HermannSW
Camera controlled automatic PT approach for a landing capturing
Thu Sep 19, 2019 7:47 pm
Two years ago I played with PT (Pan Tilt) bracket for Raspberry camera with my caterpilar robot (only the tilt part):
https://www.raspberrypi.org/forums/view ... 1#p1231151
The raspiraw based automatic tilt procedure brought camera into a defined position after starting.
Camera went up, then vertically down, and then stepwise up until black robot front became bottom of FoV:
My secondary living place in Holzgerlingen/Germany (near IBM Böblingen lab) has a nice view out of slanted roof window onto entry lane of Stuttgart airport. As a new project I wanted (as the title says) do automatic PT control for a (centered) capturing of approach for a landing. Recently I received some new 1$ PT brackets from aliexpress for that (I have some SG90 servos at home already):
As a pilot study I took a short video with Raspberry camera of an approach for a landing during dusk, with this command:
$ raspivid -t 0 -md 1 -w 1920 -h 1080 -o tst.h264 -fps 30
Then I converted it to .mp4:
$ ffmpeg -framerate 30 -i tst.h264 -c copy out.mp4
Finally I did cut out partfrom second 16 to second 44:
ffmpeg -ss 16 -i out.mp4  -t 28 -c copy out.1.mp4
And converted that to a nice (scaled down to 640x360) animated .gif using this thechnique:
http://blog.pkh.me/p/21-high-quality-gi ... fmpeg.html
I did upload the complete 2MP@30fps .mp4 to youtube as well.
In one of the first frames you can see roof top of next house and airplane at top left:
https://www.youtube.com/watch?v=sW4VpSM ... e=youtu.be
I am really happy that capturing airplane video at dusk works, and that I did capture the airplane quite well given the fact that I did it blindly with no video control during capturing.
Yesterday I took some screenshots from https://www.flightradar24.com. In this screenshot I marked the airplanes with approach for a landing at Stuttart airport (white circle) with blue circles (you can click on an airplane and get start and destination airport information). Holzgerlingen is marked with filled red circle:
As you can see there is a steady stream of airplanes landing, so automatic PT capturing might move camera to left, wait for airplane to come in sight, follow it centered until it is out of sight, and then repeat.
Today was a good pilot study, more to come.
P.S:
This is a good "slow speed" (the servo motors, not the airplanes) live camera video processing excercise before doing live camera video processing to control high speed caterpillar robot.
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://twitter.com/HermannSW
Re: Camera controlled automatic PT approach for a landing capturing
Fri Sep 20, 2019 2:15 pm
Get yourself a RTL-SDR USB radio and a copy of PiAware. From that you can get JSON for every aircraft in your local area - with speed, heading, altitude and lat/lon.
This is a doctor free zone.
HermannSW
Sat Sep 21, 2019 2:19 pm
While that sounds interesting, it does not help to get centered video of each approach for a landing.
And this project will be an exercise on life video frame feature extraction and live control of PT camera.
When capturing blinking plane in dusk will work (easier), next step could be capturing airplane at daylight as well.
HermannSW
Wed Oct 02, 2019 5:56 pm
Today I was at secondary living place earlier, at daylight. And I took video of airplane that did take off in Stuttgart with destination Milan, when passing Holzgerlingen. This time with smartphone camera, so audio is available:
https://www.youtube.com/watch?v=Akf9BqgvXac
It is better to capture airplane at daylight (dark dot before bright background) than capturing only airplane lights in darkness. I will try to use 3.98° M12 mount lens to see more from the plane (if PT platform can handle 70mm lens weight):
"70mm F1.6 3.98° lens allows for clear 500m distant video"
https://www.raspberrypi.org/forums/view ... p?t=227166
HermannSW
Fri Oct 11, 2019 4:58 pm
I just measured the weight of v1 camera with 70mm M12 lens mounted as 19.1g.
Not sure whether PT bracket can carry that and function as well:
I don't know the shortest distance between secondary living place slanted roof window and a passing airplane.
But in "WoodenBoardPi" thread I just made photo with 70mm lens showing house of my friend 1.73km distant !
This is promising for "automatic capturing of airplane" size on image and quality.
(passing airplanes feel to be closer than 1.7km at shortest distance)
https://www.raspberrypi.org/forums/view ... 9#p1550469
HermannSW
Sat Oct 12, 2019 2:18 pm
I am not in Holzgerlingen right now, but flightradar24 allowed me to watch some departures from Stuttgart airport.
Four airplanes heading to southeast Europe or Italy took the lower trajectory, but the Airbus A319 to Lisbon took the upper trajectory:
I constructed the trajectory from two known points in gmaps pedometer in order to find the minimal distance point, marked with blue above. The distance to my slanted roof window is 1.46km. Assuming that airplane is still below 1km height the total distance is slightly more than to the house of my friend in previous posting [sqrt(1.46^2+1^2)=1.77]. Airbus A319 has length 34m, perhasp 3 times the width of my friends house. Fuselage height is 4m, a little less than 2 floors of my friend's house.
Expected size of airplane is roughly 300 pixel width and 60 pixel height -- we will see later how good this rule of a thumb calculation matches real airplane captures:
P.S:
Just building PT camera system. Controlling two SG90 servos with pigpio pigs library is so simple:
"flag_semaphore att rest R A S P B E R R Y ready"
https://www.raspberrypi.org/forums/view ... 7&t=254180
HermannSW
Wed Oct 16, 2019 10:37 pm
Initial build of PT camera system with 70mm done.
First I missed matching gearwheel connector for ground plate.
As workaround I did simply superglue the existing connector to desk.
Two drops of superglue to Raspberry camera module connector.
And some superglue on top plastic line of bracket, connect camera to PT (Pan Tilt) camera platform easily:
Next question got answered whether PT system can deal with 70mm long lens -- it can:
I forgot to take 3 needed male/female connector cables to connect at least one SG90 servo with me.
This is a real hack, just using what I have here:
https://www.youtube.com/watch?v=Tt7uMuvfItk
With that working, next problem was that I cannot get any sharp image inside room with that lens, and it is dark outside.
So I decided to take a video for patrolling the underside of window curtain ;-)
Not sharp video inside room, but works.
First I started raspivid to capture 25s of 1920x1080 video at 30fps:
pi@raspberrypi2B:~ $ raspivid -md 1 -w 1920 -h 1080 -fps 30 -t 25000 -o tst.h264
Then I started endless patrolling (after having started "sudo pigpiod"):
pi@raspberrypi2B:~ $ while true
> do
> for((i=1180; i<1450; ++i)); do pigs s 18 $i; done
> for((i=1450; i>1180; --i)); do pigs s 18 $i; done
> done
This is resulting video, uploaded to youtube, played at 25fps, 0.833 times slower than real:
https://www.youtube.com/watch?v=bYRJ0Ie1alU
Return to “Camera board”
