applesauce
PiCamera not working
Thu Jul 11, 2019 11:23 pm
Hey! I'm new to the Raspberry Pi and have recently run into an issue.
I have updated and upgraded Raspbian multiple times in preparation to use my camera. My camera is attached correctly and I have enabled the camera software on my Pi. However, whenever I input raspistill -o cam.jpg into my terminal, I get the following error message:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates.
Whenever I try to use Python to take a photo, I get this message:
  File "/home/pi/DukeTip/camera.py", line 4, in <module>
    camera = PiCamera()
  File "/usr/lib/python3/dist-packages/picamera/camera.py", line 433, in __init__
    self._init_preview()
  File "/usr/lib/python3/dist-packages/picamera/camera.py", line 513, in _init_preview
    self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
  File "/usr/lib/python3/dist-packages/picamera/renderers.py", line 558, in __init__
    self.renderer.inputs[0].connect(source).enable()
  File "/usr/lib/python3/dist-packages/picamera/mmalobj.py", line 2212, in enable
    prefix="Failed to enable connection")
  File "/usr/lib/python3/dist-packages/picamera/exc.py", line 184, in mmal_check
    raise PiCameraMMALError(status, prefix)
picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
I have updated my firmware multiple times while trying to figure this out. I have discussed this with multiple people, but I can't find a solution. How can I fix this?
Thanks!
B.Goode
Re: PiCamera not working
Fri Jul 12, 2019 6:37 am
Welcome to the Raspberry Pi forums.
The official Raspberry Pi documentation for the Camera Module, including Troubleshooting, is here: https://www.raspberrypi.org/documentati ... /camera.md
To highlight some possibilities:
The camera module needs to be enabled in your installed Operating System.
There are 3 connections that need checking.
The camera can only be used by one script or tool at a time.
Return to “Camera board”
