bear with me - this is nearly a short (?) story ... but i have the following problem:
I have a powered ush-hub.
Connected to the hub are
a Astrometa USB Tv stick and
a 2.5” harddisk.
This hub is connected to a USB-switch, by which the connection is directed either to a Raspberry Pi 3b+ (running Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux) or
Raspberry Pi 4b (running Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux)
Power adapter is the original Pi 5.1V 3A
Cable length is about 20 cm.
Switching to the Rpi 3b+ the hub is recognized and the correct devices are installed.
Switching to the Rpi 4 the hub is never connected (I tried USB3.0 and USB 2.0)
Switching the cables doesn’t help nor does switching the ports on the USB switch.
Raspberry Pi 3 always works – Raspberry 4 never. So any hardware problems (except for Raspi 4) can be excluded.
Output (short dmesg) when switching to Raspi 4
pi@raspberrypi:~ $ dmesg
[ 1333.805324] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 1334.715360] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 1334.715794] usb 1-1-port2: attempt power cycle
[ 1335.965412] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 1336.875422] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 1336.875835] usb 1-1-port2: unable to enumerate USB device
[ 1473.986324] usb 1-1.3: new high-speed USB device number 31 using xhci_hcd
[ 1474.896957] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1474.996346] usb 1-1.3: new high-speed USB device number 32 using xhci_hcd
[ 1475.906947] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1475.907382] usb 1-1-port3: attempt power cycle
[ 1477.156939] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1478.096964] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1478.097398] usb 1-1-port3: unable to enumerate USB device
pi@raspberrypi:~ $
Output (short dmesg) when switching to Raspi 3
[ 8089.172448] usb 1-1.2: new high-speed USB device number 22 using dwc_otg
[ 8089.302836] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 8089.302852] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 8089.302862] usb 1-1.2: Product: USB 2.0 Hub
[ 8089.303583] hub 1-1.2:1.0: USB hub found
[ 8089.303672] hub 1-1.2:1.0: 4 ports detected
[ 8089.722459] usb 1-1.2.2: new high-speed USB device number 23 using dwc_otg
[ 8089.953447] usb 1-1.2.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 4.07
[ 8089.953463] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8089.953473] usb 1-1.2.2: Product: External Disk 3.0
[ 8089.953482] usb 1-1.2.2: Manufacturer: JMicron
[ 8089.953491] usb 1-1.2.2: SerialNumber: 0000000045A9
[ 8089.954317] usb 1-1.2.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[ 8089.954328] usb 1-1.2.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[ 8089.954340] usb-storage 1-1.2.2:1.0: USB Mass Storage device detected
[ 8089.954820] usb-storage 1-1.2.2:1.0: Quirks match for vid 152d pid 0578: 1000000
[ 8089.961600] scsi host1: usb-storage 1-1.2.2:1.0
[ 8090.162474] usb 1-1.2.3: new high-speed USB device number 24 using dwc_otg
[ 8090.402471] usb 1-1.2.3: New USB device found, idVendor=15f4, idProduct=0131, bcdDevice= 1.00
[ 8090.402487] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8090.402497] usb 1-1.2.3: Product: dvbt2
[ 8090.402507] usb 1-1.2.3: Manufacturer: astrometadvbt2
[ 8090.410098] usb 1-1.2.3: dvb_usb_v2: found a 'Astrometa DVB-T2' in warm state
[ 8090.479673] usb 1-1.2.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 8090.479717] dvbdev: DVB: registering new adapter (Astrometa DVB-T2)
[ 8090.487703] i2c i2c-3: Added multiplexed i2c bus 4
[ 8090.487717] rtl2832 3-0010: Realtek RTL2832 successfully attached
[ 8090.498316] mn88473 3-0018: Panasonic MN88473 successfully identified
[ 8090.498415] usb 1-1.2.3: DVB: registering adapter 5 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 8090.498647] usb 1-1.2.3: DVB: registering adapter 5 frontend 1 (Panasonic MN88473)...
