'C' code (Arduino) for my ESP32 (A Heltec Kit32 with OLED) - as promised. A bit rough and ready but it works with the Pi code that Douglas6 posted.
* Program to operate ESP32 in client mode and get served information from a Raspberry Pi
* Program by: Mark Hollingworth
* The code for the Raspberry Pi can be found here :
* https://www.raspberrypi.org/forums/viewtopic.php?f=62&t=254431
* Dated: 18-10-2019
* NOTE: The MY_RASPBERRY_PI_ADDRESS is specific to my Raspberry Pi and will need to be changed in the onResult() function
* NOTE: There is a bug in the BLE characteristic library found here in a Win10 installation of the Arduino code :
* C:\Users\YOURNAME\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\BLE\src\BLEremotecharacteristic.cpp
* Search the following (at line 33 in my file) and add ": m_rawData(nullptr)"
* BLERemoteCharacteristic::BLERemoteCharacteristic(
* uint16_t handle,
* BLEUUID uuid,
* esp_gatt_char_prop_t charProp,
* BLERemoteService* pRemoteService) : m_rawData(nullptr) {
#define MAX_DEVICES 5
#include <BLEDevice.h>
//Service UUID of Pi temperature
static BLEUUID serviceUUID("00000001-710e-4a5b-8d75-3e5b444bc3cf");
//Characteristic UUID of Pi temperature R
static BLEUUID char2UUID("00000002-710e-4a5b-8d75-3e5b444bc3cf");
//Characteristic UUID of Pi temperature unit R/W 'C' or 'F'
static BLEUUID char3UUID("00000003-710e-4a5b-8d75-3e5b444bc3cf");
static BLERemoteCharacteristic* _pRemoteCharacteristic;
BLEScan* _pBLEScan;
static BLEAddress* _pServer_BLE_Address[MAX_DEVICES];
String _strScanned_BLE_Address;
boolean _blnPaired;
int _intDeviceCount;
int _intPairedDeviceIndex;
static void notifyCallback(BLERemoteCharacteristic* pBLERemoteCharacteristic,uint8_t* pData,size_t length,bool isNotify)
Serial.print("Notify callback for characteristic : ");
#ifdef DEBUG_SERIAL
Serial.print(pBLERemoteCharacteristic->getUUID().toString().c_str());
Serial.print(" of data length ");
Serial.println(length);
Serial.print("data: ");
#endif
Serial.println((char*)pData);
bool connectToserver (BLEAddress pAddress)
BLEClient* pClient = BLEDevice::createClient();
Serial.println("Created client");
// Connect to the BLE Server.
pClient->connect(pAddress);
Serial.println("Connected to Pi");
// Obtain a reference to the service we are after in the remote BLE server.
BLERemoteService* pRemoteService = pClient->getService(serviceUUID);
if (pRemoteService != nullptr)
Serial.println("Found our TEMPERATURE service");
// Obtain a reference to the temperature unit characteristic in the service of the remote BLE server.
_pRemoteCharacteristic = pRemoteService->getCharacteristic(char3UUID);
if (_pRemoteCharacteristic != nullptr)
Serial.print("Found characteristic TEMPERATURE UNIT :");
if (_pRemoteCharacteristic->canRead())
Serial.print(" read (");
Serial.print(_pRemoteCharacteristic->readValue().c_str());
Serial.print(")");
if (_pRemoteCharacteristic->canWrite())
Serial.print(" write");
// So change it from the default F to C
_pRemoteCharacteristic->writeValue('C', false);
Serial.print(" (change it to 'C') ");
if (_pRemoteCharacteristic->canNotify())
Serial.print(" notify");
_pRemoteCharacteristic->registerForNotify(notifyCallback);
Serial.println("");
// Obtain a reference to the temperature characteristic in the service of the remote BLE server.
_pRemoteCharacteristic = pRemoteService->getCharacteristic(char2UUID);
Serial.print("Found characteristic TEMPERATURE :");
Serial.print(")");
Serial.println("");
return true;
return false;
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks
void onResult(BLEAdvertisedDevice advertisedDevice)
// NOTE change this for YOUR Raspberry Pi
const String MY_RASPBERRY_PI_ADDRESS = "b8:27:eb:cf:ca:ad";
if (_blnPaired == false)
Serial.printf("Scan Result: %s \n", advertisedDevice.toString().c_str());
_pServer_BLE_Address[_intDeviceCount] = new BLEAddress(advertisedDevice.getAddress());
_strScanned_BLE_Address = _pServer_BLE_Address[_intDeviceCount]->toString().c_str();
if (_strScanned_BLE_Address == MY_RASPBERRY_PI_ADDRESS)
_intPairedDeviceIndex = _intDeviceCount;
_intDeviceCount++;
if (_intDeviceCount == MAX_DEVICES)
_intDeviceCount--;
Serial.println("Maximum number of devices found");
void setup()
_blnPaired = false;
_intDeviceCount = 0;
_intPairedDeviceIndex = -1;
Serial.begin(115200);
Serial.println("ESP32 BLE Server program (for Raspberry Pi)");
BLEDevice::init("");
_pBLEScan = BLEDevice::getScan();
_pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
_pBLEScan->setActiveScan(true);
void loop()
BLEScanResults foundDevices;
foundDevices = _pBLEScan->start(5);
while (foundDevices.getCount() >= 1)
if (_intPairedDeviceIndex != -1 && _blnPaired == false)
Serial.println("Found DEVICE...connecting to Server as Client");
if (connectToserver(*_pServer_BLE_Address[_intPairedDeviceIndex]))
_blnPaired = true;
break;
else
Serial.println("Pairing failed");
break;
