jorgen larsen
How to mount a DOCKER container to LxPanel
Fri Oct 11, 2019 10:06 am
Hi
How to mount a DOCKER container to LxPanel ??
I am running a cluster of 4 * RaspBerries Pi.
I am running DOCKER engine (19.3) in SWARM mode including the following containers::
WordPress
Ningx
MySQL
For convenience I want to use LxPanel to acces my containers.
How do I mount the DOCKER containers for use with LxPanel
/Jørgen Larsen
Denmark
epoch1970
Re: How to mount a DOCKER container to LxPanel
Fri Oct 11, 2019 10:21 am
I know very little of LXDE but I suppose you can create some sort of applet that performs something like "docker service your-service-name create" (and "service rm") to start the service?
As far as accessing it, it all depends on what you've configured the network like. I assume components would be accessible via "localhost", probably also under the IP address of the node(s) in the swarm.
jorgen larsen
Fri Oct 11, 2019 12:56 pm
Some hints can be found here:
https://docs.docker.com/storage/bind-mounts/
How access the mount from LxPanel ?
Look forward to a solution
epoch1970
Fri Oct 11, 2019 1:52 pm
I am afraid I don't understand. Can't you go to the path in question using the file navigator on your Desktop?
jorgen larsen
Fri Oct 11, 2019 1:58 pm
In order to answer my question basic understanding of DOCKER is required.
Including the relation between: images, containers, volumes, binds and mount.
Return to “Advanced users”