[ 8090.498832] r820t 4-003a: creating new instance
[ 8090.505755] r820t 4-003a: Rafael Micro r820t successfully identified
[ 8090.505786] r820t 4-003a: attaching existing instance
[ 8090.510567] r820t 4-003a: Rafael Micro r820t successfully identified
[ 8090.522883] Registered IR keymap rc-empty
[ 8090.523041] rc rc0: Astrometa DVB-T2 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.3/rc/rc0
[ 8090.523252] input: Astrometa DVB-T2 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.3/rc/rc0/input9
[ 8090.523630] rc rc0: lirc_dev: driver dvb_usb_rtl28xxu registered at minor = 0, raw IR receiver, no transmitter
[ 8090.523869] usb 1-1.2.3: dvb_usb_v2: schedule remote query interval to 200 msecs
[ 8090.535053] usb 1-1.2.3: dvb_usb_v2: 'Astrometa DVB-T2' successfully initialized and connected
[ 8090.993244] scsi 1:0:0:0: Direct-Access JMicron Tech 0407 PQ: 0 ANSI: 6
[ 8090.994500] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 8090.994525] sd 1:0:0:0: [sdb] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 8090.995034] sd 1:0:0:0: [sdb] Write Protect is off
[ 8090.995052] sd 1:0:0:0: [sdb] Mode Sense: 47 00 00 08
[ 8090.995600] sd 1:0:0:0: [sdb] Disabling FUA
[ 8090.995617] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 8094.222482] sdb: sdb1
[ 8094.226198] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 8094.701046] usb 1-1.2.3: DVB: adapter 5 frontend 0 frequency 0 out of range (174000000..862000000)
pi@raspberrypi:~ $
When I connect without the USB-Switch everything is working fine:
Raspi 4:
[ 1637.767858] usb 1-1.3: new high-speed USB device number 35 using xhci_hcd
[ 1637.898278] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 1637.898294] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1637.898307] usb 1-1.3: Product: USB 2.0 Hub
[ 1637.914730] hub 1-1.3:1.0: USB hub found
[ 1637.915433] hub 1-1.3:1.0: 4 ports detected
[ 1638.327844] usb 1-1.3.2: new high-speed USB device number 36 using xhci_hcd
[ 1638.559230] usb 1-1.3.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 4.07
[ 1638.559246] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1638.559258] usb 1-1.3.2: Product: External Disk 3.0
[ 1638.559270] usb 1-1.3.2: Manufacturer: JMicron
[ 1638.559281] usb 1-1.3.2: SerialNumber: 0000000045A9
[ 1638.566812] scsi host0: uas
[ 1638.572301] scsi 0:0:0:0: Direct-Access JMicron Tech 0407 PQ: 0 ANSI: 6
[ 1638.574894] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 1638.574910] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1638.575581] sd 0:0:0:0: [sda] Write Protect is off
[ 1638.575596] sd 0:0:0:0: [sda] Mode Sense: 5f 00 00 08
[ 1638.576501] sd 0:0:0:0: [sda] Disabling FUA
[ 1638.576517] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1638.577410] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 1638.664409] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1638.777797] usb 1-1.3.3: new high-speed USB device number 37 using xhci_hcd
[ 1639.017884] usb 1-1.3.3: New USB device found, idVendor=15f4, idProduct=0131, bcdDevice= 1.00
[ 1639.017892] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1639.017898] usb 1-1.3.3: Product: dvbt2
[ 1639.017903] usb 1-1.3.3: Manufacturer: astrometadvbt2
[ 1639.059105] usb 1-1.3.3: dvb_usb_v2: found a 'Astrometa DVB-T2' in warm state
[ 1639.131227] usb 1-1.3.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 1639.131250] dvbdev: DVB: registering new adapter (Astrometa DVB-T2)
[ 1639.144196] i2c i2c-7: Added multiplexed i2c bus 8
[ 1639.144204] rtl2832 7-0010: Realtek RTL2832 successfully attached
[ 1639.156365] mn88473 7-0018: Panasonic MN88473 successfully identified
[ 1639.156410] usb 1-1.3.3: DVB: registering adapter 5 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 1639.156508] usb 1-1.3.3: DVB: registering adapter 5 frontend 1 (Panasonic MN88473)...
