Hello, I am still trying to connect my monitor with a raspberry pi 4 using the Raspbian operating system. The monitor is still not being identified by the raspberry pi. I tried to modify the following parameters from the default config.txt file in the boot directory, hdmi_force_hotplug=1, hdmi_group=1, hdmi_mode=16, hdmi_drive=2, config_hdmi_boost=11. I modified these parameters one by one and restarted with every modification. The monitor is a Seiki model no. sc32ht04. The monitor has a resolution of 1080p with a 60hz refresh rate. It is still not being identified by the raspberry pi.
I choose these parameters based on the information from the website
https://www.raspberrypi.org/documentati ... t/video.md.
Any helpful advice would be appreciated.
# For more options and information see
http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=1
hdmi_mode=16
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
