lucdig
DVBSky S960 V2 USB , dvblast and tsduck tsp
Wed Nov 06, 2019 12:14 pm
Hi, I have problems with the DVBSky S960 V2 USB when I try to use it with dvblast. I tried dvblast with a Pctv 461e, with no issues.
I installed in /lib/firmware the drivers found here: http://www.dvbsky.net/download/linux/firmware.zip
# dmesg | grep dvb
[   17.453675] usb 1-1.3: dvb_usb_v2: found a 'DVBSky S960/S860' in warm state
[   17.454081] usb 1-1.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[   17.454154] dvbdev: DVB: registering new adapter (DVBSky S960/S860)
[   17.455621] usb 1-1.3: dvb_usb_v2: MAC address: 00:17:42:54:96:0c
[   17.758834] Registered IR keymap rc-dvbsky
[   17.759861] rc rc0: lirc_dev: driver dvb_usb_dvbsky registered at minor = 0, scancode receiver, no transmitter
[   17.759886] usb 1-1.3: dvb_usb_v2: schedule remote query interval to 300 msecs
[   17.759911] usb 1-1.3: dvb_usb_v2: 'DVBSky S960/S860' successfully initialized and connected
[   17.760229] usbcore: registered new interface driver dvb_usb_dvbsky
I also installed tsduck from github. Scanning devices:
# tslsdvb -v
/dev/dvb/adapter0 (Montage Technology M88DS3103, DVB-S, DVB-S2)
tslsdvb: error reading status on /dev/dvb/adapter0/frontend0: Resource temporarily unavailable
  Delivery system ............................ DVB-S
  Frequencies:
    Min ................................ 950,000,000 Hz
    Max .............................. 2,150,000,000 Hz
    Step ......................................... 0 Hz
    Tolerance ............................ 5,000,000 Hz
  Symbol rates:
    Min .................................. 1,000,000 sym/s
    Max ................................. 45,000,000 sym/s
    Tolerance .................................... 0 sym/s
  Spectral inversion ........................... off
  FEC(inner) .................................. auto
  Modulation .................................. QPSK
  Capabilities: inversion auto, FEC 1/2, FEC 2/3, FEC 3/4, FEC 4/5, FEC 5/6,
    FEC 6/7, FEC 7/8, FEC 8/9, FEC auto, QPSK, 2nd generation, recover
This command with tsp works, zapping only to channel 122, and the mpegts is correctly produced to multicast address 239.255.0.42:5004. I can see the red light (Lock) of the device switched on.
# tsp -I dvb -a 0 --delivery-system DVB-S2 --fec-inner 3/4 --frequency 11432000000 --modulation 8-PSK --polarity vertical --roll-off auto --symbol-rate 29900000 -P zap 122 -O ip -t 1 -r 239.255.0.42:5004
Anyway, dvblast doesn't produce any multicast stream, and the red light of the device is switched off:
# dvblast -a 0 -F 34 -f 11919000 -s 29900000 -v 13 -m psk_8 -5 DVBS2 -c dvblast.conf
debug: setting filter on PID 0
debug: setting filter on PID 16
debug: setting filter on PID 17
debug: setting filter on PID 18
debug: setting filter on PID 19
debug: setting filter on PID 20
debug: conf: 239.255.1.42:5004/epg/srcaddr=127.0.0.1/ttl=0 config=0xc1 sid=122 pids[0]
debug: change sid tsid
# cat dvblast.conf
239.255.1.42:5004/epg/srcaddr=127.0.0.1/ttl=0 1 122
Any idea?
Thanks, regards
Return to “Media centres”
