scttnlsn
Minimal menu-focused GUI toolkit suggestions?
Tue Sep 24, 2019 2:27 am
I've been playing around with some small OLED screens (128x64 pixels) via Linux framebuffers. I've done some simple rendering by manipulating the framebuffer manually and via Cairo. I'm interested in finding a graphics toolkit for generating menu systems (something akin to the original iPod) where you can specify the menu structure/settings/callbacks/etc. and it returns the graphical output that you can write to a framebuffer. Do you have any suggestions?
Thanks!
Gavinmc42
Re: Minimal menu-focused GUI toolkit suggestions?
Fri Sep 27, 2019 8:37 am
I'm dancing on Rainbows.
procount
Fri Sep 27, 2019 9:36 am
uGui is a really small graphics library (in C) that supports such small displays with a framebuffer.
https://github.com/achimdoebler/UGUI
Last timeI looked it didn't support menus directly, but they should be pretty easy to implement using the graphic primitives it provides.
