plugwash
sonic-pi 3.10 for buster available for testing.
Thu Jul 18, 2019 6:46 pm
Add
deb http://plugwash.raspbian.org/sonic-pi buster-sonicpi main
to your sources.list
apt-get update && apt-get install sonic-pi sonic-pi-server sonic-pi-samples
I have done a basic smoke test of running the application and trying out the first example in the tutorial, but i'm not a sonic-pi guy so feedback from people who actually use sonic-pi would be welcomed.
ShiftPlusOne
Re: sonic-pi 3.10 for buster available for testing.
Fri Aug 30, 2019 1:30 pm
Just tried building it for i386 and amd64:
dh_auto_configure
        cd app/gui/qt && qmake -makefile "QMAKE_CFLAGS_RELEASE=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CFLAGS_DEBUG=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CXXFLAGS_RELEASE=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CXXFLAGS_DEBUG=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_LFLAGS_RELEASE=-Wl,-z,relro -Wl,-z,now" "QMAKE_LFLAGS_DEBUG=-Wl,-z,relro -Wl,-z,now" QMAKE_STRIP=: PREFIX=/usr
Info: creating stash file /<<PKGBUILDDIR>>/app/gui/qt/.qmake.stash
Project ERROR: Unknown module(s) in QT: opengl
dh_auto_configure: cd app/gui/qt && qmake -makefile "QMAKE_CFLAGS_RELEASE=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CFLAGS_DEBUG=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CXXFLAGS_RELEASE=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_CXXFLAGS_DEBUG=-g -O2 -fdebug-prefix-map=/<<PKGBUILDDIR>>=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2" "QMAKE_LFLAGS_RELEASE=-Wl,-z,relro -Wl,-z,now" "QMAKE_LFLAGS_DEBUG=-Wl,-z,relro -Wl,-z,now" QMAKE_STRIP=: PREFIX=/usr returned exit code 3
make[1]: *** [debian/rules:19: override_dh_auto_configure] Error 3
make[1]: Leaving directory '/<<PKGBUILDDIR>>'
make: *** [debian/rules:10: build-arch] Error 2
plugwash
Sat Aug 31, 2019 1:21 am
I'd guess it needs a build-dependency on libqt5opengl5-dev
jamesrobinson
Mon Sep 02, 2019 8:22 am
I have tested the install on a Pi 4 and everything I would usually use for a Picademy session is there and work's perfectly! Thanks so much
Botspot
Contact: Yahoo Messenger
Sat Sep 14, 2019 1:33 am
Worked last month, but today it wouldn't open. Strange.
Opened an issue on github, but error output is here also:
Sonic Pi Boot Error Report
System Information
* Sonic Pi version: 3.1.0
* OS: Raspbian GNU/Linux 10 (buster)
GUI Log
**`/home/pi/.sonic-pi/log/gui.log`**
[GUI] - Detecting port numbers...
[GUI] - GUI OSC listen port 4558
[GUI] -    port: 4558 [OK]
[GUI] - Server OSC listen port 4557
[GUI] -    port: 4557 [OK]
[GUI] - Server incoming OSC cues port 4559
[GUI] -    port: 4559 [OK]
[GUI] - Scsynth port 4556
[GUI] -    port: 4556 [OK]
[GUI] - Server OSC out port 4558
[GUI] - GUI OSC out port 4557
[GUI] - Scsynth send port 4556
[GUI] - Erlang router port 4560
[GUI] -    port: 4560 [OK]
[GUI] - OSC MIDI out port 4561
[GUI] -    port: 4561 [OK]
[GUI] - OSC MIDI in port 4562
[GUI] -    port: 4562 [OK]
[GUI] - Init script completed
[GUI] - using default editor colours
[GUI] - launching Sonic Pi Server:
[GUI] - starting UDP OSC Server on port 4558...
[GUI] - UDP OSC Server ready and listening
[GUI] - Ruby server pid registered: 20853
[GUI] - waiting for Sonic Pi Server to boot...
[GUI] - Critical error! Could not boot Sonic Pi Server.
[GUI] - stopping UDP OSC Server...