[ 1639.170952] r820t 8-003a: creating new instance
[ 1639.177956] r820t 8-003a: Rafael Micro r820t successfully identified
[ 1639.177967] r820t 8-003a: attaching existing instance
[ 1639.182765] r820t 8-003a: Rafael Micro r820t successfully identified
[ 1639.194378] Registered IR keymap rc-empty
[ 1639.194444] rc rc0: Astrometa DVB-T2 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.3/rc/rc0
[ 1639.194521] input: Astrometa DVB-T2 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.3/rc/rc0/input9
[ 1639.194681] rc rc0: lirc_dev: driver dvb_usb_rtl28xxu registered at minor = 0, raw IR receiver, no transmitter
[ 1639.194755] usb 1-1.3.3: dvb_usb_v2: schedule remote query interval to 200 msecs
[ 1639.208579] usb 1-1.3.3: dvb_usb_v2: 'Astrometa DVB-T2' successfully initialized and connected
[ 1639.208709] usbcore: registered new interface driver dvb_usb_rtl28xxu
[ 1641.796524] sda: sda1
[ 1641.809727] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1643.324024] usb 1-1.3.3: DVB: adapter 5 frontend 0 frequency 0 out of range (174000000..862000000)
pi@raspberrypi:~ $
My question is why hub and switch are working on the Raspberry Pi 3b+ but not on the Raspberry 4?
Complete dmesg Raspi 4 after boot:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 2019
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 256 MiB at 0x000000001c000000
[ 0.000000] On node 0 totalpages: 951296
[ 0.000000] DMA zone: 1593 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 181248 pages, LIFO batch:63
[ 0.000000] HighMem zone: 770048 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 949703
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M video=HDMI-A-1:1280x720M@60,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 smsc95xx.macaddr=DC:A6:32:5A:80:BD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=5e3da3da-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3491992K/3805184K available (8192K kernel code, 661K rwdata, 2352K rodata, 2048K init, 850K bss, 51048K reserved, 262144K cma-reserved, 3080192K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xec800000 - 0xff800000 ( 304 MB)
lowmem : 0xc0000000 - 0xec400000 ( 708 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 662 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 851 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 28124 entries in 83 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000018] Switching to timer-based delay loop, resolution 18ns
[ 0.000238] Console: colour dummy device 80x30
[ 0.000261] console [tty1] enabled
[ 0.000304] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000326] pid_max: default: 32768 minimum: 301
[ 0.000586] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000603] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001336] CPU: Testing write buffer coherency: ok
[ 0.001734] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002361] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002514] rcu: Hierarchical SRCU implementation.
[ 0.003357] smp: Bringing up secondary CPUs ...
[ 0.004214] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005205] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006156] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006287] smp: Brought up 1 node, 4 CPUs
[ 0.006300] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006310] CPU: All CPU(s) started in HYP mode.
[ 0.006318] CPU: Virtualization extensions available.
[ 0.007055] devtmpfs: initialized
[ 0.017260] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.017458] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017477] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.024975] pinctrl core: initialized pinctrl subsystem
[ 0.025803] NET: Registered protocol family 16
[ 0.028548] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.030006] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.030017] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.030206] Serial: AMBA PL011 UART driver
[ 0.033237] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.069026] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.071406] vgaarb: loaded
[ 0.071780] SCSI subsystem initialized
[ 0.071966] usbcore: registered new interface driver usbfs
[ 0.072023] usbcore: registered new interface driver hub
[ 0.072116] usbcore: registered new device driver usb
[ 0.090376] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-09-24 17:34, variant start
[ 0.100106] raspberrypi-firmware soc:firmware: Firmware hash is cd3add54955f8fa065b414d8fc07c525e7ddffc8
[ 0.111623] clocksource: Switched to clocksource arch_sys_counter
[ 0.188700] VFS: Disk quotas dquot_6.6.0
[ 0.188776] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.188921] FS-Cache: Loaded
[ 0.189096] CacheFiles: Loaded
[ 0.189623] simple-framebuffer 3ea38000.framebuffer: framebuffer at 0x3ea38000, 0x1c2000 bytes, mapped to 0x(ptrval)
[ 0.189639] simple-framebuffer 3ea38000.framebuffer: format=r5g6b5, mode=1280x720x16, linelength=2560
[ 0.193160] Console: switching to colour frame buffer device 160x45
[ 0.196240] simple-framebuffer 3ea38000.framebuffer: fb0: simplefb registered!
[ 0.205185] NET: Registered protocol family 2
[ 0.205821] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.205846] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.205916] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.205986] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.206095] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.206124] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.206405] NET: Registered protocol family 1
[ 0.206930] RPC: Registered named UNIX socket transport module.
