david_1234
unable to downlaod from git using pip?
Mon Nov 04, 2019 2:51 pm
Hello ,
I'm having a strange problem - and maybe I'm missing something
I have install a a clean pi4 with buster
after setup finish , I have run a update&&upgrade - then reboot the pi
then I try to downlaod this
sudo pip install git+git://github.com/chrisb2/pi_ina219.git
but I'm getting this error:
pi@raspberrypi:~ $ sudo pip install git+git://github.com/chrisb2/pi_ina219.git
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting git+git://github.com/chrisb2/pi_ina219.git
  Cloning git://github.com/chrisb2/pi_ina219.git to /tmp/pip-req-build-cQuKEg
fatal: unable to connect to github.com:
github.com[0: 140.82.118.3]: errno=Connection timed out
Command "git clone -q git://github.com/chrisb2/pi_ina219.git /tmp/pip-req-build-cQuKEg" failed with error code 128 in None
when I enter the ptoject using the web - I can see it's online and "alive"
did I miss soemthing , do I need to allow some privileges ? to open some setting?
the network is OK , there is ping to 8.8.8.8 and also to www.cnn.com
so what am I missing?
I have open in the firewall tcp/udp 3128 , do I need to open something else?
Thanks ,
topguy
Re: unable to downlaod from git using pip?
Mon Nov 04, 2019 3:39 pm
Why ?
And did you ping github directly ?
ping github.com
PING github.com (140.82.118.3) 56(84) bytes of data.
64 bytes from lb-140-82-118-3-ams.github.com (140.82.118.3): icmp_seq=1 ttl=53 time=33.4 ms
64 bytes from lb-140-82-118-3-ams.github.com (140.82.118.3): icmp_seq=2 ttl=53 time=33.2 ms
64 bytes from lb-140-82-118-3-ams.github.com (140.82.118.3): icmp_seq=3 ttl=53 time=33.2 ms
^C
--- github.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 33.212/33.280/33.413/0.176 ms
david_1234
Mon Nov 04, 2019 4:03 pm
because I found somewhere that this is the pip port use
and
ping github.com
PING github.com (140.82.118.4) 56(84) bytes of data.
64 bytes from lb-140-82-118-4-ams.github.com (140.82.118.4): icmp_seq=1 ttl=49 time=99.4 ms
64 bytes from lb-140-82-118-4-ams.github.com (140.82.118.4): icmp_seq=2 ttl=49 time=97.3 ms
64 bytes from lb-140-82-118-4-ams.github.com (140.82.118.4): icmp_seq=3 ttl=49 time=98.7 ms
