henribusio
automatic startup Bash script
Mon Nov 04, 2019 10:29 am
Hi i made a bash script en when a mannualy click it it works but when i try to add it to RC.LOCAL its does not start activate with the system.
file exist in /home/pi/script
i went to /etc/rc.local and added the script just before the exit like this.
/home/pi/script
but it does not work.
Can some one help me?
Kendek
Re: automatic startup Bash script
Mon Nov 04, 2019 11:47 am
What happens if you try to execute the /etc/rc.local?
sudo /etc/rc.local
henribusio
Mon Nov 04, 2019 12:37 pm
i found a solution adding it to sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
Kendek
Mon Nov 04, 2019 12:47 pm
The correct file is
~/.config/lxsession/LXDE-pi/autostart
if you want to execute a script from your home directory.
henribusio
Mon Nov 04, 2019 12:51 pm
well not for me because i get this error
bash: /home/pi/.config/lxsession/LXDE-pi/autostart: No such file or directory
however with this it did work
henribusio
thank you all for helping :D
Kendek
Mon Nov 04, 2019 12:54 pm
mkdir -p ~/.config/lxsession/LXDE-pi
touch ~/.config/lxsession/LXDE-pi/autostart
nano ~/.config/lxsession/LXDE-pi/autostart
Return to “Advanced users”
