and is fine if you are used to doing things that way.
You will have to prise my apt-get from my poor dead broken pedipalps before I stop using it ;-)
Return to “Raspbian”