[ 0.206939] RPC: Registered udp transport module.
[ 0.206949] RPC: Registered tcp transport module.
[ 0.206958] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.206972] PCI: CLS 0 bytes, default 64
[ 0.209989] Initialise system trusted keyrings
[ 0.210163] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.219018] FS-Cache: Netfs 'nfs' registered for caching
[ 0.219499] NFS: Registering the id_resolver key type
[ 0.219530] Key type id_resolver registered
[ 0.219539] Key type id_legacy registered
[ 0.219558] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.221807] Key type asymmetric registered
[ 0.221817] Asymmetric key parser 'x509' registered
[ 0.221927] bounce: pool size: 64 pages
[ 0.221966] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.222120] io scheduler noop registered
[ 0.222130] io scheduler deadline registered (default)
[ 0.222280] io scheduler cfq registered
[ 0.222291] io scheduler mq-deadline registered (default)
[ 0.222301] io scheduler kyber registered
[ 0.245804] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.245823] brcm-pcie fd500000.pcie: could not get clock
[ 0.245883] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.245919] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ 0.301658] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.301911] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.301926] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.301955] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.301996] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.302132] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.304854] PCI: bus0: Fast back to back transfers disabled
[ 0.304872] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.305079] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.305201] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.305513] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.308259] PCI: bus1: Fast back to back transfers disabled
[ 0.308274] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.308319] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.308338] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.308408] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.308425] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.308639] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.308804] pcieport 0000:00:00.0: Signaling PME with IRQ 56
[ 0.308958] pcieport 0000:00:00.0: AER enabled with IRQ 56
[ 0.309124] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.310933] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.312918] iproc-rng200 fe104000.rng: hwrng registered
[ 0.313138] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.313628] vc-sm: Videocore shared memory driver
[ 0.314015] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.323752] brd: module loaded
[ 0.333154] loop: module loaded
[ 0.333895] Loading iSCSI transport class v2.0-870.
[ 0.335526] libphy: Fixed MDIO Bus: probed
[ 0.335943] bcmgenet fd580000.genet: failed to get enet clock
[ 0.335958] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.335975] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.335991] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.336013] bcmgenet: Skipping UMAC reset
[ 0.336236] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.351651] libphy: bcmgenet MII bus: probed
[ 0.392176] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.393036] usbcore: registered new interface driver r8152
[ 0.393094] usbcore: registered new interface driver lan78xx
[ 0.393150] usbcore: registered new interface driver smsc95xx
[ 0.393445] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.393475] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.395700] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.396010] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 57
[ 0.396859] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.396873] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.396884] usb usb1: Product: xHCI Host Controller
[ 0.396895] usb usb1: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[ 0.396906] usb usb1: SerialNumber: 0000:01:00.0
[ 0.397408] hub 1-0:1.0: USB hub found
[ 0.397488] hub 1-0:1.0: 1 port detected
[ 0.397951] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.397973] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.397991] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.398392] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.398405] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.398417] usb usb2: Product: xHCI Host Controller
[ 0.398428] usb usb2: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[ 0.398438] usb usb2: SerialNumber: 0000:01:00.0
[ 0.398920] hub 2-0:1.0: USB hub found
[ 0.398987] hub 2-0:1.0: 4 ports detected
[ 0.400165] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.425724] dwc_otg fe980000.usb: base=(ptrval)
[ 0.626026] Core Release: 2.80a
[ 0.626045] Setting default values for core params
[ 0.626070] Finished setting default values for core params
[ 0.826393] Using Buffer DMA mode
[ 0.826403] Periodic Transfer Interrupt Enhancement - disabled
[ 0.826412] Multiprocessor Interrupt Enhancement - disabled
[ 0.826422] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.826479] Dedicated Tx FIFOs mode
[ 0.827051] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = dc134000 dma = 0x00000000dc134000 len=9024
[ 0.827073] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.827084] dwc_otg: Microframe scheduler enabled
[ 0.827145] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.827162] WARN::hcd_init_fiq:458: FIQ ASM at c07b6224 length 36
[ 0.827178] WARN::hcd_init_fiq:497: MPHI regs_base at ec810200
