RonR
Image File Utilities
Thu Aug 01, 2019 9:12 pm
Attached are several utilities I created and use to manipulate image files.
image-backup:
image-backup creates a backup of a running Raspbian system to a standard 'raw' image file that can be written to an SD card or a USB device card with Etcher, imageUSB, etc. It will also perform incremental updates to an existing backup image file.
Running image-backup with no parameters will create a full backup. To create the smallest possible image, specify an Image ROOT filesystem size of 0 to determine the minimum allowed size. If you plan to incrementally update the image file, specify a considerably larger size to allow for additional growth.
Running image-backup with a parameter of an existing image filename will incrementally update that image file.
Image-check:
image-check will check the integrity of a standard 'raw' image file. Usage is:
image-check imagefile [W95|Linux]
where W95 checks the BOOT partition and Linux checks the ROOT partition. If neither is specified, Linux is assumed.
image-compare:
image-compare compares a running Raspbian system to an existing standard 'raw' image file and displays the incremental changes that image-backup would perform if run. Usage is:
image-compare [imagefile]
image-mount:
image-mount mounts a standard 'raw' image file to allow it to be read or written as if it were a device. Usage is:
image-mount imagefile mountpoint [W95|Linux]
where W95 mounts the BOOT partition and Linux mounts the ROOT partition. If neither is specified, Linux is assumed.
image-set-ptuuid:
image-set-ptuuid sets the Partition Table UUID value of a standard 'raw' image file. Usage is:
image-set-ptuuid imagefile ptuuid
where ptuuid is 8 hex digits
image-shrink:
image-shrink shrinks a standard 'raw' image file to its smallest possible size (plus an optional additional amount of free space). Usage is:
image-shrink imagefile [Additional MB]
where Additional MB is an additional amount of free space to be added.
image-utils.zip
(8.95 KiB) Downloaded 55 times
rin67630
Re: Image File Utilities
Tue Aug 13, 2019 4:40 pm
Super! very useful applets!
Could you please tell me where to put the unzipped files? Just in /home/pi)?
Are they executable directly or must we first chmod them?
A detailed noob-proof description of what to do would really be useful.
Thank you!
RonR
Wed Aug 14, 2019 12:56 am
They're not picky about where you place them (/home/pi would be fine). You must make them executable (chmod +x ...).
I'll try to write up a few examples shortly.
itsmedoofer
Wed Aug 14, 2019 11:19 am
Again, fantastic work, really appreciated !
scruss
Sat Aug 24, 2019 4:57 pm
They could also go in ~/bin (that's /home/pi/bin). Raspbian automatically adds ~/bin to your path at login if the folder exists.
mkdir ~/bin
is all people need to create it. The system will add it to your path the next time you login or reboot.
RonR — thanks very much for writing these. I see that some older links have expired and people can't seem to find them, so I created a github repo of your code as of 2019-08-01: RonR-RaspberryPi-image-utils. I hope that's okay with you.
I've also stored a copy of the attachment on the Internet Archive so it should stick around better.
bls
Sat Aug 24, 2019 6:40 pm
image-mount is particularly sweet! Takes away all the hassle of mounting an SD card image. Thanks!
RonR
Sat Aug 24, 2019 6:58 pm
Thanks for the feedback.
I use image-mount every time a new Raspbian image is released to inject an ssh and/or wpa_supplicant.conf file into the image file. Then I don't have to manually add them to the SD card or USB device each time I write one. It's also handy for extracting files from an image file created by image-backup.
bls
Sat Aug 24, 2019 7:13 pm
That's great! I never thought of that approach. Mine is slightly different. I have a script that adds all my stuff (scripts, config files, etc) to a newly-built SD card. I then boot it and install the packages I want. At that point I dd that beautiful SD card to an IMG file and use it for building new 'virgin' SD cards, as needed. image-mount lets me make certain classes of updates to my SD "golden master" without having to go through a complete rebuild.
Botspot
Fri Aug 30, 2019 2:50 pm
These are brilliant! I have used portions of image-mount in my bash script to let it mount and boot a Raspbian disk image using systemd-nspawn.
Bug report:
image-mount does not accept disk images located in a directory that contains the space character. (And yes, I tried using quotation marks.)
pi@raspberrypi:~ $ sudo /home/pi/image-utils/image-mount "/home/pi/Web drives/DMA Google Drive/image files/2019-06-20-raspbian-buster-full.img" /media/pi/fs Linux
Mount /home/pi/Web drives/DMA Google Drive/image files/2019-06-20-raspbian-buster-full.img on /media/pi/fs (y/n)? y
/home/pi/image-utils/image-mount: line 66: drives/DMA * 512: division by 0 (error token is "DMA * 512")
Unable to create loop device
My doctor told me my brain is as useful as a Raspberry Pi. Is that a compliment?
scruss
Fri Aug 30, 2019 10:22 pm
Yeah, it doesn't quite get the quoting right around starting round about line 60.
