cebess
Problems maintaining VNC connection - Cannot Currently show the desktop
Tue Dec 03, 2019 11:33 am
I use VNC all the time on my Pi but sometimes when I have a long running task, I walk away. When I get back "Cannot currently show the desktop" is shown on the screen. I know the computer is still running OK. I just cannot bring up the VNC virtual screen on a client on my PC...
Any thoughts on how to get the virtual display working again or to restart the server without killing the current activity? A reboot always work, but then I need to restart my long running task.
cebess
Re: Problems maintaining VNC connection - Cannot Currently show the desktop
Tue Dec 03, 2019 12:16 pm
A little more detail:
When I do a ps -e, I see:
385 ? 00:00:00 vncserver-x11-s
398 ? 00:08:50 vncserver-x11-c
but when I do a sudo vncserver, I receive back
vncserver: error while loading shared libraries: libbcm_host.so: cannot open shared object file: No such file or directory
I am relatively new to the pi and VNC so I figured I was missing something obvious.
FTrevorGowen
Tue Dec 03, 2019 5:23 pm
Are you referring to RealVNC's virtual mode** or some other VNC server?
Trev.
** Often useful for Pi's (temporally ) running headless (w/o being connected to a display etc...) - FWIW, some examples here: https://www.cpmspectrepi.uk/raspberry_p ... uster.html
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
cebess
Tue Dec 03, 2019 9:17 pm
I believe it is RealVNC. It was a while ago when I installed it. One other detail - as long as my long running task is working the remote screen behaves fine. It is when the task ends and there is nothing consuming the CPU that it goes black with the error message.
FTrevorGowen
Tue Dec 03, 2019 9:39 pm
IIRC, RealVNC is already installed within "Desktop" versions of Raspbian (and enabled via raspi-config etc.)** so you may have installed something else.
Trev.
** Historically from the time of Raspbian Jessie "Pixel" onwards:https://www.cpmspectrepi.uk/raspberry_p ... Pixel.html
cebess
Wed Dec 04, 2019 11:03 am
Thanks for the response. I checked my notes and I did
sudo apt-get update
sudo apt-get install realvnc-vnc-server realvnc-vnc-viewer
So it is realVNC that is installed.
FTrevorGowen
Wed Dec 04, 2019 7:58 pm
sudo apt-get update
O.K. just so we have a better idea of your setup can you post the output of these commands:
uname -a
cat /etc/os-release
Trev.
Return to “Raspbian”
