doomjoshuaboy
Zandronum Server (Doom source port engine)
Thu Oct 31, 2019 10:03 am
Hello Everyone
Ever want to use Original doom for gaming servers with mods like Complex doom and Brutal Doom? well this is the best bet for you:
After a few days of testing and compiling the zandronum-server on the pi is finally ready for you to compile. (tested on Raspberry PI4 with Rasphian Buster.)
What went wrong was the SQLite needed an update to the latest as well as the lemon code.
So here's how it works:
1. Update the pi to the latest:
sudo apt update && sudo apt upgrade
1a. (optional) reboot (if needed)
sudo reboot
2. Install these:
sudo apt-get install build-essential zlib1g-dev libsdl1.2-dev libjpeg-dev \
    nasm tar libbz2-dev libgtk2.0-dev cmake mercurial libfluidsynth-dev libgl1-mesa-dev \
    libssl-dev git
3. Make new folder and enter there:
mkdir $HOME/zandronum-build && cd $HOME/zandronum-build
4. Get repo from this website:
git clone https://doomjoshuaboy@bitbucket.org/doomjoshuaboy/zandronum-rpi.git
5. Make a new folder and enter there:
mkdir buildserver && cd buildserver
6. and make:
make clean; \
cmake -DCMAKE_BUILD_TYPE=Release -DSERVERONLY=ON -DNO_ASM=1 .. && \
make -j$(nproc)
and there you have it. have fun with it. if you have any Problems let me know. or pull request and help out.
Zandronum is an source port engine for the Original Doom. (Not Doom 2016) you can easily find out more here: https://zandronum.com/.
The reason why I did this is because the wiki from: https://wiki.zandronum.com/Compiling_th ... spberry_Pi does not work and need an help getting 3.0.X working so i managed to fix it for arm device.
Cheers,
DoomJoshuaBoy
Last edited by doomjoshuaboy on Sun Nov 03, 2019 4:34 am, edited 2 times in total.
B.Goode
Re: Zandronum Server
Thu Oct 31, 2019 2:56 pm
Thank you for your efforts and for sharing the results with the community.
But...
What is a Zandronum Server, and why might I want or need to run one?
doomjoshuaboy
Thu Oct 31, 2019 6:54 pm
B.Goode wrote: Thank you for your efforts and for sharing the results with the community.
But...
hey, yeah i was going to edit the first post to fix up some stuff.
the reason why I did this is because the wiki from: https://wiki.zandronum.com/Compiling_th ... spberry_Pi does not work and need an help getting 3.0.X working so i managed to fix it for arm devices So if you need to run a server with mods like the popular ones which is Complex doom and Brutal Doom the results is in this.
doomjoshuaboy
Re: Zandronum Server (Doom source port engine)
Fri Nov 01, 2019 4:56 am
first update released:
bumped to v2 contains unlagged and tics issues please recompile you have v1 installed
also ill be giving out updates for improvements for the servers stuff
doomjoshuaboy
Wed Nov 06, 2019 4:25 am
Update:
v3 released if you have recieved version 2 please recompile it
as it contains: Desynced problems and tics issues fixed.
do keep in mind though you might need to replace to the old zandronum.pk3 from 3.0 for it to work because the new one you compiled isn't working for some strange reason.
doomjoshuaboy
Thu Nov 07, 2019 9:58 pm
sorry for the another bump:
Update:
v4 released if you have received versions 1, 2 or 3 please recompile it
as it contains: client tics fixed.
Return to “Gaming”
