jeff_pimenta
Install Java7 on Raspian buster
Fri Aug 02, 2019 7:30 pm
Hello all,
I'm trying to run an application on RPI B+, but this application requires Java 6 and tomcat6. After some research i found that this app run on java7 and tomcat7.
I couldn't install Java7 on RPI via apt-get install openjdk-7-jdk or try to download via https://www.oracle.com/technetwork/java ... 21261.html
First option i got: openjdk-7-jdk : Depends: openjdk-7-jre (= 7u221-2.6.18-1~deb8u1+rpi1) but it is not going to be installed
Second one i try to run "update-alternatives --config java" and get "There is only one alternative in link group java (providing /usr/bin/java): /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/java
Nothing to configure."
I try to install Java using this link https://www.guru99.com/how-to-install-j ... buntu.html and downloading "jdk-7u75-linux-arm-vfp-hflt.tar.gz" from Oracle.
My sources.list file is:
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
deb http://raspbian.raspberrypi.org/raspbian/ oldstable main contrib non-free rpi
deb http://raspbian.raspberrypi.org/raspbian/ oldoldstable main contrib non-free rpi
deb http://mirrordirector.raspbian.org/raspbian/ oldstable main contrib non-free rpi
deb http://mirrordirector.raspbian.org/raspbian/ oldoldstable main contrib non-free rpi
deb http://archive.raspbian.org/raspbian wheezy main contrib non-free
deb http://archive.raspbian.org/raspbian oldstable main contrib non-free
deb http://archive.raspbian.org/raspbian oldoldstable main contrib non-free
I have add some other repositories to try to get java package direct by apt install, but i have no success. Btw, the application is "ScadaBR"
Re: Install Java7 on Raspian buster
Fri Aug 02, 2019 9:30 pm
Hello all,
You can not mix sources from different Raspbian versions.......
....there are major differences between Raspbian Wheezy, Jessie, Stretch and Buster.
adieu
knute
Sat Aug 03, 2019 8:04 pm
tomcat 8 and 9 are available for Buster. Java 11 is the standard on Buster. Can you not run tomcat with Java 11? Java 8, 9, and 10 are also available for Buster.
jeff_pimenta
Tue Aug 06, 2019 3:05 pm
The main problem is because the application does not suport newer versions of java. Tomcat works just fine for me, but the application does not work property.
Any ideas about how to downgrade? Even manually.
Btw, the application is ScadaBR and ScadaLTS.
Tue Aug 06, 2019 3:13 pm
What is the model of Raspberry Pi is it 1B+ or 3B+ ??
adieu
jeff_pimenta
Tue Aug 06, 2019 7:42 pm
B version 1.2
Edited: I have one rpi 3 B and B+, either works for me
Tue Aug 06, 2019 7:50 pm
B version 1.2
Try Raspbian Jessie on the 3B ??
http://downloads.raspberrypi.org/raspbi ... 017-07-05/
adieu
jeff_pimenta
Tue Aug 06, 2019 8:07 pm
I have tried a older version without success.
Any ideas for manual instalation?
knute
Tue Aug 06, 2019 10:42 pm
When you attempt to run it under Java 8 what errors are you getting?
Java 7 is so far beyond end of life that without going back to a much older version of Raspbian you probably aren't going to get it to run and then you are going to run into problems getting the old version of Raspbian to run on your Pi3.
Did you try the installing Java 7 from the Oracle archive?
Wed Aug 07, 2019 5:25 am
Yes that is extremely helpful diagnosis !!!
Please contact the software developers to update their software or find an alternative.
adieu
jeff_pimenta
Wed Aug 07, 2019 7:47 pm
Nevermind, i did it installing direct from old archives from oracle.
Use this link
https://www.javahelps.com/2017/09/insta ... linux.html
And to set env variables i miss the link i use
Magenet
Contact: ICQ AOL Skype
Fri Aug 23, 2019 9:16 pm
Search the forum, there are many threads about wifi and Debian buster.
Or you could say what have you done, and what errors did you get.
Return to “Java”
