LinuxTux23
What is the maximum temperature of the CPU before it gets demaged ?
Sat Nov 09, 2019 9:01 am
Hi folks,
I have a Raspberry Pi 4 with a fan, to avoid a overheating of the CPU.
The fan isnt so quietly. Thats why i wanna write a little python programm, that turn on the fan if the CPU gets to hot.
Now my question is, what is the maximum temperature wich the CPU can survive ?
Thank you,
LinuxTux23
PS: Sorry for my English I´m not a natíve speaker. :lol:
timg236
Re: What is the maximum temperature of the CPU before it gets demaged ?
Sat Nov 09, 2019 11:41 am
The CPU frequency is automatically reduced in order to avoid damage due to overheating so you don't need a fan to prevent damage. In the very worst case you will just see a performance reduction when running CPU intensive tasks e.g. compiling the Linux Kernel.
First, make sure you have the latest software which reduces power consumption. Install the latest Buster image from the downloads page or if you have already installed Raspbian
sudo apt update
sudo apt upgrade
# Then reboot
If you only want to run the fan when the CPU is getting warm then 80 C might be a reasonable threshold but lots you'll have to experiment with different workloads and will depend on heatsink/case or not etc
The bcmstat utility is very useful for determining if/when you want active cooling
https://github.com/MilhouseVH/bcmstat
Sat Nov 09, 2019 12:05 pm
The true answer would appear to be the melting point of lead free solder and best of luck to the OP trying to run their Raspberry at the temperature.
The in-built throttling means you can't practically run over 85°C without using mythical overclocking settings that would be outside the spec for the processor.
This is a doctor free zone.
jbudd
Sat Nov 09, 2019 12:32 pm
You don't actually need to write a program for this, it is possible to control a fan automatically using a device tree overlay and a transistor-
For example, this line in /boot/config.txt will set GPIO 12 high when the CPU temperature reaches 65C and low again when it cools down by 10 degrees.
dtoverlay=gpio-fan,gpiopin=12,temp=65000
See https://raspmer.blogspot.com/2019/02/co ... o-fan.html for more details
jahboater
Sat Nov 09, 2019 1:04 pm
With the latest firmware, there seems to be no risk of even reaching 85C now.
My Pi4 has no fan, and the maximum temp is about 72C when running the cpuburn stress test for an hour.
Running huge compilations like building GCC brings it up to around 63C.
And that's overclocked!
Idles around 40C or less now.
Cooling problems and throttling are a thing of the past, unless you have a silly unventilated case.
Time         ARM    Core    H264 Core Temp (Max)  IRQ/s      RX B/s      TX B/s
13:08:43 1600Mhz  500Mhz    0Mhz 39.92C (40.89C)  4,772       4,089      16,728
13:08:45 1600Mhz  500Mhz    0Mhz 39.43C (40.89C)     87         129         113
13:08:47 1600Mhz  500Mhz    0Mhz 39.43C (40.89C)     82          32         105
13:08:49  640Mhz  200Mhz    0Mhz 39.43C (40.89C)     99         158         104
13:08:51  640Mhz  200Mhz    0Mhz 39.43C (40.89C)     88         158         100
13:08:53  640Mhz  200Mhz    0Mhz 39.43C (40.89C)     88          32         100
13:08:55  640Mhz  200Mhz    0Mhz 39.43C (40.89C)     95         200         163
13:08:57  640Mhz  200Mhz    0Mhz 39.43C (40.89C)     86         128         100
13:09:00  640Mhz  200Mhz    0Mhz 39.43C (40.89C)     89          32         100
13:09:02  640Mhz  200Mhz    0Mhz 38.95C (40.89C)     98         196         142
13:09:04  640Mhz  200Mhz    0Mhz 38.95C (40.89C)     92         158         100
13:09:06  640Mhz  200Mhz    0Mhz 38.95C (40.89C)     92          74         139
13:09:08  640Mhz  200Mhz    0Mhz 38.95C (40.89C)     86         128         100
13:09:10  640Mhz  200Mhz    0Mhz 37.97C (40.89C)     85          96         100
jbudd
Sat Nov 09, 2019 1:14 pm
Is "firmware" different from the kernel version as shown by uname -r?
