MarDre
Creating a Pi Image via Network
Sun Nov 10, 2019 1:58 pm
Hello Community,
I hope i am not asking a question which has already been asked...
I am working with a my Pi remotly and i am not always able to plug in USB devices or remove my SD Card.
I would like to know, if there is a way to create an Image of my Pi over the Network conection.
There are a few criteria for this:
- the Pi is running
- the Pi must be running while and after the Image is created
- the Pi is connected to a Windows PC
- the Image must be an Image of the real used data, not the whole 32gb SD Card
- I want to use the Image on other Pi's --> These Pi's i can acces physically
Here are my Os Information:
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
Thank you for your help in advance!
Best regards!
MarDre
topguy
Re: Creating a Pi Image via Network
Mon Nov 11, 2019 2:12 am
Then its not really an "image" anymore.
But yes you can make an archive of all the files in the file-system even if its running and you can extract those over to another card if you want.
This article migth have a solution to your problem.
https://www.cyberciti.biz/faq/howto-use ... h-session/
RonR
Mon Nov 11, 2019 4:01 am
- the Pi is running
Yes to all your criteria. Simply mount a windows share on /media or /mnt:
mount -t cifs -o username=USERNAME,password=PASSWORD //WINDOWS_SHARE /mnt
and use image-backup from Image File Utilities. image-backup can even do incremental updates to the image file as things change on the Raspberry Pi.
