Sulforaphane
EXT4 not mounting on boot.
Fri Sep 13, 2019 7:18 pm
Hello.
It has all been working fine until now, when I rebooted.
I have edited my fstab file to include the ID so it mounts to the same folder at startup, but everytime i reboot, it doesn't remount.
Actually I can't even find the entry when typing df in the terminal.
However, when I remove the fstab entry and reboot, it appears again and I can mount it manually.
Here is the entry:
UUID="ID-XXXXXXXXXXXXXXXX" /disks/location  ext4  defaults,auto,rw,nofail 0 1
Andyroo
Re: EXT4 not mounting on boot.
Fri Sep 13, 2019 7:36 pm
It’s possible the disk is not ready by the time the fstab is read.
Try a reboot with the line in and then run
sudo mount -a
and see if that works.
This will show any errors as it tries to mount the drive.
By the way - no need to hide the UUID - we cannot get to the device and it can make it harder to debug issues when checking things.
Need Pi spray - these things are breeding in my house...
Sulforaphane
Fri Sep 13, 2019 7:38 pm
sudo mount -a
It gives me an error, saying the partition is busy... Ok thanks for letting me know!
Sulforaphane
Fri Sep 13, 2019 11:25 pm
sudo mount -a
this is the verbatim output:
mount: /disks/linus: /dev/sda1 already mounted or mount point busy.
Andyroo
Fri Sep 13, 2019 11:52 pm
Anything else in fstab - can you pop it all on here?
Can you run
blkid
Sulforaphane
Sat Sep 14, 2019 2:51 am
Can you run
blkid
I can.
proc            /proc           proc    defaults          0       0
PARTUUID=02166231-01  /boot           vfat    defaults          0       2
PARTUUID=02166231-02  /               ext4    defaults,noatime  0       1
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
UUID=f9df3404-3a6a-d231-f01f-36784c6xd921 /disks/linus  ext4  defaults,auto,rw,nofail 0 1
Sulforaphane
Sat Sep 14, 2019 3:13 am
Can you run
blkid
Actually I can't run the BLKID, and a proces called fsck.ext4 seems to be taking a bit of CPU power while the drive is spinning.
However, it does not appear in the mount I specified.
This is the error:
Sulforaphane
Sat Sep 14, 2019 3:31 am
Also something weird:
Device     Start        End    Sectors  Size Type
/dev/sda1   2048 3906961407 3906959360  1,8T Microsoft basic data
When typing lsblk -f (it's definitely an ext4 format, and I have been able to mount it before. But it's formatted in Windows)
Return to “Beginners”
