peppy.player
Server starts on wrong IP
Tue Aug 20, 2019 4:26 am
I'm trying to start web server (Tornado) on Raspbian Buster. I suspect that the order of 'lo' and 'eth0' causes the issue during server startup. I don't specify IP address explicitly. So I guess server takes the first from the top of the list. As a result it starts on address 127.0.1.1 and I cannot access it from outside. Is there any way to change the order? Here is the current one:
pi@raspberrypi:~ $ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:49:1f:bc brd ff:ff:ff:ff:ff:ff
    inet 10.0.0.11/24 brd 10.0.0.255 scope global noprefixroute eth0
    inet6 2601:648:8500:41e0::88ac/128 scope global dynamic noprefixroute
       valid_lft 604745sec preferred_lft 604745sec
    inet6 2601:648:8500:41e0:eadb:5904:98f4:b6df/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 260931sec preferred_lft 260931sec
    inet6 fe80::865a:3657:fae5:88d6/64 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether b8:27:eb:1c:4a:e9 brd ff:ff:ff:ff:ff:ff
Re: Server starts on wrong IP
Tue Aug 20, 2019 6:46 am
It doesn't matter.
All addresses from 127.0.0.1 to 127.255.255.254 work as loopback.
This is a doctor free zone.
hortimech
Tue Aug 20, 2019 8:01 am
Problem is that '127.0.1.1' doesn't appear in your output from 'ip a'
Try looking in /etc/hosts, I think you will find something like this:
127.0.0.1	localhost
::1		localhost ip6-localhost ip6-loopback
ff02::1		ip6-allnodes
ff02::2		ip6-allrouters
127.0.1.1	raspberrypi
If you are using dhcp, just comment the '127.0.1.1' and it will start to use the dhcp supplied IP
peppy.player
Tue Aug 20, 2019 3:24 pm
Thank you for replies!
Another part of my code caused the confusion. After starting web server I print to console host an port:
logging.debug("Web Server Started at %s:%s", host, port)
I get host this way:
host = socket.gethostbyname(socket.gethostname())
That returned 127.0.1.1 but server was actually started on 10.0.0.11 as expected.
I just need to find a way to get real host from the server.
Thanks!
hortimech
Tue Aug 20, 2019 4:54 pm
I just told you how to, comment '127.0.1.1' out in /etc/hosts, it will start using the correct IP supplied by dhcp, this comes up fairly frequently on the Samba mailing list.
peppy.player
Wed Aug 21, 2019 3:18 am
As I mentioned the problem was in this line:
It returned 127.0.1.1 which was wrong/confusing as Tornado server actually started on 10.0.0.11
The server starts on the same address 10.0.0.11 no mater if I have that line in /etc/hosts or not. If I delete that line the code above throws exception as hostname 'raspberrypi' doesn't exist anymore.
Andyroo
Wed Aug 21, 2019 8:59 am
The name raspberrypi is only part of a system name and should have a domain as well as the machine name.
Raspbian uses avahi so by default will use the domain ‘.local’ so technically the machine is known to DNS as raspberrypi.local and often with home networks it will register itself with the DHCP server as that performs the DNS function.
By putting an entry in the HOSTS file you are bypassing the DNS and getting away with not using the domain name :D
hortimech
Wed Aug 21, 2019 11:15 am
And I told you to comment the '127.0.1.1' line in /etc/hosts and this will fix your problem, with '127.0.1.1 raspberrypi' in /etc/hosts
pi@raspberrypi:~ $ hostname -i
127.0.1.1
Change it to '#127.0.1.1 raspberrypi'
192.168.0.146
peppy.player
Wed Aug 21, 2019 3:16 pm
I'm using the latest upgraded/updated Raspbian Buster OS. If I have the line
in /etc/hosts:
127.0.1.1
If I comment out or delete that line:
hostname: Name or service not known
Python code throws the exception with the same message: Name or service not known
RaTTuS
Wed Aug 21, 2019 3:21 pm
you'll need to reboot after editing hosts
Covfefe
peppy.player
Wed Aug 21, 2019 4:17 pm
Sure, I did that.
hortimech
Wed Aug 21, 2019 7:00 pm
I am also running the latest Raspbian and it works for me, so there must be something else going on here. How is the ipaddress being set ?
Is it a static ip or is it set via dhcp. If the latter, it should work, but if is a static IP, then don't comment the line, but change '127.0.1.1' to the static IP.