[ 0.827213] dwc_otg fe980000.usb: DWC OTG Controller
[ 0.827242] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ 0.827275] dwc_otg fe980000.usb: irq 38, io mem 0x00000000
[ 0.827325] Init: Port Power? op_state=1
[ 0.827334] Init: Power Port (0)
[ 0.827590] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.827603] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.827614] usb usb3: Product: DWC OTG Controller
[ 0.827625] usb usb3: Manufacturer: Linux 4.19.75-v7l+ dwc_otg_hcd
[ 0.827635] usb usb3: SerialNumber: fe980000.usb
[ 0.828135] hub 3-0:1.0: USB hub found
[ 0.828183] hub 3-0:1.0: 1 port detected
[ 0.828766] dwc_otg: FIQ enabled
[ 0.828775] dwc_otg: NAK holdoff enabled
[ 0.828784] dwc_otg: FIQ split-transaction FSM enabled
[ 0.828797] Module dwc_common_port init
[ 0.828990] usbcore: registered new interface driver uas
[ 0.829098] usbcore: registered new interface driver usb-storage
[ 0.829255] mousedev: PS/2 mouse device common for all mice
[ 0.830410] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.830595] bcm2835-cpufreq: min=600000 max=1500000
[ 0.831138] sdhci: Secure Digital Host Controller Interface driver
[ 0.831147] sdhci: Copyright(c) Pierre Ossman
[ 0.831535] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.831961] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.834902] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.835039] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.835159] usbcore: registered new interface driver usbhid
[ 0.835168] usbhid: USB HID core driver
[ 0.835860] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.837151] [vc_sm_connected_init]: start
[ 0.843397] [vc_sm_connected_init]: end - returning 0
[ 0.844459] Initializing XFRM netlink socket
[ 0.844487] NET: Registered protocol family 17
[ 0.844606] Key type dns_resolver registered
[ 0.844988] Registering SWP/SWPB emulation handler
[ 0.845561] registered taskstats version 1
[ 0.845577] Loading compiled-in X.509 certificates
[ 0.853186] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.853248] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.856458] console [ttyS0] disabled
[ 0.856489] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 36, base_baud = 62500000) is a 16550
[ 0.856543] console [ttyS0] enabled
[ 0.856960] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.857463] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.858074] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.858085] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.882196] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ 0.899441] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.901031] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.902796] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.905677] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.907280] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.914533] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.917002] of_cfs_init
[ 0.917080] of_cfs_init: OK
[ 0.917652] Waiting for root device PARTUUID=5e3da3da-02...
[ 0.963702] random: fast init done
[ 0.971688] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.979228] mmc1: new high speed SDIO card at address 0001
[ 1.018808] mmc0: new ultra high speed DDR50 SDHC card at address 1234
[ 1.019846] mmcblk0: mmc0:1234 SA16G 14.4 GiB
[ 1.021095] mmcblk0: p1 p2
[ 1.058859] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.058900] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.065924] devtmpfs: mounted
[ 1.072156] Freeing unused kernel memory: 2048K
[ 1.072396] Run /sbin/init as init process
[ 1.154290] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 1.154305] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.154317] usb 1-1: Product: USB2.0 Hub
[ 1.156031] hub 1-1:1.0: USB hub found
[ 1.156344] hub 1-1:1.0: 4 ports detected
[ 1.526133] systemd[1]: System time before build time, advancing clock.
[ 1.643548] NET: Registered protocol family 10
[ 1.644722] Segment Routing with IPv6
[ 1.692082] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.692796] systemd[1]: Detected architecture arm.
[ 1.701066] systemd[1]: Set hostname to <raspberrypi>.
[ 1.703453] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 2.047019] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.047040] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.302274] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 2.421685] usb 1-1.3: new high-speed USB device number 4 using xhci_hcd
[ 2.461554] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.470435] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.476069] systemd[1]: Listening on Syslog Socket.
[ 2.476487] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.476895] systemd[1]: Listening on udev Kernel Socket.
[ 2.482113] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.483394] systemd[1]: Created slice User and Session Slice.
[ 2.574125] i2c /dev entries driver
[ 3.342229] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 3.342778] usb 1-1-port3: attempt power cycle
[ 3.996185] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.103242] systemd-journald[115]: Received request to flush runtime journal from PID 1
[ 4.592322] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 4.656405] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 4.657016] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 4.660271] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 4.662616] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 4.691733] usb 1-1.3: new high-speed USB device number 6 using xhci_hcd
[ 4.692301] usb 1-1.3: Device not responding to setup address.
