knute
Need 5V for my fan, pins covered by RTC?
Tue Oct 01, 2019 9:23 pm
I've got a Pi4 in a case with a fan and a RTC that covers pins 1-6. The fan needs 5V. Is there another pin or place to get 5V on the board? What about the POE pins? I thought as a last resort I could use one of the USB ports for power but that uses up a USB that could be used for something more interesting.
trejan
Re: Need 5V for my fan, pins covered by RTC?
Tue Oct 01, 2019 9:33 pm
No. Solder to the bottom of the Pi or top of the RTC. You've already mentioned powering it via USB.
No. That is where the PoE HAT gets the PoE power from. Those 4 pins are connected to the transformers in the Ethernet socket. It feeds the 5V in via the GPIO header.
LTolledo
Fri Oct 04, 2019 9:26 am
something like this (hint: not the GPIO extenders)
Some people be like:
knute
Fri Oct 04, 2019 9:35 pm
Did you solder that to the board?
LTolledo
Mon Oct 07, 2019 12:37 pm
yup!
