Jawikama
Installed Samba but not visable on the network
Sun Nov 10, 2019 9:00 pm
Hi all.
I've installed Sabnzbdplus on my raspberry pi succesfull and started downloading.
Now I want all downloaded files available for my devices and i installed Samba to do so.
Unfortunately Samba started with showing a map which i did not configure and while trying to get it working I can not login any more and all my devices say that the server does not respond.
As a nono on this area i've tried all kind of solutions provided by Google but the result is still nothing.
Also i can not find any log files related to Samba. I have the idea that i only get further away from the solution.
Removing Samba and reinstall gives no improvement. (all samba config files are not removed by this)
Looking at this i believe that something else is causing issues and blocking Samba to work properly.
Does anyone has an idea how i solve this?
Thx in advance
Regards Jacob.
pcmanbob
Re: Installed Samba but not visable on the network
Sun Nov 10, 2019 11:09 pm
After you installed samba did you add a user and set up a folder to share ?
have a look at the samba setup in the magpi magazine for more details
https://magpi.raspberrypi.org/articles/ ... ile-server
hortimech
Mon Nov 11, 2019 8:50 am
No, don't follow that howto, follow the official Samba one:
https://wiki.samba.org/index.php/Settin ... one_Server
Your problem is probably a lack of SMBv1, this is now turned off by default and without it, there is no network browsing.
Jawikama
Tue Nov 12, 2019 8:50 pm
thanks for the help but unfortunately everything is already tried as most of this is also available by google.
Looking at my setup and I did several attempts in smb.conf
[global]
workgroup =workgroup (like on my pc)
Security = user
log file = /var/log/samba/log.%m
server role = standalone server
[share]
path = media/pi/usb/shared
available = yes
browsable = yes
only guests = no
writable = yes
public = yes
guest ok = yes
So after a fresh reboot the system work fine except the samba part.
When I connect via my PC to \\192.168.2.55\ (ip adres on my server) it finds my raspberry and asks for userid and password so i login with user = pi and correct password and i get an error "no access to \\192.168.2.55" and when I click on solve problem it returns with "the external source does not accept connection".
So the pi reacts on my request but even though i populate the correct userid and password it does not let me pass.
Anybody any idea what is happening here?
hortimech
Tue Nov 12, 2019 9:57 pm
Did you read the link I pointed you to ?
Lets look at the smb.conf you are using now:
You don't really need the workgroup line, it is the default.
You do not need both 'Security = user' and 'server role = standalone server'
Now for the share:
'available = yes' and 'browsable = yes' are defaults, so are not needed.
'only guests' is actually 'only guest' and the default is 'no', so again not needed
'public = yes' and 'guest ok = yes' mean the same thing, so you only need one, but you haven't set 'map to guest = bad user' in global, so whichever you pick will do nothing.
Read our documentation: https://wiki.samba.org/index.php/Settin ... one_Server
iznobe
Tue Nov 12, 2019 10:25 pm
Hi ,
when samba is well configured , you must add your user ( probably pi ) to the sambashare groupe , without this , pi can NOT acces to sambashare , RTFM as said before !
if you want you can add more than one user , to give access , if it is not a public share.
your device is windows ? if not , use NFS is more simple with linux or android or mac .
DirkS
Wed Nov 13, 2019 9:07 am
In addition what was mentioned above:
Looks like an invalid path to me. Probably missing a leading '/'
