ProDigit
Re: Update procedure too slow on a Pi 3B+
Fri Aug 16, 2019 6:18 am
Since I now have both the Sandisk MicroSD 64GB A2 as well as the A1 card, I can do a much more precise measurement of both cards on the Pi 3B+ internal card reader.
Both cards are inserted in the exact same Pi 3B+ unit, both cards have Raspbian Buster full desktop version on them.
Both cards are updated to the latest, and here are the test results:
Of the A1:
fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test --filename=test --bs=4k --iodepth=64 --size=256M --readwrite=randrw --rwmixread=75
test: (g=0): rw=randrw, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=libaio, iodepth=64
fio-3.12
Starting 1 process
test: Laying out IO file (1 file / 256MiB)
Jobs: 1 (f=1): [m(1)][97.9%][r=3227KiB/s,w=1245KiB/s][r=806,w=311 IOPS][eta 00m:01s]
test: (groupid=0, jobs=1): err= 0: pid=3230: Fri Aug 16 02:14:32 2019
  read: IOPS=1030, BW=4122KiB/s (4221kB/s)(192MiB/47684msec)
   bw (  KiB/s): min= 1984, max= 5040, per=99.88%, avg=4117.05, stdev=545.01, samples=95
   iops        : min=  496, max= 1260, avg=1029.18, stdev=136.22, samples=95
  write: IOPS=343, BW=1375KiB/s (1408kB/s)(64.0MiB/47684msec); 0 zone resets
   bw (  KiB/s): min=  704, max= 1688, per=99.91%, avg=1373.69, stdev=172.62, samples=95
   iops        : min=  176, max=  422, avg=343.40, stdev=43.15, samples=95
  cpu          : usr=2.17%, sys=9.04%, ctx=91147, majf=0, minf=16
  IO depths    : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=99.9%
     submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.1%, >=64=0.0%
     issued rwts: total=49141,16395,0,0 short=0,0,0,0 dropped=0,0,0,0
     latency   : target=0, window=0, percentile=100.00%, depth=64
Run status group 0 (all jobs):
   READ: bw=4122KiB/s (4221kB/s), 4122KiB/s-4122KiB/s (4221kB/s-4221kB/s), io=192MiB (201MB), run=47684-47684msec
  WRITE: bw=1375KiB/s (1408kB/s), 1375KiB/s-1375KiB/s (1408kB/s-1408kB/s), io=64.0MiB (67.2MB), run=47684-47684msec
Disk stats (read/write):
  mmcblk0: ios=48399/16333, merge=622/69, ticks=2522336/474228, in_queue=119940, util=99.00%
A2:
fio-3.12
Starting 1 process
Jobs: 1 (f=0): [f(1)][100.0%][r=4524KiB/s,w=1468KiB/s][r=1131,w=367 IOPS][eta 00m:00s]
test: (groupid=0, jobs=1): err= 0: pid=850: Fri Aug 16 02:22:31 2019
  read: IOPS=985, BW=3942KiB/s (4036kB/s)(192MiB/49869msec)
   bw (  KiB/s): min= 3088, max= 4736, per=99.81%, avg=3933.55, stdev=217.43, samples=99
   iops        : min=  772, max= 1184, avg=983.38, stdev=54.34, samples=99
  write: IOPS=328, BW=1315KiB/s (1347kB/s)(64.0MiB/49869msec); 0 zone resets
   bw (  KiB/s): min= 1040, max= 1564, per=99.89%, avg=1313.62, stdev=87.58, samples=99
   iops        : min=  260, max=  391, avg=328.36, stdev=21.89, samples=99
  cpu          : usr=3.47%, sys=13.73%, ctx=76508, majf=0, minf=16
   READ: bw=3942KiB/s (4036kB/s), 3942KiB/s-3942KiB/s (4036kB/s-4036kB/s), io=192MiB (201MB), run=49869-49869msec
  WRITE: bw=1315KiB/s (1347kB/s), 1315KiB/s-1315KiB/s (1347kB/s-1347kB/s), io=64.0MiB (67.2MB), run=49869-49869msec
  mmcblk0: ios=48255/16297, merge=592/80, ticks=2622927/503435, in_queue=134420, util=99.83%
In this case the A1 was only slightly faster, but the previous numbers from the A2 I thought I posted, the A2 was faster.
The numbers are subjective, but I think it's safe to say that both A2 and A1 MicroSD cards will operate the same on a Raspberry Pi 3B+.
Tomorrow I'll test them out on a Raspberry Pi Zero W, as I have one available.
I currently don't own a Pi 4 yet, so I can't comment on that.
The A2 drives do have much faster burst speeds, than the A1 drives, up to 70MB/s.
This will not do much of anything when the MicroSD card reader is running at USB 2.0 speeds.
Return to “Raspbian”
