fti74
Raspberry pi 4 | Unable to force sound through jack
Fri Sep 13, 2019 9:35 pm
on one of my raspberry PI 4, I can't get audio through the 3.5mm jack (I don't know if 'm getting any audio through DMI)
I have forced the audio to go through the jack (using raspi-config):
sudo amixer cset numid=3
numid=3,iface=MIXER,name='Master Playback Volume'
  ; type=INTEGER,access=rw------,values=1,min=0,max=65536,step=1
  : values=1
I can't get any audio from the usual apps: VLC, Chromium...
Sound works fine from another PI and also when using:
omxplayer -o local sample.mp3
As I don't hear a thing with:
omxplayer sample.mp3
this means I can rule out any cable/speaker issue.
I have checked with alsa-mixer, the volume isn't set to 0 (same with the desktop widget).
I have to admit I can't think of anything else.
Re: Raspberry pi 4 | Unable to force sound through jack
Fri Sep 13, 2019 11:21 pm
Run sudo rpi-update; sudo reboot. There's a fix for analog audio in today's update.
This is a doctor free zone.
