kasek
Music player
Fri Sep 13, 2019 8:34 pm
Hey got a raspberry pi 4 and want to install a music player like iTunes that will load my songs in a library. What works and do you have a guide most guides I’ve seen r for pi 2 or 3 not sure if there is a difference
epoch1970
Re: Music player
Fri Sep 13, 2019 9:12 pm
I would recommend piCorePlayer, which wraps piCore linux, Logitech Media Server, Squeezelite, etc. in an easy to live with package. Excellent support for the Pi platform and available audio HATs.
https://www.picoreplayer.org
If you target using a Pi 4, you need a beta release.
kasek
Re: Music player
Fri Sep 13, 2019 10:08 pm
Thanks how would I install it from that zip? Do I have to use commands in terminal or
Andyroo
Re: Music player
Fri Sep 13, 2019 10:32 pm
You would use Etcher or similar to create the SD as this includes the operating system as well as all the programs.
This is not Raspbian but a slightly different version of Linux and the SD card would be dedicated to this task.
Note: This will delete everything off that SD card.
Need Pi spray - these things are breeding in my house...
kasek
Re: Music player
Fri Sep 13, 2019 11:04 pm
Do you know of an alternative that doesn’t do that? I’m using the pi as a work station at work and it’s already all set up was just hoping to install an app
epoch1970
Re: Music player
Sat Sep 14, 2019 1:13 pm
Well there is a media player built in the Desktop version of the distribution AFAIK. It does video, so it does audio.
kasek
Re: Music player
Sat Sep 14, 2019 4:45 pm
I’ve only seen vlc media player, but I’m looking for something I could load my library into
Re: Music player
Sat Sep 14, 2019 5:04 pm
Where is your Music Library stored at present ??
Retired disgracefully.....
gordon77
Re: Music player
Sat Sep 14, 2019 6:28 pm
You might like to try this python script l've been working on...
https://github.com/Gordon999/Pi-MP3_Player
It will work on a pi and desktop monitor.
W. H. Heydt
Re: Music player
Sat Sep 14, 2019 6:40 pm
I'm pretty minimalist. I use mplayer and write shell scripts so I don't have to remember all the command line options. Recorded tracks are either stored in a directory on the boot media, or on a USB stick. It also serves to stream programming off the 'net, specifically, our local classical radio station.
kasek
Re: Music player
Mon Sep 16, 2019 2:41 pm
Currently USB drive but I have to select all the music to play it, was wanting just a program open it and hit pl ay
kasek
Re: Music player
I’ll take a look thanks
BluPI2
Re: Music player
Sun Sep 22, 2019 3:59 am
I believe Rhythmbox will suit your needs
It supports multiple Playlists and importing of Music Libraries
Just run in a terminal window:
sudo apt-get update
sudo apt-get install rhythmbox
Rhythmbox is a very easy to use music playing and management program which supports a wide range of audio formats (including mp3 and ogg). Originally inspired by Apple's iTunes, the current version also supports Internet Radio, iPod integration and generic portable audio player support, Audio CD burning, Audio CD playback, music sharing, and Podcasts.
Owner of a Raspberry Pi 2B, 3B, and 3B+
Return to “Beginners”