[GUI] - UDP OSC Server no longer listening
Server Errors
**`/home/pi/.sonic-pi/log/server-errors.log`**
Failed to load the fast_osc c-extension, falling back to pure Ruby version
Overriding fast_osc c-extension FastOsc::decode_single_message, falling back to pure Ruby version
control open "hw:0" (No such file or directory)
ALSA lib pcm_hw.c:1822:(_snd_pcm_hw_open) Invalid value for card
ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
Cannot initialize driver
JackServer::Open failed with -1
Failed to open server
ruby: No such file or directory -- /usr/app/server/ruby/bin/task-register.rb (LoadError)
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
JackTemporaryException : now quits...
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
terminate called without an active exception
Server Output
**`/home/pi/.sonic-pi/log/server-output.log`**
Sonic Pi server booting...
Using protocol: udp
Send port: 4558
Listen port: 4557
  - OK
Scsynth port: 4556
  - OK
Scsynth send port: 4556
  - OK
OSC cues port: 4559
  - OK
Erlang port: 4560
  - OK
OSC MIDI out port: 4561
  - OK
OSC MIDI in port: 4562
  - OK
Booting server...
Booting Sonic Pi
Booting on Raspberry Pi
Jackd not running on system. Starting...
jackdmp 1.9.12
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2016 Grame.
Copyright 2016-2017 Filipe Coelho.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
creating alsa driver ... hw:0|hw:0|2048|3|44100|0|2|nomon|swmeter|-|32bit
Boot - Starting the SuperCollider server...
Boot - scsynth -u 4556 -m 131072 -a 1024 -D 0 -R 0 -l 1 -i 2 -o 2 -z 128 -c 128 -U /usr/lib/SuperCollider/plugins:/usr/app/server/native/extra-ugens/ -b 4096 -B 127.0.0.1
Scsynth Output
**`/home/pi/.sonic-pi/log/scsynth.log`**
# Starting SuperCollider 2019-09-13 20:26:16
Found 0 LADSPA plugins
*** ERROR: open directory failed '/usr/app/server/native/extra-ugens/': No such file or directory
jackdmp 1.9.12
creating alsa driver ... hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
could not initialize audio.
Process Log
**`/home/pi/.sonic-pi/log/processes.log`**
Clearing pids: []
No pids to clear :-)
Started [19014] [-] ruby -E utf-8 /opt/sonic-pi/app/gui/qt/../../../app/server/bin/sonic-pi-server.rb -u 4557 4558 4556 4556 4559 4560 4561 4562 [-] /tmp/sonic-pi-pids/19014
Started [19086] [-] sh [-] /tmp/sonic-pi-pids/19086
Started [19143] [-] scsynth -u 4556 -a 1024 -m 131072 -D 0 -R 0 -l 1 -z 128 -c 128 -U /usr/lib/SuperCollider/plugins:/opt/sonic-pi/app/server/native/raspberry/extra-ugens/ -i 2 -o 2 -b 4096 [-] /tmp/sonic-pi-pids/19143
Started [19214] [-] sh -c erl -pz "/opt/sonic-pi/app/server/erlang" -s pi_server start 4560 [-] /tmp/sonic-pi-pids/19214
Started [19268] [-] sh -c '/opt/sonic-pi/app/server/native/raspberry/osmid/o2m' -b -i 4561 -O 4562 -m 6 [-] /tmp/sonic-pi-pids/19268
Started [19299] [-] sh -c '/opt/sonic-pi/app/server/native/raspberry/osmid/m2o' -b -o 4562 -m 6 'Sonic Pi' [-] /tmp/sonic-pi-pids/19299
My doctor told me my brain is as useful as a Raspberry Pi. Is that a compliment?
plugwash
Sat Sep 14, 2019 8:23 am
Seems like jack is failing to open the audio device. Are you running any other audio related stuff?
Botspot
Sat Sep 14, 2019 12:19 pm
Not that I'm aware of. How could I find out?
rbn
Tue Sep 17, 2019 11:45 am
Interested to come across this.
Personally I build SP 3.2dev from source on a Pi4 with Buster (run apt-update and apt-upgrade on it first)
Details for the build are at https://in-thread.sonic-pi.net/t/buildi ... a-pi4/2645
I have been using this both on Pi4, and on Pi2 and Pi3 with Buster.
There have been quite a lot of changes to the source code since 3.1 with several bugs sorted, and the structure of the code layout has also changed.
Return to “Raspbian”