[ 4.714123] media: Linux media interface: v0.10
[ 4.742498] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.746023] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.746044] [vc_sm_connected_init]: start
[ 4.751976] [vc_sm_connected_init]: installed successfully
[ 4.753775] videodev: Linux video capture interface: v2.00
[ 4.808451] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.810212] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.822975] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.846415] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.863244] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.863288] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.864331] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.872922] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.872953] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.881029] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.881060] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.882543] bcm2835_audio soc:audio: card created with 8 channels
[ 4.911931] usb 1-1.3: Device not responding to setup address.
[ 5.131681] usb 1-1.3: device not accepting address 6, error -71
[ 5.132069] usb 1-1-port3: unable to enumerate USB device
[ 5.202679] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.262780] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.262798] checking generic (3ea38000 1c2000) vs hw (0 ffffffffffffffff)
[ 5.262808] fb: switching to vc4drmfb from simple
[ 5.263012] Console: switching to colour dummy device 80x30
[ 5.268950] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 5.268964] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.268973] [drm] No driver support for vblank timestamp query.
[ 5.268982] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.383996] Console: switching to colour frame buffer device 160x45
[ 5.384038] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[ 5.420872] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.431687] usb 1-1.3: new high-speed USB device number 7 using xhci_hcd
[ 5.514128] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.555988] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.568572] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.569189] usbcore: registered new interface driver brcmfmac
[ 5.794923] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.808300] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 6.342304] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 6.441675] usb 1-1.3: new high-speed USB device number 8 using xhci_hcd
[ 7.352250] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 7.352686] usb 1-1-port3: attempt power cycle
[ 7.679911] random: crng init done
[ 7.679930] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.813008] uart-pl011 fe201000.serial: no DMA platform data
[ 8.086459] 8021q: 802.1Q VLAN Support v1.8
[ 8.389105] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.612283] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 9.522226] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 9.522639] usb 1-1-port3: unable to enumerate USB device
[ 9.678386] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.678405] brcmfmac: power management disabled
[ 10.125631] bcmgenet: Skipping UMAC reset
[ 10.222195] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 10.222352] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.998002] input: vnc-keyboard as /devices/virtual/input/input0
[ 10.998260] input: vnc-abspointer as /devices/virtual/input/input1
[ 10.998650] input: vnc-relpointer as /devices/virtual/input/input2
[ 11.271854] bcmgenet fd580000.genet eth0: Link is Down
[ 13.890858] input: vnc-keyboard as /devices/virtual/input/input3
[ 13.891105] input: vnc-abspointer as /devices/virtual/input/input4
[ 13.894285] input: vnc-relpointer as /devices/virtual/input/input5
[ 14.757568] Bluetooth: Core ver 2.22
[ 14.757610] NET: Registered protocol family 31
[ 14.757614] Bluetooth: HCI device and connection manager initialized
[ 14.757624] Bluetooth: HCI socket layer initialized
[ 14.757631] Bluetooth: L2CAP socket layer initialized
[ 14.757651] Bluetooth: SCO socket layer initialized
[ 14.777381] Bluetooth: HCI UART driver ver 2.3
[ 14.777390] Bluetooth: HCI UART protocol H4 registered
[ 14.777431] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.777544] Bluetooth: HCI UART protocol Broadcom registered
[ 15.059859] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.059863] Bluetooth: BNEP filters: protocol multicast
[ 15.059875] Bluetooth: BNEP socket layer initialized
[ 15.179721] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.994885] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 21.093775] Bluetooth: RFCOMM TTY layer initialized
[ 21.093799] Bluetooth: RFCOMM socket layer initialized
[ 21.093830] Bluetooth: RFCOMM ver 1.11
[ 21.395590] fuse init (API version 7.27)
pi@raspberrypi:~ $
pi@raspberrypi:~ $ lsusb -v
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idProduct 0x0003 3.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bMaxBurst 0
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
idVendor 0x2109 VIA Labs, Inc.
idProduct 0x3431 Hub
bcdDevice 4.20
iManufacturer 0
iProduct 1
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
pi@raspberrypi:~ $
pi@raspberrypi:~ $ uname -a
What can I do - besides leaving out the usb-switch?
