JonnyAlpha
Raspberry Pi Certified Educator
Raspberry Pi 4 Recommended Mobile Power
Fri Sep 13, 2019 2:36 pm
Hi;
We are updating our Pi Jam equipment and have decided to get 10 x Pi 4s. Along with these we are getting a couple of CamJam Robotics kits, however I need some advice on what power packs to buy to enable the Pi and the Robotics kit to be mobile.
I have used the CamJam kits before with a Pi 3 and used a these 5000mAh USB packs
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
But I have heard the Pi 4 is more power hungry so hence the advice request.
The robots will only be used for the duration of the Pi Jam (1 hour or so) so don't need to last too long before needing a re-charge?
Raspberry Pi Certified Educator. Main Hardware - Raspberry Pi 1 model B revision 2, Raspberry Pi 2 model B, Pi Camera
Re: Raspberry Pi 4 Recommended Mobile Power
Fri Sep 13, 2019 3:18 pm
Buy the official power supply. That's guaranteed to work with a RPi4B (any flavour).
This is a doctor free zone.
rpdom
Fri Sep 13, 2019 3:41 pm
Oh yes, and run extension leads to each of the robots. :lol:
Fri Sep 13, 2019 3:44 pm
Sorry, I read "mobile" as meaning "phone".
W. H. Heydt
Fri Sep 13, 2019 4:19 pm
Step 1. Determine the actual power requirement for your setup. The max power for a Pi4B is 3A @ 5v, but that includes 1.2A for USB devices. Your actual requirements may be less.
Step 2. Determine the power output (W) and energy capacity (Wh) of your proposed supply.
Step 3. Make sure that the output in Step 2 meets or exceeds the requirements in Step 1.
Step 4. Make sure that the total available energy capacity meets or exceeds the power from Step 1 times the desired duration.
JonnyAlpha
Fri Sep 13, 2019 4:51 pm
Thanks all :-)
diogen151
Sat Sep 14, 2019 6:37 am
Most power banks have overestimated capacity.
It's more convenient to use two Panasonic NCR 18650 batteries with real 3400mAh capacity; in parallel this configuration give more than 6 Ah.
This mean to buy apropriate power bank electronic; this one I've testes in several projects with succes.
https://www.aliexpress.com/item/3296822 ... 4c4d9w4RqS
You can use USB 5V output as well as separate 5 V pins for soldering output wires.
RPi 2b MotionEyeOS; RPi3b OMV 3; RPi 3b+ OMV 4; RPi 3b+ TVHeadend + desktop, RPi 3a+ MotionEyeOs; RPi 4b - everything else ;-)
W. H. Heydt
Sat Sep 14, 2019 6:55 pm
I think the bigger issue is that Li Ion/LiPo rating are given in Ah without stating that that is at 3.7v (nominal). That's why I spend so much time recommending that people convert everything to Watts (W) and Watt-hours (Wh) when figuring battery capacities and run times. Thus a 4Ah "powerbank" has 14.8Wh. A Pi that is going to require 2A needs 10W. So that battery has an expected run time of just under 1.5h, then adjusting for losses, it would probably be more like 1.2h. (Ignoring the fact that a 4Ah "powerbank" won't actually deliver 2A.)
diogen151
Mon Sep 16, 2019 1:06 pm
Yes, the problem is efficiency of step-up (booster) converter; it is hard to expect more than 80 % i.e factor of 0,8 for small cheap products.
Final calculation , therefore should be something like this:
(Wh capacity of power bank/ required W) * 0,8 will give approx. running hours.
I've made solar -powered RPI 3b+ with 20W solar-panel and 6,6 Ah LiPo single cell battery for storage. After 6 p.m. sunlight became insufficient for supplying, sunset was at 8 p.m, and I never reach 11 p.m. with running 3b+ (loaded only with pi-cam)
Imperf3kt
Mon Sep 16, 2019 9:49 pm
I believe step one should be "re-assess upgrade requirements"
A Pi Zero should handle the tasks OP mentions, and will last much longer on a battery than any other model Pi will.
As an analogy, it'd be like taking a jet powered hypercar to go grocery shopping.
Is there a specific reason the Pi4b must be used?
55:55:44:44:4C
52:4C:52:42:41
W. H. Heydt
Mon Sep 16, 2019 11:52 pm
That may simply be similar to the old remark about climbing mountains...because it is there. But, then, other than a Pi3A+ (which is overkill for what it's doing), I don't use batteries to power anything past a Pi2Bv1.1
Return to “Advanced users”
