40Alpha
GPIO pin turns off immediately when switch is connected, turns back on when disconnected
Thu Sep 05, 2019 3:14 am
I have no problem turning on and off pins on my rpi4 (using both gpio on the terminal and Gpiozero with python3) however when I connect a wire (which is connected to a switch) to the pin... it turns the pin output to 0. When I disconnect, it goes back to 1.
What is the deal here? When I take the connection and attach it to an always on 5V pin - the turns on!
Any thoughts?
Imperf3kt
Re: GPIO pin turns off immediately when switch is connected, turns back on when disconnected
Thu Sep 05, 2019 5:24 am
You didn't connect a GPIO pin with the 5v pin did you? Because that's certain death for a Pi.
55:55:44:44:4C
52:4C:52:42:41
Burngate
Thu Sep 05, 2019 10:25 am
I'm not sure I understand your description.
... so you've set the GPIOs to ouput, and you can set them to 0 (gnd) or 1 (3v3) at will.
How are you checking they do what you want? A meter? a LED and resistor?
... that is only useful if you set the GPIO to input
Are you using a different pin from the first ones?
Also, what's on the other end of the switch?
pcmanbob
Thu Sep 05, 2019 3:13 pm
Hi.
Might I suggest you have a look at the physical computing guide for python https://projects.raspberrypi.org/en/pro ... -computing
this will guide you through connecting switches to gpio inputs and things like LED's to gpio outputs.
