leafry
Joining pi's on a home network
Fri Sep 13, 2019 7:22 pm
Hey everybody. I have a trio of pi zeros that are retrieving some stats and I want to network join them on my home network so that a larger server (most likely a pi 4) can consume that data and return the results to a web app. I'm a little new to Linux and pi's, what would be my best bet in creating a domain to address the machines by computer name over the network instead of IP since that is most likely to change if the router assigns them a new one?
Andyroo
Re: Joining pi's on a home network
Fri Sep 13, 2019 7:32 pm
I assume you have a Pi Zero W as the Pi Zero does not have any network connections.
First thought:
A) Check the router and reserve a range of IP addresses that the router does not issue out to devices
B) Set up dhcpcd.conf to use an address in that range (static)
Second thought:
A) Find the MAC address of each Pi from the router and reserve an IP address on the router for that MAC address
Note: it is vital that you change the Pi name using
sudo raspi-config
As you should never have two computers with the same name on the same network.
I also add this into dhcpcd.conf now to make sure for WiFi routers (the EE one I have is a bit naff in this respect).
So, my questions are:
1) Are these boards Zeros or Zero Ws - accuracy is key :lol:
2) How we’ll do you understand your router config screens?
3) What type of router do you have (and do you have the admin password)?
Need Pi spray - these things are breeding in my house...
leafry
Fri Sep 13, 2019 7:41 pm
Haha for sure, accuracy is key.
1) Yes, these are Zero W's, sorry for any confusion. They are joined over wifi.
2) Not very well, but I can learn.
3) I have an orbi rbk30 bridged to a router my isp has given me. I have the admin password for both.
Andyroo
Fri Sep 13, 2019 8:18 pm
I would set each Pi up first and give them a unique name in that case.
Does the router or the Orbi give out IP addresses do you know?
leafry
Fri Sep 13, 2019 8:19 pm
Yeah, from what I understand it is what is distributing the IP addresses.
neilgl
Fri Sep 13, 2019 9:56 pm
Maybe just install mqtt on the three pi zeros and set the pi4 up as an mqtt server (mqtt broker). Then feed the data to influxdb on the pi4 and graph it with grafana on the pi4 - which you can see on a web page. That is what I do.
Andyroo
Fri Sep 13, 2019 10:15 pm
:?: the router or Orbi?
neilgl
Fri Sep 13, 2019 10:32 pm
And set the pi4 mqtt server (mqtt broker) to have a fixed ip address in your router. The other pis can then use that - they dont need a fixed ip.
Andyroo
Fri Sep 13, 2019 11:54 pm
Technically NONE of them need static IPs as you can connect to an MQTT broker by name...
leafry
Sat Sep 14, 2019 12:23 am
The orbi should be distributing IPs. Also, I've never heard of MQTT until now. That sounds very interesting. Just to be sure, how reliable is the MQTT method mentioned? In the future as a fyi, I would like to extrapolate the data I'm collecting and display it in a web app that will run on the Pi 4 that I can then access through my phone or some other machine.
W. H. Heydt
Sat Sep 14, 2019 2:47 am
While your assumption turned out to be correct, it didn't have to be...https://www.monoprice.com/product?p_id=9466
Andyroo
Sat Sep 14, 2019 12:39 pm
MQTT is very reliable and you can set 'last will and testament' messages if the Pi locks / dies and even basic messages can have different service levels to increase reliability if needed. See http://www.steves-internet-guide.com for a good introduction to MQTT
As for the original request :lol:
Going by https://community.netgear.com/t5/Genera ... -p/1655446 you may not be able to set static IP addresses on the network but as I do not have one I cannot check for you. I did see that there are two apps for setting these up - it may be worth hunting the second app and see if that gives you more control.
So for now, I would avoid static addresses for every computer and set every machine up as dynamic addresses and refer to each machine by name or name.local if the network supports that correctly.
leafry
Sat Sep 14, 2019 6:47 pm
Awesome!!! Thank you so much for your help. This gives me a great idea of where I need to start. I will come back if I have any issues setting anything up. I was able to review some documentation on the MQTT service last night and it looks very straight forward. Again, thank you for all your help everybody.
Sat Sep 14, 2019 8:38 pm
Steve's Internet Guide is brilliant for MQTT.
There's also some good education materials at https://www.hivemq.com/mqtt-essentials/
This is a doctor free zone.
Return to “Beginners”
