NPDedyukhin
WiFi Scanner
Wed Oct 09, 2019 7:20 pm
Good afternoon! :P
When we connect the Raspberry Pi to a WiFi network, we can enter a command in the console to see a list of available networks:
iwlist wlan0 scan
What should a python script look like that will do the same? :roll:
Respectfully,
Nikita Dedyukhin
gkaiseril
Re: WiFi Scanner
Wed Oct 09, 2019 7:31 pm
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
NPDedyukhin
Re: WiFi Scanner
Wed Oct 09, 2019 7:36 pm
See Executing Shell Commands with Python
Not found, error 404
Respectfully,
Nikita Dedyukhin
pcmanbob
Re: WiFi Scanner
Wed Oct 09, 2019 7:41 pm
Simple error extra character added to end of address
Try : https://linuxhandbook.com/execute-shell-command-python
NPDedyukhin
Re: WiFi Scanner
Wed Oct 09, 2019 7:48 pm
Thanks for the tip.
I figured out how to do it.
The code is as follows:
import os
myCmd = 'iwlist wlan0 scan | grep "ESSID"'
os.system (myCmd)
But now the problem is that if this script is run without using "sudo" - it gives information only about my network.
Other networks can only be seen if you start it manually using "sudo". :|
Respectfully,
Nikita Dedyukhin
peppy.player
Re: WiFi Scanner
Fri Oct 11, 2019 3:14 pm
What's the problem starting the script with 'sudo' ? Here is the example from Peppy player:
https://github.com/project-owner/Peppy/ ... il.py#L292
neilgl
Re: WiFi Scanner
Fri Oct 11, 2019 5:30 pm
And is iwlist the old command and the newer iw command has more features?
sudo iw wlan0 scan | egrep 'SSID|signal'
Return to “Python”