Of course, no-one I know would admit the creating or owning any file system with spaces in the name …
(joke, in case it was too obtuse.)
RonR
Sat Aug 31, 2019 4:13 am
The problem was totally unrelated to quoting. The problem was due to using fdisk to display disk parameters and awk to parse them. The addition of spaces in path/file names caused awk to grab the wrong fields. The solution was to switch to sfdisk and sed.
An updated image-utils.zip file is now available in the first post of this topic which works properly with spaces in path/file names.
Thanks Botspot for reporting this.
Milliways
Sun Sep 15, 2019 7:36 am
I had used image-mount: to view a downloaded image and tried to use image-backup to perform a backup.
The documentation is incredibly brief, there is no help and even examining the script didn't help much - it is devoid of any comments.
I have a mounted drive (in /mnt/PiHDD) which I wanted to use for the backup.
I have tried all the following (and more)
sudo ./image-utils/image-backup /mnt/PiHDD/BusterBackup
/mnt/PiHDD/BusterBackup not found
sudo ./image-utils/image-backup /mnt/PiHDD/ BusterBackup
/mnt/PiHDD/ is a directory
cd /mnt/PiHDD
sudo /home/pi/image-utils/image-backup BusterBackup
BusterBackup does not begin with /mnt/ or /media/
How, on earth, do you perform a backup?
RonR
Sun Sep 15, 2019 7:47 am
"Running image-backup with no parameters will create a full backup."
sudo image-backup
"Running image-backup with a parameter of an existing image filename will incrementally update that image file."
sudo image-backup image_file_name
You must start with a full backup and then you can incrementally update it if you wish.
jcyr
Sun Sep 15, 2019 6:09 pm
How hard would it be to make this work for hybrid boot (/boot on SD, / on USB) with backup to CIFS share?
It's um...uh...well it's kinda like...and it's got a bit of...
RonR
Sun Sep 15, 2019 6:15 pm
That already works.
Botspot
Sun Sep 15, 2019 7:38 pm
Thanks so much RonR for these powerful scripts!!
I am using image-mount in my vdesktop script, it allows me to mount a Stretch image on a Buster OS, then boot that as a VM in a VNC-style window!
Edit: shorten link
Milliways
Mon Sep 16, 2019 7:19 am
deleted
Botspot
Mon Sep 16, 2019 12:30 pm
deleted
Remember we want information...No information no help. Could you clarify "deleted"?
Milliways
Mon Sep 16, 2019 12:54 pm
deleted
Fix the Forum so that posts can be deleted.
Botspot
Mon Sep 16, 2019 1:36 pm
Never done this personally, but I think you can flag your own post and tell the moderator you want it deleted.
jcyr
Mon Sep 16, 2019 4:37 pm
Hmmm... I've never had any issues deleting my own posts! That's what the garbage can icon does...
Mon Sep 16, 2019 4:40 pm
You can delete them until someone makes another reply following it.
Milliways
Wed Sep 18, 2019 6:26 am
I have run the backup, but before copying the image to a SD Card decided to check it out.
I noticed that directories under /mnt were NOT copied. I have a number of directories which my fstab assumes exist, but they were missing.
This is not a major problem but is easily fixed.
I changed the rsync to copy the directories, but not contents with an exclude /mnt/*/*
rsync -aDH --partial --numeric-ids --delete --force --exclude "${MNTPATH}" --exclude '/dev' --exclude '/media' --exclude '/mnt/*/*' --exclude '/proc' --exclude '/run' --exclude '/sys' \
This looks like a great script.
It makes more compact backups than dd and these compress to a much smaller .gz file because that omit a lot of transient rubbish.
Unfortunately the "documentation" is extremely brief. Even understanding the script is difficult as is totally devoid of comments.
I have commented my version and added a message to let you know it has started a backup update.
I will probably update my copy to facilitate making a fresh backup without the need to answer on-screen prompts.
RonR
Tue Oct 08, 2019 9:31 am
image-utils.zip (in the first post of this topic) has been updated.
Backups created with image-backup now auto expand the root filesysystem on the first boot. Manual resizing with raspi-config is no longer required regardless of whether the backup is restored to an SD card or a USB device.
itsmedoofer
Tue Oct 08, 2019 10:16 am
Thanks Ron, appreciated!
Return to “Advanced users”