If it is, does it get updated by apt update? How do we tell what version we have?
My Pi4 does seem to run cooler than it first did. I'd put it down to the weather.
Sat Nov 09, 2019 1:18 pm
There's a new piece rpi-eeprom that updates the bootcode stored in EEPROM on your RPi4B. The RPF/RPTL folks have now forced a package on every Raspbian Buster user to run that automagically at boot time (which will be all good fun until they ship bootcode with a catastrophic bug and then the brown stuff will make quick company with the air movement device).
Sat Nov 09, 2019 1:48 pm
Just for completeness, the CPU's are tested to over 120degC during MTBF testing. They are still undamaged at that temperature, but we do not allow to get anywhere near that hot in the real world.
jbudd
Sat Nov 09, 2019 2:08 pm
Hmm I knew about changes for network booting, didn't realise the bootcode also related to thermal issues.
So "firmware" version is revealed by sudo vl805 (000137ab)
It is updated by apt update and possibly at every boot. (I don't like that but I guess it's important to keep bootcode and kernel in sync)
I disabled my fan and ran sysbench --test=cpu --num-threads=4 --cpu-max-prime=80000 run The maximum temperature reached was 74C and the CPU was not throttled.
Did I miss an announcement somewhere to say the temperature issue is now resolved? Good job RPT engineers anyway!
HermannSW
Sun Nov 10, 2019 8:07 am
Can you try it not overclocked?
I did compile OpenCV in >40min, and did log all relevant data, CPU frequency was 1.5GHz the whole time.
Maximal temperature was 81°C, average was 76.7°C:
https://www.raspberrypi.org/forums/view ... 1#p1561520
SInce I don't have fans, your and my measurements should match somehow.
Perhaps your overclocking reduced heat (should not), or you did not push the CPUs like OpenCV compilation did ...
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
sparkyhall
Sun Nov 10, 2019 9:00 am
Board orientation makes a difference, vertical seems best for cooling and I recall jahboater saying his was vertically mounted.
HermannSW
Sun Nov 10, 2019 2:16 pm
I need to try vertical next time, I thought air from above and below is good enough.
My Pi was 45°, only the edge of a small box did touch the bottom side.
You made a good point with vertical, I will hammer in Nx2 nails into book shelve 5.8cm apart.
That way I can just hang the PIs with GPIO up, power and HDMI connectors down, when running.
In addition to better cooling, they don't use space on working plate that way!
I did use that hanging concept before, but with wooden back which means no air from bottom (Wooden Board Pi):
https://www.raspberrypi.org/forums/view ... ?p=1550484
Paul Hutch
Sun Nov 10, 2019 9:40 pm
Not quite true. I've made multiple Pi3B+'s hit 94°C when running flat out in a 65°C oven, with clock throttling enabled. So when running in an environment that hot I include code to stop non-essential tasks after it reaches 85°C and to shut itself down at 90°C to try not to shorten the Pi's life too much.
jahboater
Sun Nov 10, 2019 10:51 pm
HermannSW,
Yes. It didn't seem to make any (easily) measurable difference.
Since I don't have fans, your and my measurements should match somehow.
Try this:-
wget https://raw.githubusercontent.com/ssvb/cpuburn-arm/master/cpuburn-a53.S
gcc -o cpuburn-a53 cpuburn-a53.S
./cpuburn-a53
It uses NEON on all four cores. I don't know of anything else that raises the temp so quickly.
In the early days of the Pi3 it would crash in less than 10 seconds!
My Pi4 is mounted vertically in free air. There is a small stick-on heat sink on the SoC with the fins aligned vertically.
The unused sockets have short cables plugged in (because the PCB ground plane and the sockets dissipate heat).
With this latest software, I suspect the little heat sink is not really needed.
