phase
power rpi-4 via the 40 pin header
Thu Aug 08, 2019 8:09 am
how do i go about powering the rpi-4 via the header pins..
does powering the board in this manner bypass any circuitry at all..???
.if somebody could point me to a thread or if it`s in a sticky i cannot find it..thanks...
joan
Re: power rpi-4 via extension header
Thu Aug 08, 2019 8:36 am
You can't power the Pi via the GPIO. You will destroy the Pi.
You can power the Pi via the 5V and ground pins on the extension header.
https://pinout.xyz/
phase
Re: power rpi-4 via the 40 pin header
Thu Aug 08, 2019 8:46 am
thank you ..ok i will do it ,,i fixed my question..
davidcoton
Thu Aug 08, 2019 8:52 am
The Pi4 appears not to have a polyfuse, so there is no protection to bypass. There is still overvoltage/reverse polarity protection, so you should consider providing your own polyfuse between supply and Pi.
Signature retired
phase
Thu Aug 08, 2019 9:29 am
would a 6.3 volt zenner to gnd be ok or a 5.1 and an in4004 in series to give 5.7 volts to gnd using 1 watt devices and an inline 3.15 amp fuse..
i dont know where i could get a 6 volt polyfuse from..??...or 5 volt for that matter
Burngate
Thu Aug 08, 2019 9:35 am
There's a SMBJ - effectively a zener, etc. - on board, so you won't gain by providing your own.
Davidcotton is suggesting you provide a fuse that can blow when you trigger the SMBJ by doing something wrong.
Polyfuses can handle 6v and upwards. You need to choose one that can handle the full current that the Pi will take, but will blow at the higher current that the SMBJ will take when triggered, preferably before the SMBJ dies.
rpdom
Thu Aug 08, 2019 9:50 am
Fuses work on current (Amps) not voltage, even though they do frequently have maximum working voltage ratings for safety reasons.
phase
Thu Aug 08, 2019 11:09 am
ok all the above taken into account ..can anybody tell me the max current that the rpi-4 can consume..pls..
Thu Aug 08, 2019 11:10 am
The official power supply is rated at 3000mA.
This is a doctor free zone.
Thu Aug 08, 2019 11:27 am
https://www.raspberrypi.org/documentati ... /#pi-power
Retired disgracefully.....
dzyner
Wed Jan 15, 2020 4:19 pm
Thought I'd post this here since it took me several hours to figure out, and a lot of folks saying it wasn't possible with Pi 4B to direct power through the 40 Pin GPIO. As you can see, assuming you've applied the proper Buck Converter to step down the power into the Pi (mine is connected from my 3D printer's power supply so I can power everything off with one switch), it certainly does work using pins 2 and 6. Whether or not this means my device "could" be damaged by doing this I do not know, but for now it is working fine so apparently they did not disable the ability to power the Pi via the GPIO connectors like many are saying.
Having said that, if you see something that I'm doing incorrectly or that could be very dangerous, please let me know since I am indeed a novice to the world of Raspberry Pi.
rpdom
Wed Jan 15, 2020 5:44 pm
I don't know where you've seen that. It's common knowledge that the Pi 4B can be powered via the "GPIO" header if you supply a stable 5V with sufficient current to the correct pins. After all, that's how the official PoE HAT does it.
davidcoton
Wed Jan 15, 2020 10:34 pm
The only thing to be aware of is that the Pi's power protection relies on the PSU to limit the fault current to below 5A. So if you use a PSU/converter with a higher current capacity, you should include a 3A polyfuse (or equivalent protection).
Note that, unlike Pi1,2,3, the Pi4 does not have an on-board polyfuse even for the USB power input. So this advice applies whichever way your power gets on to the Pi4B.
Signature retired
dzyner
Thu Jan 16, 2020 12:02 am
In this very thread and others (link below to another topic on this forum). Second post in this thread specifically reads, "You can't power the Pi via the GPIO. You will destroy the Pi."
Here's another thread on this forum where it also mentions it isn't possible through the GPIO pins...
https://www.raspberrypi.org/forums/view ... p?t=248280
Perhaps I'm misunderstanding terms being noted in these posts, but regardless just thought I'd be helpful and point out that it does work.
drgeoff
Thu Jan 16, 2020 12:20 am
GPIO means General Purpose Input/Output. The GPIOs are signal pins. You cannot power a RPi though signal pins.
The 40 pin GPIO header has both GPIOs and power pins. You can power any RPI through those power pins. On a RPi4B those pins are electrically commoned with the power input contacts of the USB-C socket.
hippy
Thu Jan 16, 2020 2:12 am
In this very thread and others ... Second post in this thread specifically reads, "You can't power the Pi via the GPIO. You will destroy the Pi."
That's because some people take "powering via GPIO", "powering via GPIO pins" to mean something other than "powering via the 0V and 5V pins which are present on the GPIO header".
I would normally assume that's what the poster meant, but others take it more literally.
dzyner
Thu Jan 16, 2020 5:14 pm
I would agree with that, which is why it was so challenging for me to find the answer I needed, because I'm new (like many) to Pi and may not know the lingo yet. As a laymen, immediately when I read the OPs post in these threads I knew what they were asking. Yet the answer was consistently "not possible" or similar. I figured I'd do some newbies like me a favor and post my pics and explanation in case someone else finds this post (and they will) looking for the same answers - save them hours of research.
emma1997
Thu Jan 16, 2020 6:07 pm
What's ironic is it's quite common for beginners to accidentally power boards via IO bits. Current flows through reverse biased clamp diodes. Only those MCU with protection diode though which is not the case for Pi which does not have those.
Anyway language corrupts evolves so most people should know what "power via GPIO" means by now.
Return to “Beginners”
